Question about Refrigerators
The ace bucket auger and blades came apart. I need a diagram to re-assemble the parts.
Nothing. need a diagram of the sequence of parts.
    Filmmaker:
    Uploaded 5 video answers.
  • 28 Answers
Jim, Maybe? This will help............. the ace bucket auger and blades came apart.  I nee - 25301614-s3getkgsyvh2ebjmmxpqj10l-5-0.gif
Posted on Nov 30, 2014
How do I re-assemble the auger and blades for my ice bucket assembly? Kenmore model #795.5103.3011. Is there a diagram available?
Jim, i cannot find exploded view of Kenmore...but maybe one of these is similar enough......... 25301609-s3getkgsyvh2ebjmmxpqj10l-3-0.gif
Nov 30, 2014 | Kenmore Refrigerators
Whirlpool GD5RVAXVY05 dispensing problem
yep replace the motor and she is back to normal
Mar 22, 2014 | Whirlpool Refrigerators
The auger in the ice maker has broken on our model gss201etaww serial dll222857. Can we just buy the auger or do we need to buy the whole ice drawer?
you can buy just a auger. But you better pretty handy. because you have to take bucket apart and lots of small parts that have to go back in the right order. might be better off buying the whole complete bucket.that is ready to go after you wash it
Aug 18, 2011 | GE Refrigerators
The parts in my ice bin have rusted or coroded and now the ice bin needs to be replaced. I can only find parts. Where can I get a whole new ice bin for my Amana sxd26vw?
The only assembly I could find was a auger and blade already assembled. Part # 12740302
Auger and Blade
For this model I am unable to find one that would be complete.
I hope this helps
At least these are the only parts the could rust in this bucket other than the flat metal plate in front.
Aug 14, 2011 | Refrigerators
What is a replacement part number for the ice maker tray 197D2303?
Hello BeckJeff, I believe that your fridge has the built-in ice maker and water dispenser and as such, only accumulates ice cubes in the ice maker's integral ice bin or as they call it, the ice bucket.
According to the parts list for the PSS26MSR series of refridgerators, the ice bucket and auger are supplied as a complete subassembly.
The part number is WR17X11447 and you can get ordered through any GE appliance dealer or online from several sources of your choice. If you have difficulty getting the part, you can also order it directly from searspartsdirect.com.
The approximate retail price for this should be $165.00 or less, again, depending on where you order it from.
I would suggest you confirm that this is the correct replacement part for your specific fridge model, before you order the part, so you're certain you receive exactly what you are seeking. You can call the folks at sears, toll free, to confirm the part. They can be reached at 1-800-252-1698.
I hope you find this Very Helpful and best regards!
Nov 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
How do i remove the agitator on my kenmore 23822100 washing machine?
The agitator on your model washer is a split design. The upper portion is called the auger, the bottom is the agitator. It comes apart by followng these simple steps:
1. Remove the center cap on the auger by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap. Make sure you keep the gasket. This is used to create an air gap to keep water from leaking into the transmission, so make sure you seat it properly for a good seal when you reassemble.
2. If the auger is equipped with an inner cap underneath with a handle, remove this as well by pulling straight up.
3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4. With the center bolt removed, you can remove the entire assembly with the auger still attached to the top of the agitator, by grasping the bottom flange near the bottom of the tub and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this reassembly much easier.
If the agitator comes apart and you need assistance in how the parts go back together, refer to searspartsdirect.com for some helpful exploded view diagrams under the "Agitator, Basket and Tub" parts section.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Oct 17, 2009 | Washing Machines
How do you take apart an agitator on a Whirlpool Estate Washing Machine
The agitators on Whirlpool manufactured washers usually have a split design. The upper portion is known as the "auger", the lower portion is the agitator. To get the whole assembly apart just follow these steps:
1. Remove the auger center cap/dispenser by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
4. Remove the auger by carefully pulling straight up. Try to keep all the cam assembly parts assembled while doing this, so do not pull too hard. This will make this reassembly much easier.
5. With the auger removed grab the agitator at the bottom flanges and pull straight up to remove from the gearcase shaft.
If you need an illustration of how the components go back together, refer to any of these websites for helpful exploded view diagrams:
pcappliancerepair.com
appliancepartspros.com
NOTE: When reassembling, make sure you get the auger seal seated properly. If it is not sealed, water will leak into the gearcase shaft and ruin it.
If you have any questions, or need further assistance, please let me know. I hope this helps you.
Oct 06, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Ice maker makes ice but can't dispense ice
Please try this. Remove your Removable Ice Bucket Assembly which is where the Auger (corkscrew) is located. You should be able to see the Auger Motor Drive Fork which is located permanently inside the freezer compartment... opposite the end of the Removable Ice Bucket Assembly that you just took out. Close the freezer door and attempt to dispense ice... if you can hear the Auger Motor running as you attempt to dispense ice... then the Auger Motor is OK. Dump out all the ice that is in your Removable Ice Bucket Assembly and wash it out in your kitchen sink with warm water. Reach into your freezer and put your hand on the Auger Motor Drive Fork ... you should be able to rotate it CW or CCW...it is a little hard to turn but it will turn. Position the Auger Motor Fork to a 12:00 and 6:00 o'clock position. Now take your Removable Ice Bucket Assembly and position its Receiver Auger Fork to a 9:00 and 3:00 o'clock ....Re install the Removable Ice Bucket Assembly into the Auger Drive Fork. Close the freezer door and again attempt operate the ice dispenser... you should hear the Auger Motor again run as you press the ice dispenser. Note....at this same time the Ice Chute Door in the Freezer Door should spring open so that ice can fall out. Of course you have no ice in the Auger at this time...but it all this works then future production of ice will fall out. Note...Usually the Auger Motor never fails. but the whole thing can get jammed with ice and not dispense. Also, the the solenoid that operates the Ice Chute Door fails quite frequently. Last but not least... if nothing is happening... it is a control board type problem. Hopes this helps! Handy Henry
Jul 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The icemaker makes ice, but it won't dispense.
rmielsen and PhyllisForbe,  Your refrigerator has an auger motor that causes the ice to be dispensed when you press the ice selector on the front of the refrigerator.  You could have several possible problems that will gives you the same result.  The auger motor could be at fault. The ICE selector part of the  control panel of the front of the refrig could be at fault.  To isolate to auger or control... do the following.  Remove the ice bucket or auger assembly from the freezer. Reach into the freezer compartment where the auger assembly normally would be.  You should be able to see a "horse shoe shaped metal drive assembly" that would mesh with the auger assembly (ice bucket) to turn the cork screw shaped auger. Try and turn the auger drive assembly in rear of freezer to determine if motor armature is free.  The is somewhat difficult to do because the auger motor is high torque, slow rpm motor, but it should turn if it is good. Sometimes the auger motor will become stuck due to a water leak, inactivity, high humidity during a defrost cycle, etc.  The more possible suspect is the ICE selector assembly on the front of the refrigerator.  If any function on the refrig fountain dispenser control panel goes bad...then the ice/water control assembly will need to be replaced.  Hopes this helps you!  HandyHenry
Jan 30, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE PS123 MGNA CC Ice Auger
I just finished replacing the ice auger in my GE HSS25GFPA side-by-side and offer some suggestions/hints.
The auger (WR17X11705) was available locally (Appliance Parts Co., $28.97). This fits many other refrigerators. The replacement took a little under 2 hours. I estimate these hints may cut the time by one-half.
There are only 4 screws in the entire ice drawer assembly. It possibly was not necessary to remove the control rod. The other 3 screws hold the front cover. There are also 2 tabs holding the top of the cover.
The most difficult part of the repair was removal of the plastic assembly housing the crusher blades and the front bearing of the auger. This is held in place by only 2 large square tabs on the sides. There is enough space to get ONE side to release BUT to get both released required careful prying with thin-bladed screwdrivers (and prayer). These "tabs" don't push in, rather the drawer flexes out. Once released, the unit slides up and angles to allow removal of the auger/crusher. Re-assembly could not be easier. Stainless sheet metal screws would probably work if you do break something.
Remove the clear inside cover of the crusher assembly and the "C" clip on the threaded end of the auger shaft to separate the auger from the crusher.
And now for my PRIMARY reason for sharing my experience - the %#$@ plastic nut/bearing is a LEFT-HAND THREAD. I only realized this when trying to bend my make-shift split screwdrive back and the SOB loosened right up!
Carefully note the locations and orientations of the blades and spacers as you move them from the old to the new auger.
Nov 22, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
