Question about DeLonghi Coffee Makers & Espresso Machines
How to decalcify Delonghi Rialto 4500
Need to decalcify my machine, I have not done so since I brought it many yrs already. I used filtered water but figure it may need to be cleaned out. Coffee not tasting as it should. Also what's the best number to put on grinner for whole beans? I can't seem to get it right, making it too strong, bitter tasting. Thanks
  • 352 Answers
Here is a link to the manual. Descaling is described starting on page 18. http://www.encompassparts.com/shop/research_new/DEI/om/EAM4500.pdf
Posted on Dec 05, 2014
  • 2039 Answers
SOURCE: Coffee doesn't taste good
even if the machine is new use a decalfier 1 partsolution 1 part water normally when you clean start the machine turn it off for a few minute repeat until emty rinse it very good thatstuff is very corosif try after a good wash and dont forget it like a the pot the older the better hope it work cheers
Posted on Jan 17, 2008
SOURCE: What if my coffee tastes bad?
Did you run the vinegar through it three times, then rinse it three times? You might try changing the filter and filter basket.
Posted on Jan 07, 2009
Jeff the TV
  • 82 Answers
SOURCE: Need descaling instructions for EAM 4500 auto espresso machine
use 1/4 cup of vinegar and fill pot with cold water, run through machine
Posted on Aug 01, 2009
cmccune04
  • 213 Answers
SOURCE: coffee is really bitter and doens't taste good
hmm well it wouldn't surprise me. I'm glad you were able to get to the bottom of it! ;) have a great day and enjoy your Keurig!
Posted on Jun 14, 2010
  • 11 Answers
SOURCE: coffee machine blocked
it could be grind stuck in the (yes the, as in the only) hole in the filter cup. remove the filter cup from the cup holder (the thing with the black handle) and use the tiny pin in the little brown tool to push out whatever is in there. you may have used to fine a grind or stuffed the filter cup too much. careful, that is how you break the plastic filter holder ring.
for calcifying, i just use plain white vinegar. i put it in straight into the clear water holder, about 3/4 cup, then i run it throuhg a bit, let it sit 5 min, run it through a bit, let it sit 30 min to an hour. depending on the day, i repeat a few times, rinse with clean water. i do this about every 2 months.
Posted on Aug 13, 2010
DeLonghi Rialto EAM-4500. When I turn it on, it makes loud noises and give me the following message:Ground too fine adjust grinder and insert water spout
Step: 1 Switch off your coffee maker. Remove the first brewer unit. Wash it thoroughly under running water.
Step 2: clean the coffee grinder using vaccum cleaner.
Step 3: switch on the Machine !!! Make Coffee
(Note: if you hear loud noises during coffee preparation then please use food graded grease to fix it)
Mar 19, 2017 | DeLonghi Coffee Makers & Espresso Machines
Delonghi rialto eam4500: Lost Hot Water Spout. Where to get one?
I had the same problem!! I was able to find one on Amazon:
http://www.amazon.com/DeLonghi-5532124900-HOT-WATER-SPOUT/dp/B002EKFX06
It works on 4500 as well as a couple of other models :)
Jul 25, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Delonghi rialto. i need a manuel and video
I'm not sure if there is a specific model number on yours. But here is a link to a DeLonghi Rialto 4500. http://www.starbucksstore.com/images/products/pdf/4_Rialto_Espresso_Machine.pdf
Feb 27, 2010 | DeLonghi Coffee Makers & Espresso Machines
Had the Rialto 4500 for over a year. All of a sudden the milk is not coming out properly, mostly just steam. I've cleaned the tube and container top many times ! What else can it be ?
Me too! They ordered me a new milk pitcher from Italy. Didn't work. They told me to run it through some tests using water in pitcher. Didn't work. They then told me to send it in to a Delonghi repair shop. They just told me that it was all "clogged up" and also needed a new generator. The tow are linked together. We descaled fairly regularly. Total tab: $380! OUch! Have not told them to go ahead. seaching for cheaper solutions. Let me know if you hear of any. wosbrink@me.com.
Will Houston TX
Oct 23, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Aug 01, 2009 | Coffee Makers & Espresso Machines
Stuck filter screen screw on DeLonghi BAR32
i got a saeco vienna digital i got the same problem that screw jam the same as our i clean the filter with water and air if you whant to try something try to soak in decalcifier it gonna melt the calcium cheers
Jan 16, 2008 | DeLonghi BAR 32 Espresso Machine
Coffee Makers & Espresso Machines Logo
209 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
