Question about Tefal ActiFry Deep Fryer
My actifry doesn't work, there's power going to it as the timer still works but it doesn't turn on at all. Any suggestions on how to get it working please??
Don't know what to try!
Actifry kept stopping so changed the motor that drives it
Contact Actifry and tell them your problem you should find them very helpful as I did & it doesn't matter what age it is.
Trust this helps
ddmc
Jan 10, 2014 | Tefal Actifry Family Ah900015 Low Fat...
I have a tefal family actifry and a green error flashed up and a long alarm. What is this telling me?
Tefal Actifry GH800215 user manuals GH800215
www.tefal.com/instructions.../Fryer/Actifry/Actifry.../1500634805
TefalThe Actifry Plus GH800015, GH800215 deep fryer allows you to make 1.2 kg of chips with only 1 ... To display Instructions & Manual, choose your language :.
Apr 13, 2013 | Tefal ActiFry Deep Fryer
Timer works & oven works but microwave doesn't go on
Most often this is a bad door switch or door switch mount.
See my help file on door switches here.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Mar 19, 2013 | Microwave Ovens
I have a 96 Cavalier and my passenger side low beam does not turn on (high beams OK) & my horn doesn't work either. I've replaced the bulb with no luck. Any suggestions?
The light socket itself could be bad. If you turn on the lights and put a meter on it you can verify there is power at the socket. If not you still have to trouble shoot some more. No power at socket could be wiring that went bad or melted but you will have to remove the socket and test the wires themselves. No power at the wire bare ends you have to go back to the fuse distribution and check that. Low voltage sucks for this very reason. good luck.
Nov 12, 2012 | 1996 Chevrolet Cavalier
I bought a new tefal actifry family Ah9000 and when open the box and connect it to power then pressed on/off button nothing happened. Just a green screen with hardly to see sun shape on the left side
Use the timer. Unlike the Actifry and Actifry Plus models, the timer on the Actifry Family controls the fryer, and turns it off at the end of the cooking time.
Jul 20, 2012 | Tefal ActiFry Deep Fryer
I installed a new Intermatic 200w powerpack with 15 malibu lights using 131 watts. The lights turn on manually, but the timer doesn't work. How is this possible.
More information is needed.
Open following link for Intermatic-Malibu resources:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
You say clock doesn't work.
Add a comment with following information:
Do you have timer with analog dial?
Does dial rotate as time passes?
Does dial keep good time?
Have you put the black and red trippers in place?
Are trippers push all the way down?
Have you set current time by rotating clock dial 2 full turns before rotating dial to current time?
Intermatic/Malibu ML series timers come with 5-year warranty.
Product is covered by warranty.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 01, 2011 | Malibu ML200RT - Low Voltage Power Pack...
We are trying to replace the belt on the bissell 89q9 model. We purchased belt 8 and got in onto the brush however the brush doesn't spin anymore. Even trying to turn it by hand doesn't work. One...
Remove the beater brush assy & remove the
shaft & brgs that go through it 7 clean out the
hair,fuss ect,so it will turn
You need to take your vacuum apart once a year or more
to clean things so they continue to work
May 22, 2011 | Vacuums
Sanyo television doesn't turn off either by using the remote or by turning it off at the tv.All other fuctions work using the remote or directly on the set.Even using the sleep timer doesn't turn...
Unplug the set and hold the power button for 30 seconds. Plug it back in and see if that fixes it. If it doesn't then it sounds like there is a problem on the board underneath the power button. Something isn't allowing the circuit to be cut.
May 05, 2011 | Televison & Video
I have GE Model #15089 digital timer. I want to reset time to come on to 7:30 pm and turn off at 10:30 pm. It was previously coming on at 6:00 pm and off at 10:30 pm and working fine but when I tried...
The problem with answering questions where somebody cannot program a timer, or programming stopped working, is that expert doesn't know if timer is defective, or needs to be reset, or timer has conflicting programming, or if person has mis-read the instruction manual, or if wrong button sequence is being used, or if internal battery has gone bad, or if circuit has interference or loose wiring, or if light bulb burned out, and however expert guesses, the person asking question is unhappy because the timer still doesn't work and/or the manual still doesn't make sense.
I work with timers every day and suggest the following steps to get started:
Reset timer and try setting program again.
Write out steps in manual at point where timer doesn't seem to work.
Double-check that you are pushing correct buttons all the way down.
Make sure same days of operation are selected for ON and for OFF. For example if ON is set for all days, and OFF is set for Tuesday, then timer will not work as expected.
Reset timer and make sure there are no conflicting or overlapping programs, or timer will not work as expected.
Test outlet with cheap circuit analyzer from home center, try timer on different outlet, try timer on different Load, check that Load works when plugged into outlet without the timer.
Save some headaches listed above, and buy another 15089 at Home Depot and return defective one in new package.
http://waterheatertimer.org/GE-timers-and-manuals.html#15079
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
Add a comment for more free help
Also take advantage of fixya expert assistance live.
Apr 25, 2011 | Hardware & Accessories
Leviton Programmable Timer 6124H-W installation problem
I Have a decora 24 hour lcd programmable timer switch 6124, when i set the timer it doesn't go on, but it goes one a 5:00 am. when there is nothing programed?
Apparently i need to set the time first and then program timer?
Can you please help. Thanks so much.
Apr 20, 2009 | Leviton 6124H 24 Hour LCD Programmable...
Tefal ActiFry Deep Fryer Logo
135 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Gerry Harvey
Gerry Harvey
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
