Question about Home
Fix a leaking shower
Nothing so far
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
If it's leaking all the time you will need to get the tap rubber washers replaced.
Posted on Nov 30, 2014
Testimonial: "The answer wasn,t quite what was expected,As what was required was a new Flow Cartridge, however many thanks for trying to solve my problem"
Leaking pipe behhind shower head
See if there is a wall behind your shower stall you will have to open up the wall to fix your plumbing repair and patch the wall
Nov 20, 2015 | Home
Water leaking below shower
You may have a very small access panel on the front of the shower pan or through an access point in a cabinet on the backside of the shower wall. I have seen the shower tail piece get cut too short and as a result is becomes disconnected from the "P" trap under the shower.
Apr 04, 2014 | Dutchmen 2010 Grand Junction 345RE
Leak
1.How did you attribute the leak to the shower?
2. where did the water drip etc show up?
Jul 13, 2013 | Home
Handheld Shower leaks where it connects to shower arm
pull rubber boot away and you should see a nut or connecting ring. you can use thread tape on the leaking threads for the nut or use a rubber gasket washer depending on the setup inside. if all else fails you can put duct tape along the leaking area make sure water is off and area is dry.
Sep 22, 2012 | Ace Hardware OAKBROOK COLLECTION DESIGNERS...
I have a Moen shower faucet that is six years old(copper sweated plumbing). My wife noticed water dripping profusely from the downstairs ceiling during my shower. The screws holding the face plate were...
Try removing the handle, then the face plate. With a flashlight handy, check inside the wall around the valve to see if you see any leaks. Then, try the valve by pulling the stem (may need a plier to grab this). Keep checking inside the wall. Next, try the shower, and again watch in the hole you have. You may find that the connection(s) to the valve is/are leaking, particularly at the top of the valve where the shower pipe heads up the wall. Or, it may be that the shower head's arm is leaking somewhere above. If you only see water dripping down from above, try the flashlight with a small make-up mirror to see if you can see where it's coming from. Sometimes the pressure in the shower head builds up from the flow restrictor, or the head's spray holes may need cleaning out (try soaking the head in a solution of CLR [stands for Calcium, Lime, Rust] available at most home improvement/ hardware stores). Sometimes the shower arm (the bent 1/2" diameter pipe that the shower head mounts to) isn't fastened in tightly enough. A good trick to help here is to wrap the threads with teflon tape, then apply teflon paste also. Wrap the tape clockwise around the threads so that it doesn't unwrap when you screw the pipe back into the fitting in the wall. Also, make sure the threads in the fitting in the wall are cleaned out, and don't let any debris contaminate the new teflon paste as you slip it back through the hole in the wall. If you find that the pipe out of the top of the valve is leaking, I recommend you call the plumber. He/she can likely fix it without taking the wall apart.
Aug 27, 2010 | Moen & One Handle Tub & Shower Faucet
Leaking form shower facet also leaking from
id say your tub spout or shower pipe is leaking and running down behind remove both and replace teflon tape see if it stops
Mar 14, 2010 | Home
My shower head leaks
for some reason the cartridge set up does a sporadic drip which is infuriating but replacing the insert will not fix it
after the cartridge there is just an empty hose to the shower head and no pressure
Nov 13, 2017 | Price Pfister R897EBK Brushed Nickel...
Water heater has hot water in it but cold water is still flowing
Nothing wrong with waterheater. Did you perhaps reverse hot/supply lines on new shut off valves?? try reversing lines. Maybe
Please rate. Thanks jj505
Mar 28, 2009 | Whirlpool Water Heaters
Shower handle leak
turn off main water in home . turn on tap some where in home to release presser take shower handle off (screw under cap) unscrew the tap with a wrench unscrew on insides you pull out replace washer put all back togethere
Feb 11, 2009 | American Standard 3275.505.099 Colony Soft...
Home Logo
48 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
