Question about Car Audio & Video
I have bought a wireless veyron v link mirror box and have wired it to a sony xav602bt doubke din stereo unit it runs on aux 1 but I have no sound coming through do I need to put a seperate earth cable from the back of the stereo unit so aux 1 will play sound out please help
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 112 Answers
It shouldn't need any wiring it works wireless .
Posted on Nov 30, 2014
  • Matthew Less Nov 30, 2014
    If you use the standard mirror link on the stereo you have to use drivelink which is shockingly poor and it has to be hard wired
    I want it full wireless with full mirror link
    Just need to find out about the rca audio
TRocky
  • 4 Answers
SOURCE: i have a pioneer DEH-P3000
Hi nhmteam. I have the solution for you: 1. With your DEH-P3000 turned off, press your FUNCtion button. It's a tiny button towards the upper right of the faceplate. Hold it down until you "ALARM OFF" or "ALARM ON" on the display. Release the button. 2. Press the FUNCtion button again and you should see another feature. I don't remember how many features you need to cycle through, but keep releasing and pressing the FUNCtion button until you see "M-CD ON" on the display. If you miss it just keep going and eventually it will come back. 3. On the right side of your faceplate there is a button with 4 arrows. You will need to push the up or down arrow until the display reads "M-CD OFF". If your display already reads "M-CD OFF", kip to the next step. 4. Press and release the FUNCtion button again and you should see "AUX OFF" on the display. Again press the up or down arrow until the display reads "AUX ON". 5. Now, turn on your unit, then press the INPUT button until the display reads "AUX". You are now ready to use your iPod in the way you always did. Keep these instructions for the future since I believe every time you disconnect the unit from the battery the unit will reset itself and disable your iPod cord. Best regards - TomR
Posted on Sep 23, 2007
techman
  • 3130 Answers
SOURCE: 1998 ford el xr6, need stereo wiring harness colours
You did not specify if you wanted the wiring diagram for the Expedition or the Explorer, so I got you both. Good Luck
1998 Ford Expedition Stereo Wiring
Constant 12V+ White/Purple Switched 12V+ Black/Pink Ground Black/Green Illumination Blue/Black Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Light Blue/White Left Front (-) Orange/Light Green Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 6" x 8" Rear Doors Left Rear (+) Tan/Yellow Left Rear (-) Gray/Light Blue Right Rear (+) Brown/Pink Right Rear (-) Orange/Red
1998 Ford Explorer Stereo Wiring Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Door Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
Posted on Feb 23, 2008
SOURCE: Panasonic CQ-VD5505W dbl-Din dvd 7'' touch screen CAR AUDIO
i got the same problem and i ground the green/white to the case of the unit. do i have to ground it to the chassis?
Posted on Apr 04, 2008
SOURCE: Car stereo installation
I had this problem as well. On my harness was a wire for connecting the factory amp. You have to connect the Automatic Antenna wire to the Factory Amp Turn On wire. Should be a blue wire to a blue wire with a white stripe.
Posted on Apr 14, 2008
SOURCE: Can;t play my Ipod through Kenwood KDC 237
i was just having this same problem but i pressed standby and menu and scrolled up till i got to a AUH which is off all i did was turn it on and press standby again and my ipod started playing
Posted on Jul 06, 2009
Do you know were I can get a wiring harness for DDA 650W VALOR car stereo
no wiring diagrams found
only this
Features:
6.5" Double Din Size Fully Motorized IN-Dash Monitor w/DVD;
2 DIN;
16:9 Wide Screen;
Compatible with DVD/VCD/CD/MP-3/CD-R/CD-RW;
"True All-In-One" (no separate brain);
Built-in DVD;
AM/FM radio tuner;
Wireless remote;
3 video inputs;
1 aux input;
2 video outputs;
Front and rear audio outputs;
Subwoofer output with adjustable crossover;
Center channel output;
Reverse signal input for camera;
Dual zone playback function;
AC-3, Dolby Prologic II;
Dolby digital surround (5.1CH) audio output;
PAL/NTSC compatible;
DVD/CD changer interface;
5 x 45 watts;
Oct 23, 2016 | Cars & Trucks
Does din for car steros matter if prop mounting equip is purch?
a normal car stereo is 1 din and then 1.5 din is about 1 inch taller they shouldhave what you are looking for at a car stereo dealer
Jul 14, 2009 | Sony 52W x 4 Satellite Radio/Apple iPod...
Car Door Speakers wont work after installing new Stereo
check you Fade and Balance,sometime the ground is used for two speakers sometimes a ground is used more then once will cause your problem ........Good luck......
May 14, 2009 | 1998 Ford Explorer
Connecting to the AUX input. Hard and software
you are connecting a cd PLAYER to an AMPLIFIER of some sort?
The rear connecters are audio/video out (red/white audio L/R and yellow is video) i assume rca connectors (phono)
The sound should be on for those connectors all the time, so no need to switch to audio out.
You connect to Aux in on the amp. and select Aux on that (amp meaning amplifier or stereo unit with aux in)
I hope this helps.
May 09, 2009 | Kenwood KDC-W5534U CD Player
I just bought the dual headrest from walmart and can not get the sound to work the passenger side. can anyone help me with this?or possibly tell me how to get the sound through the stereo.
The monitor only headrest does not have audio handling circuitry in it. the wire harness for that side is the one with the red and black wire, and the two video inputs, not the harness with the red and black wire and the three RCA jacks. It will function on the wrong harness, but it is not the correct one.
The DVD headrest has two harnesses. One of them is for power and output, the other is for input only from another source. The harness with the red and black wire has the three RCA outputs... the video lead goes to the other headrest, and the audio can be fed to an aux input on a stereo or amplifier. The input harness is designed to be Video 2 input from either a gaming system (a Game Cube is a nice option), or another DVD or video source (hand held video device such as iPod or Smart Phone like a HTC Touch Pro 2).
To get sound out of the stereo, either run the audio output from the headrest to the aux input on your stereo, or cycle the FM transmit options using the FMTX button on the DVD player unit to a station you can tune to on your car's FM radio.
Apr 26, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
CDM 150 IPOD question
OK all you need is a 1/8 th inch stereo jack that goes out into two RCA cables RED and White (you can get this conector at any radio shack) now plug the red and white wires into the back of your gem sound unit AUX or TAPE..plug in your mp3 through headphone jack into 1/8 in plug....now turn on set switch to AUX OR TAPE DEPENDING on the one you plug into ..now play your mp3...make sure volume is up!
This should fix YA!
Dec 12, 2008 | Gem Sound CDM-150 Mixer
J-link hook up
My Jensen TV/DVD unit came with a media box as well as the head unit. The media box was the interface where my iPod and XM antenna plug in, and everything is routed via a DIN cable from the media box to the head unit. I'd think you're missing that extra module that allows all the auxiliary hookups.
Jul 21, 2008 | Jensen VM9510 Car DVD Player
Wiring with a sattelite receiver and new Samsung TV
Nope RamaTheMan - you are incorrect! No way to get an actual surroundsound from your TV on this turd - this came straight from the Samsung FAQ -
"You cannot get surround sound from your television. On the other hand, if your television has audio output jacks you can connect your TV or Set Top Box to your Home Theater System and get stereo sound (that is, sound from the left and right speakers of your Home Theater System only).
To connect your TV or STB audio output jacks to your Home Theater System and get stereo sound, follow these steps:
  1. Turn off your TV and Home Theater System.
  2. Connect the Audio Out jacks on your TV to the External Audio Input jacks on the back of your Home Theater System. The External Audio Input connectors are typically labeled AUX IN. Note: There are usually two pairs of Audio Input jacks, AUX 1 and AUX 2. Each pair has a jack for the left audio input and the right audio input. Often, there are two Video AUX IN jacks as well. You can plug the audio cables into either audio AUX 1 or AUX 2. See the following diagram.
  1. Turn on your TV and Home Theater System.
  2. Press the Function Button on the front panel of your Home Theater System until the display on your Home Theater System shows AUX 1 or AUX 2.
For advanced installation, if you are using a High Def STB, you can connect an OPTICAL connection from the STB to the HTS. This is a specified cable that must be purchased separately.
In either instance, you must then set the HTS to its auxiliary input. (i.e AUX 1, AUX 2, DIGITAL IN) in order to get the sound from the HTS.
Note: If your television does not have Audio Out jacks, you may be able to get stereo sound by attaching the Audio Out jacks on your VCR to either the AUX 1 or AUX 2 audio inputs on your Home Theater System. If you attach your VCR to AUX 1 or AUX 2, you will have to tune your television to channel 3 or 4, and then tune to the station you want to watch on your VCR."
Dec 26, 2007 | Samsung HT-X50 System
Car Audio & Video Logo
158 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
