Question about Hitachi Televison & Video
I am coming to you for help again. This time it is my 55" Hitachi Rear Projection TV. I need to change the CRT fluid in it but with this one, I don't see the typical screws to remove the lids.
This one has me stumped. You gave me directions to change the CRT fluid in my Magnavox and it is great. This Hitachi seems to be different. I already bought the fluid thinking it was as easy as my other tv. I can't find any screws to remove the cap to replace the fluid. This TV has never given us any problems until now. Believe it or not, it is 25 years old and in a beautiful Oak cabinet. Can you PLEASE tell me where the caps are located?
  • 208 Answers
SOURCE: tv picture
Unit has a bad optics block (light engine). Rebuilt engines available for around $350.00. I have seen this sympton several times and I am sure this is the problem.
Posted on Mar 11, 2008
  • 101 Answers
SOURCE: Hitachi Tv is automatically turning off and
Its probably the lamp that needs replaced.
Posted on Nov 16, 2009
SD Tech
  • 14553 Answers
SOURCE: Hitachi RP CRT Gone Red On All Inputs!!!
I want you to do a simple visual check of something that will tell me what the problem may be.
Go to a channel that is in black and white--old movie and tell me what color the screen/picture is.
You can also turn the COLOR in the customer menu all the way off and look that way.
What we are trying to see here is if TRACKING is set correctly or has changed. If the screen is somewhat to medium reddish it may be an adjustment outside of the customer menu.
Let me know what you find--I have seen several of these where the black and white picture was somewhat red--the idea is it should be as close to black and white as possible--if red is the predominant background color the picture will look reddish.
If this has helped and you confirm the red instead of black and white picture--I can tell you a easy way to adjust this.
If this information told you something you did not know and helps you rate this solution as I do this here for free.
SD TECH
Posted on Dec 23, 2009
Testimonial: "Got it! Your explanation is very clear and I'll give it a shot right now. I'll let you know how it turns out. Thanks again!"
SOURCE: How to disassemble an old Hitachi projection TV (model 53sbx59b)
To remove the protection screen and lens from my Hitachi model 53SDX89BA:
1) Remove the speaker cover from the bottom. It is attached by velcro.
2) Remove the 4 screws on 4 plastic tabs on the bottom of the screen frame.
3) Remove the 4 screws on the 4 metal tabs on the bottom beneath the screen frame.
4) Pry the bottom corners loose with a wide blade screw driver and work both sides of the screen frame away from the case from the bottom up. CAUTION: The top does not snap away as the sides do. When the sides are loose let the screen frame hang down vertical and lift the screen frame straight up.
5) The protection screen and the lens will come off together.
When reinstalling the screen frame perform the steps in reverse. Be careful when resnapping the frame back onto the case - there are two small wooden support blocks on the bottom. Don't try to force the frame back on until you are sure the bottom of the frame clears these block. You may find it easier just to remove them temporarily until the frame is reattached.
Posted on Jun 09, 2010
Ecollier2012
  • 3459 Answers
SOURCE: philips magnavox 55" rear projection tv problems
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Posted on Dec 15, 2010
Hitachi 61UWX10B 61 in. Rear Projection Television, See double image, Magic focus doesn't fix
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2011 | Hitachi 61UWX10B 61" Rear Projection...
I have a 55 in Hitachi rear prjection tv and the horizontal and vertical lines wont go straight. How do I fix this problem
Please do us a favor and rate this solution after reading.
  • Screen looks 3D
69189a5.pngSOLUTION
Feb 19, 2011 | Hitachi 53UDX10B 53" Rear Projection...
Hi there, I have a hitachi 53" projection tv and
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
69189a5.pngSOLUTION
Jan 31, 2011 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi ultravision hd tv out of focus, shadows, focus button does not fix
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 24, 2011 | Hitachi UltraVision CineForm 55VG825 55"...
Last night we got some multicolor, green, yellow etc horizontal, kind of half moon shapes coming across the screen, removed the front screen and cleaned the lens's and mirror,, no change. Any Ideas?...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 01, 2011 | Hitachi 51SWX20B 51" Rear Projection...
Help
Change the CRT coolant in the green and blue tubes thats a comon problem with that model. You will be amazed at the results that changing the coolant will have on color, it will make it look like new again.
Jun 13, 2008 | Philips 55P8341 55" Rear Projection...
PHILIPS 55PP8620
Good Day;
It sounds like the CRT COOLANT needs replacement, it is a fluid that trys too keep the picture tubes cool , but it some times get "dirty". The fluid is called 'PROJECTION TV COOLANT', it contains; High Concentration of Ethylene Glycol. You can purchase at M.A.T. Electronics; (215) 354-7667, in PA. Part Number 212072-16.
BUY at least 2 containers. CAUTION: remove tubes from TV, just alot of plugs,remove plugs, clean "fluid" chamber, replced discarted fluid. Good Luck, big IRISH. PS more INFO; come back.
Mar 28, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Poor color
You may need fluid change. CRT gets dirty fluid, must be changed after long time of use.
Nov 26, 2007 | Philips 55P8341 55" Rear Projection...
My tv sucks help me
Ryan, this sounds as if the green CRT has gone out in this set. You might want to double check the warranty of your television as this set might have a lifetime warranty on the CRT's. If you cannot find the warranty info on your set, call 1-800-448-2244 for further assistance
Nov 16, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 50 rear projection
Just curious... since the Hitachi 50UX57B projection TV does not have any lamps in it, exactly which "lamp" did you replace? Did you actually replace the entire blue CRT itself?
Jul 23, 2007 | Hitachi 50UX57B 50" Rear Projection...
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
