Question about KitchenAid KSM150PSGR - Artisan Series 5-Quart Mixer, 10 Speed, Imperi
How do I fix my Kitchenaid mixer, that produces a loud clatter at low speeds and a burning smell?
I've imported this machine from the US into Europe. Not aware of the 110/220v issue, I plugged it in and caused a short-circuit. The governor screw of the device came apart during the incident. I ordered a new governor as well as a power converter (220 to 110v). After assembling the new governor the device now makes a loud sound and produces a burning smell. The sound seems to be caused by the governor pushing against the brass part of the speed-control plate. The governor did the same after I reassembled to old one (whilst using the purchased power converter). However, when I put the machine on full speed, the sound dies away and the locomotion becomes regular. I've tried tuning the speed by adjusting the top two, and bottom one, screws, but to no avail. As soon as I turn on the kitchenaid, the governor pushes against the speedcontrol plate which produces a loud sound, as well as green sparks. To get a better image of the issue at hand, please take a quick look at below video: https://www.youtube.com/watch?v=TbgW13ZQN-w&list=UUHkfUtredxlGLEIXZLBGmz What can I do to fix this device? Will it even work in Europe with a power converter, or should I give up and buy a European model? Many thanks in advance!
  • KitchenAid Master
  • 1,259 Answers
That green sparking looks to be in the area of the off/on contacts, look for something causing them to not be touching properly. The speed control lever has a ramp on the plastic end that goes through that speed control plate to move that copper arm, that is the off/on switch. I'm wondering if maybe the voltage from your converter is not fully as it should be, just a thought. If you wanted to properly convert to Euro voltage you need an armature, a set of fields and that small PCB with the 6 wires off it just above the black speed control plate. You set your slowest speed (#1) with the 2 screws and locknuts on the top of the speed control plate. 13 to 15 rpm in 15 seconds, I do it by running mixer with palm of my hand in position to be bumped by the silver shaft on the planetary each revolution, count them and watch your second hand. Once that is done you set that bottom screw to just increase the speed as you click the lever into speed 2. Had a look at your video, the governor does not sound happy, it could be the back plate adjustment out of whack to cause it. You can email me with more questions if you like screaming_skull@hotmail.com
Posted on Dec 01, 2014
3 Suggested Answers
  • 1704 Answers
SOURCE: KitchenAid mixer runs evenly at low speeds, motor
Hi, It could be the variable speed switch. (bad) Replace it for a new one. Good luck.
Posted on Sep 27, 2011
  • 185 Answers
SOURCE: kitchenaid mixer makes a clattering sound at low speeds - seems to be coming from the governor or the control plate - any ideas, is this a common problem and how should I approach it?
Did it start clattering before or after it was re-greased? The K5ss by Hobart is an excellent mixer and there is no reason why it can't go on for a bunch more years. First you can get clattering if the brushes are less than 5/16th inch long, But that is not usual.
I would think that the rear bearing which is in the center at the rear may be more your problem, That bearing is behind the speed control switch and behind the governor (don't discount the governor being the problem) and is attached by two 3/8th nuts and slides onto the two guide slides that hold the motor parts in place. What i have found over the years is that 1.) the studs can bend (happens but not often) 2.) the bearing which is in the center of the big aluminum housing, (Called rear bearing assembly) moves over the years and causes humming and clattering.
So what to do about it? Loosen the two nuts a turn or two (do not remove) look at the top of the the bearing assembly and you will see a metal tab (used to attach the rear cover) (make sure the bowl and beaters are not attached to the machine) now plug it in and turn it to stir speed or number 2 position, put your finger on top of the tab and press down while the mixer is running, you should hear a change in pitch, and it should effect the clattering noise, (It will go up or down, or you may hear a new noise a light humming) (The humming is caused by the armature no longer in the center of the motor field and getting to close to the stator of the motor while it is operating, when it is out of center the developed magnetic field that causes the armature to turn gives off the humming noise because it is out of center or balance) if you notice that the clattering gets louder or softer by pushing down or pulling up you have to play with it to find the sweet spot, when you find it tighten the two nuts down just enough to hold it in place and no more. It takes a while and you wont hurt the machine but never go above speed two while doing this. If that fixes the problem you may have to do it more than once as the machine continues to age or if you move the machine around a lot. the real problem is the armature needs replacing (if this is the problem). Next you may have the machine timed wrong and that has to do with the speed control switch entirely, let us know what you find if these are not the problems we have a ways to go but they are the usual culprits with your symtom.
Posted on Mar 04, 2013
Kitchenaid mixer shot sparks when turned to high
Tanya, it sounds like there might have been a short to ground, that is when a wire comes loose and touches the housing. So you will definitely have to rewire/fix the wiring in the mixer, there is a wiring diagram in the KitchenAid service manual (http://ep.yimg.com/ty/cdn/mendingshed/kitchenaidservicemanual.pdf)
There may have also been damage to the speed control plate or phase board, either part would have burn marks on it in most cases.
You can find replacement parts here: http://www.mendingshed.com/regmixerparts.html
And as always if you have any questions give us a call, we have technicians that work on these every day at our repair shop that can help guide you in the repair.
-Colleen @Mending Shed
Apr 04, 2015 | KitchenAid KSM150PS Artisan Series Stand...
No power on kitchenaid mixer
Apart from checking a fuse, there is little more you can do. Did you notice a loss of power or burning smell the last time you used this? What make and model you have may help others identify a known problem with your machine.
Kind Regards, Dan.
Sep 08, 2014 | KitchenAid Classic Stand Mixer
Kitchenaid mixer makes a clattering sound at low speeds - seems to be coming from the governor or the control plate - any ideas, is this a common problem and how should I approach it?
Feb 21, 2013 | KitchenAid K5SS Heavy Duty Commercial...
I need a replacement motor on a KitchenAid Professional HD Stand Mixer (Model KG25H7XSL).
The loud pop was probably the soft start circuit board on the motor. You can buy this board at repair sites or Ebay. And yes, they make 220V versions of this mixer.
http://www.samstores.com/product-kitchenaid-5ksm5ebu-heavy-duty-mixer-for-220-volts-%28cobalt-blue%29-16220.html
Dec 31, 2012 | KitchenAid Food Mixers
Kitchenaid 525 stopped working while mixing cookie dough
Let it completely cool and then start again. It overheated because your speed was set too low for the heaviness of the dough. I have burned up three kitchenaid stand mixers so far making bread. go up one setting at least; if it is straining, go up another.
Dec 15, 2012 | KitchenAid KP2671 Professional 6 Series...
Kitchen aid khm3wh beaters will not stay in mixer
I fixed mine (my wife's). Kitchenaid 3-Speed Hand Mixer KHM3WH. Here's how I did it.
This is a pretty old mixer. My wife bought it at a thrift store for $1. She brought it home, we found the beaters and whisk beaters on eBay. Paid $34.00 for both sets of beaters, but when we received them we found they would not stay in the mixer. Oh we also bought the alternative/replacement beaters from Sears, parts online. I don't think those will work with my fix. However with some $0.92 rubber washers from Lowe's and a heavy duty paperclip I fixed the mixer, and it works flawlessly. Maybe some stainless steel wire would be a better, more permanent fix.
Apr 30, 2012 | KitchenAid KHM3 Classic Hand Mixer
My Kitchenaid mixer (k5ss lift bowl?) smells hot
I think you have a K45SS. It sounds like there is a problem with one of the gears, probably the worm gear. The worm gear is designed to be the first to fail if the mixer has struggled with a heavy dough or other difficult to mix substance. The best way to establish the cause will be to open the head up and check the gears for signs of damage.
Jan 25, 2010 | KitchenAid K5SS Heavy Duty Commercial...
I have a KitchenAid Pro 600 stand mixer, and it makes a loud whining noise which gets louder and ear piercing the faster the speed setting. I did not make this noise when I first got it, just a gentle...
It appears that you've got some internal transmission gear issues, and a situation similar to my wife's mixer, which we got new in Dec 2006. It could be as simple as the gears have become loose and are making different contact, hence the noise. The higher the speed, the louder, higher pitched sound you'll get. It may also be indicative of a potential gear failure (after all our increasing noise, the bevel gear broke and the mixer 'froze'). If your mixer is under warranty, contact Kitchenaid. If it's out of warranty, then take it apart and do a diagnostic exam of the gearing. Whatever you find you should be able to fix yourself. Be sure to have the Kitchenaid Part Manual (Part No. 8212278 Rev D) on hand if you attempt to disassemble yourself. It also lists all the parts so that you can determine, which parts, if any have failed. You'd think that the Kitchenaid name would warranty their mixers for a lifetime... So much for quality in America today!
Jun 08, 2009 | KitchenAid KP26M1X Stand Mixer
Theres a loud squeaking noise when the mixer turned on
Hi. These mixers normaly make a lot of noise when in operation. Go to the shop that sold it to you, or any place that has these units on display and ask them to turn on the mixer for a demonstration. If their mixer does not make the same noise, then contact Kitchenaid Customer Service and ask for a replacement under warranty. If this solution assists you, please rate it. Good luck! ricardok45
Mar 05, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid KSM150PSGR - Artisan Series 5-Quart Mixer, 10 Speed, Imperi Logo
131 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
