<!-- from fixya rte -->Can I connect a programmable thermostat - Heating & Cooling
  • 1 more comment
  • Bob Baker
    Bob Baker Nov 30, 2014
    Connect to Coleman Presidential II 7670 model
  • tractorman44
    tractorman44 Dec 02, 2014
    What in specifically are you connecting it to? Gas or electric, Oil or heat pump ?? Single stage heat and cool,or two stage heat and cool. Single stage heat and single stage cool, Single stage heat and two stage cool ??
  • Bob Baker
    Bob Baker Dec 02, 2014
    Connect to Coleman Presidential II 7670 model in a mobile home >gas > no cooling> maybe heat pump > it only has two wires and both are green
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
Dec 02, 2014
A heat pump connected would require quite a few additonal wires and a standard central A/C would require a total of 5 for a good quality programmable with single stage heat and single stage cooling in the circuit.
The two wires you refer to should be all that's required to operate heat only with a standard thermostat. You must do one of two things though to add a programmable thermostat:
1) Either select a programmable stat that operates on battery power alone, necessitating periodic battery replacement or,
2) Prepare yourself to pull at least one additional wire from the furnace to the thermostat location.
The two wires, if utilizing a battery powered stat can go to either R or Rh and to W. Either wire to either terminal because you are only completing the one circuit. Ideally you would want to locate which of the two is the one directly off of the ' hot' side of the transformer.
If you opt to pull an addiional wire for a thermostat of a superior quality, you will HAVE to determine which of the two green wires is the hot side of the transformer and it MUST be connected to R or Rh. The second green wire goes to W. The third wire that you had to add must go to the C thermostat terminal. That same wire has to be connected to the neutral side of the transformer to complete the circuit. Most programmable t-stats require both 24v hot and 24v neutral to operate, then have the battery for back up during a power failure whereas the battery powered stat runs entirely on the battery and not 24v from the furnace.
If you are unable to determine the wire connections as outlined above, do not attempt it....remember you are working on an LP furnace !!! Any doubt on the ability to ascertain correct locations for the terminations requires you to contact a qualified technician as there is only so much that can be gleaned by a person in a remote location from a typewritten description of the situation.
Posted on Dec 03, 2014
I am unable to connect to the Internet even though the email address and password are accurate. This just happened.
Trouble Shooting - - FAQs ' FWD - Honeywell
lyric.honeywell.com/support/troubleshooting/
How do I delete that thermostat from my Lyric app? If you've moved and ... How do I change the email address I use to manage my Lyric? If you already have a ...Missing: programmable ‎accurate
Wi-Fi 7-Day Programmable Thermostat ' Honeywell
yourhome.honeywell.com/.../thermostat/wi-fi-7-day-program...
HoneywellThe Wi-Fi 7-Day Programmable Thermostat is designed for the way you live ...Features such as Smart Response and precision temperature accuracy bring ... your home heating and cooling system, and then remove your existing thermostat. .... Whileconnecting to Wi-Fi, my model RTH6580WF or TH6320WF thermostat is ...
FAQs - Total Connect Comfort
Dec 29, 2015 | Honeywell Programmable Thermostat Heater
Honeywell cm61ng connection to relay box
Make sure the green button is on @ the relay box.
Nov 27, 2013 | Honeywell Programmable Thermostat Heater
Colman evcon ''B'' relay connection on new programmable t/stat
Hello The B wire now goes to the O termnal on new thermostat.
Apr 03, 2010 | Coleman Heating & Cooling
How do i hookup a thermostat to a dayton unvented radiant heater modle be132c
Hi, If you are hooking up a programmable stat, the connections on it would be RC, RH, with a jumper connected to both, Y, W, and G. If you only had 2 wires before, red to RH and white to W. For cooling,Red to RC, and W to Y. Do not remove the jumper.
Shastalaker7
Nov 29, 2009 | Honeywell Programmable Thermostat Heater
Updating old honeywell thermostat with a new honeywell thermostat
check in the unit heater to see what is hooked up most only need to have red from transformer white to call for heat and green to make the fan run in man and somtimes common usually blue or black
May 09, 2009 | Honeywell Programmable Thermostat Heater
Non programmable Honeywell to programmable
the 230 doesnt sound compatable with your system. you are gonna need a t stat that is compatable with Heat Pumps.
Mar 18, 2009 | Honeywell Programmable Thermostat Heater
Rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
Dec 28, 2008 | Honeywell Electronic Programmable...
Hunter 44360 thermostat wiring
OMG! has anyone came up with a solution? I have the same problem as mlc3530b
Mar 08, 2008 | Hunter Fan Company 5/1/1 Programmable...
Wiring a Honeywell Deluxe Programmable Thermonstat
did you mark which terminals you removed the wires from on the old stat? If not you will need to look on the furnace and see what letters they are connected to .. then connect to the same on the thermostat.
Feb 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
91 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
