Question about Keurig Coffee Makers & Espresso Machines
Need source for replacement water filters
Official Breville filters are absurdly expensive and hard to find, even on Amazon. Not sure if the type used on similar Keurig machines is compatible, looks similar but may be too small.
    Filmmaker:
    Uploaded 5 video answers.
  • 28 Answers
Http://www.amazon.com/Charcoal-Water-Filters-Replaces-Keurig/dp/B00HL2ZR2Q/ref=sr_1_6?ie=UTF8&qid=1417372516&sr=8-6&keywords=keurig+filter
Posted on Nov 30, 2014
Testimonial: "I think these particular Keurig filters are too small for the Breville machines, according to user reviews on the webpage."
  • Reify Nov 30, 2014
    These are the undersize lookalikes that don't fit, according to the user reviews on the webpage.
  • Reify Dec 29, 2014
    I finally found some reasonably priced third-party filters on Amazon that fit the Breville K-cup machines. The Amazon descriptions should list the physical dimensions of the filters, to prevent buying of undersized look-alike filters )I got a set of these, and can't use them).
What type/model/ brand of water filter do I need for the Whirlpool Roper side-by-side refrigerator with the model number: RS25AGXNQ00
There is a generic type of water filter that fits all Whirlpool and KitchenAid refrigerators with a water filter located in the base grill below the door.
it looks a bit like this: http://www.partselect.ca/11722132-2-M-Whirlpool-EDR5RXD1-Water-Filter.jpg
Here is one on amazon: Amazon com Replacement Roper RS25AGXNQ00 Refrigerator Water Filter...
Sep 05, 2016 | Whirlpool Refrigerators
Water presure or clogged up.
I don't have the same brand, but I had a similar problem. These machines depend on generating high pressure (bar) and clogging is a problem. One source of clog is calcium and minerals in the water. Even though you have and change the water filter, there will still be minerals in the water and it can result in clogging.
You should use a decalcifier periodically but for the problem you are having now, you most likely need to take the head apart and clean the mesh and parts. Make sure light comes through all the holes. Don't enlarge the holes. Just clear them. That is what did it for my unit. Hope that helps.
Mar 24, 2014 | Breville Barista Express
What type if filter do I for kitchenaid superba ksrb25fhss01?
The refrigerator water filter for the kitchenaid superba ksrb25fhss01 is part number 4396508. If you order it from Sears Parts Direct, it's $45. See: http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Refrigerator-Parts/Model-KSRB25FHSS01/0593/0165000/O2029608/00002 . It's available from other sources for less (including Amazon: http://www.amazon.com/Whirlpool-4396508-KitchenAid-Maytag-Refrigerator/dp/B0009793KC .)
I hope this helps.
Jun 24, 2012 | KitchenAid Refrigerators
Not pumping water through properly even though I have primed it.
Sounds like a pump issue.
Find your local service agent here http://www.breville.com.au/care_agentsearch.asp?type=replacement
Or call Breville in 1300139798 and speak to Customer Service.
May 25, 2010 | Breville BES400 Espresso Machine
I have a breville expresso maker. I can not figure out why the expresso is not coming out. The water and pressure go into the attached filter but it will not come out the spouts
I assume that the water is heating? If not the heater has gone and should be replaced.
If the water is heating, but is spilling over the filter, the seal has gone, these are cheap and not hard to replace.
If the pressure is escaping from the water filler, then the holes are blocked up. poke them free with a darning needle or similar.
Dec 29, 2009 | Breville Coffee Makers & Espresso Machines
We have a breville cappucino machine and where we put the coffee keeps clogging
my breville filter baskets only have one true hole in the center of each basket. there are stampings in the metal so it looks like there's more, but the others aren't really holes b/c they were never drilled out. maybe breville subcontracted the manufacture of the filter baskets out and then didn't qc them; either way, one hole means keeping it clear is much more important. i plan to drill mine out (if i can find a small enough drill bit!) otherwise, after brewing a shot run only water thru the basket each time, or clear the hole out with a pen or needle. good luck!
Sep 29, 2008 | Breville ESP8XL Espresso Machine
Pressure but no water
Make sure your filter is clean, take the filter and head it to light. If it is clean then you can see a little hole in the midle.
Aug 09, 2008 | Breville ESP8XL Espresso Machine
Breville ESP8XL Cafe Roma does not pump, or build up enough pressure to push the water through the coffee. Help.
Make sure the filter is clean, that in the holder and in the machine. If it is clean then i think your pump have to be replaced:-(
Jul 21, 2008 | Breville ESP8XL Espresso Machine
Coffee Makers & Espresso Machines Logo
101 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
