Why does my WDG 1095W fill with water when turned off
Don't know what to do
    Sergeant:
  • 455 Answers
Fill regulator is broken or the electronics that control water inlet valve need service.
Cheers,
Kelly
San Diego, CA
Posted on Nov 30, 2014
Testimonial: "Thank you so much for your help"
Purchased HPAC7Mportable AC used/ only slightly cool airblows out
i don't know this model but if its like mine then you may need to fill it up with water (ice water) and if theres a rotating wheel on it then make sure you have this turning, hope this helps, paul.
Jul 02, 2012 | Heating & Cooling
Dishlex Global 200 won't fill with water
Shut off the water to the dishwasher. Take the line off where it connect to the dishwasher. Get out a bucket (dishpan, etc.) and put the open line into the bucket, turn on the water. Does it have a good stream? If not the problem is in the supply coming from your house. If the stream is good, house water is fine. Connect the supply back up, find the electrical solenoid that the water feed goes to and disconnect the line on the other side of it. Try turning the dishwasher on with bucket catching water, when the solenoid clicks on is there a good stream of water? If not either solenoid is bad, or maybe there is a filter (screen) before the solenoid that needs cleaned. If there is a good stream after the solenoid, then the controls must be bad telling it to shut off too early.
Dec 25, 2011 | Dishwashers
The bleach dispenser keeps filling up with water (I am not using it) and I don't know how to empty it - and why is it filling up?
You have a leaking water valve that dispenses water into the bleach cup. You will need to replace the water valve to stop this problem.
Good luck
Jul 08, 2011 | LG WM2487H Front Load Washer
Water will fill but wont do anything else
Does the water turn off when filled? If so can hear a motor humming or running? If so you have power to the washer.
Can you turn the timer ahead manually a step at a time? Then if you don't hear the motor running the timer may not be working or sending signals to motor to start. . But If the motor starts a spin cycle then the timer is just not running itself probably dut to not getting power.
All this is difficult without the diagrams. There are so many interlocks and safety switches that you wont know about.
Jun 26, 2011 | Whirlpool Washing Machines
My washer is filling with water when i'm not using the machine. I read somewhere abot some wort of inlet vavle needing to be replaced?
Unplug the machine. If it still fills with water then mechanically the water valve has failed. If it don't fill while being unplugged then something in the control is doing it, might be the main control is bad. Who knows?
Affinity Service Manual
Jun 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
We had to turn off our water a couple of times this week and now the kenmore washing machine keeps filling with water when it is not in use. We also have a kenmore water softener don't know if this...
if the machine is filling on it's own you have to replace the water valve located on the back of the washer.when you shut off the water and turn it back on sediment in the pipes can get disturbed and flow into the valve,when the valve goes to fully close it can't because sediment is inside the valve and stopping it from fully closing,the only way to fix this is to replace the valve,you don't want to come home to a flooded out home because of the valve.whenever you write about your appliances send the model number so i can look up your model and give you the part number,when you go to your parts store,give them the model number off of the machine and they will sell you the correct part.
May 22, 2011 | Kenmore Washing Machines
I HAVE A vICKS VAPORSIOR AND HAVENT USED IT VERY OFTER THERES no STEAM COMMING OUT EVER I USE COLD WATER DON'T FILL ABOVE THE FILL LINE I ALSO CLEANED IT REALLY GOOD WITH CLOROX. aNY SUGGESTIONS???
The unit may simply has a calcium scale build up and it's blocking the water passage. To clean it, empty in water remaining in the tank. Mix a 50/50 solution of White Vinegar and Bottled Distilled Water and fill the tank. Allow it to soak for at least one hour, then turn the unit ON. Place you hand in front of the misting nozzle to see if it's working. If you don't feel any mist, turn the unit OFF and allow it sit over night. If you do feel mist, allow it to run until the tank is 3/4's empty Turn the unit OFF, pour out the remaining solution and refill with Bottled Distilled Water. Run the humidifier until it's empty. This will flush the system entirely. In the future, I would recommend you use Bottled Distilled Water, instead of Tap Water. If you do, you won't have to descale the unit any more.
Hope this helped you, please let me know. Thanks.
May 16, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
The wm does not accept cold water. I put it on cold cycle and it does not work the water line is fine... what could be the problem ?
Why has nobody mentioned the fact that if you “draw off” hot water using a tap beside the washing machine you can get “instant” hot water to your hot-fill. I have been doing this for years – now that all my hot water is heated by a crabon-neutral energy source (either wood or solar) I feel it is even more energy efficient.
As for water consumption, my house has a secondary return pipe on the hot water circuit with a temperature sensor fitted to the pump so that it only switches on when you turn a hot water tap on – you than turn the tap off, wait 5-10 minutes while the water circulates, then turn it on again, by which time the hot water only has ashort distance to travel and you don’t waster much down the drain.
However, I have been interested to read about the pros of cold fill only, especially the arguments about such a small volume of water being used anyway and the possibly improved wash performance? Also, I was dismayed to read that washing machines with hot and cold fill don’t use the hot wate very efficiently.
So would I be better off going for a hot and cold machine while they’re still available or going for a high-efficiency cold fill only machine? I am still minded to get an LG with hot and cold fill… comments please?
Dec 04, 2009 | Washing Machines
WATER FILL LEVEL
Every cycle has its own water measurements for example: Heavy Wash : 7.2 gal. so check the manual for further information. And don?t worry there is an Overfill Protector, so you won?t do any damage. Good luck
Apr 01, 2006 | Frigidaire 25 in. FDP750RC Free-standing...
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
