How do i connect the porta sound 2000 wireless headset to the television?
I tried to connect porta sound at the audio out at the back of the TV
We have several pairs of "R1H-11210" wireless headsets that can connect to our TV in our van. we try connecting the headsets, theirs no audio that comes out of it?
Several things come to mind:
* check the batteries in the headsets, are they good?
* check that the transmitter is powered up and connected to the audio circuit in the TV.
Jul 09, 2015 | Radio Communications
Polaroid TV – Model # 02611C FR8G-1188-1206 was working find, picture and audio, then I plugged a Radio Shack wireless headset in and it turned the audio off. I unplugged the headset, restarted the tv,...
Good day!!!!
There's a possibility that the sound board got faulty after you plug the headset..But before we decide to replaced the sound board lets make some observation and initial repair..
Lets see the screen of your TV having headset icon,,if have try to power off your TV and find the headset female connector on your TV then blow air on the connector using compressor or if you don't have compressor the human air blow is enough..
And also I want you to try other ordinary headset with a very low volume of TV to avoid damage of headset..If you hear sounds of headset the sound board is good..
Try those procedure and let me know the info..
Just keep on touch to me and I will do my best to help you because that is my primary goal here in fixya,to help people like you..
Regards
bugoy31
Bonifacio Gomez
Jan 16, 2012 | Polaroid Televison & Video
I do not have a credit card. I have connected my wireless headset to the TVs audio out on the back and it works great. My problem is I can not mute the TV speakers, so the sound is comming from both...
Try just turning the volume down on the TV. The audio power to the red/white output jacks should be the same at any TV volume since it is expecting you to control the volume with an audio receiver or other amplifier.
Good luck.
Please rate me
Mark
May 05, 2011 | Curtis-Mathis Televison & Video
Lg 42LH30 tv trying to connect a Sennheiser w/l RS120 wireless headset and I do not see an audio out connection on the back of the tv I looked up the specs of the tv and the only audio out I see is...
This is an optical digital audio output that uses optical fiber with Toslink optical connectors at both ends, from there it comes the name, since your wireless headset has only analog audio input, you'll need an optical digital audio to analog audio converter, to connect your wireless headset to your TV.
Mar 18, 2011 | LG 42LG30 42 in. LCD HDTV
I own a TV-set 42LG2000 that has no headphones socket! there are many input and output systems on the back (2AV's 2 HDMI's ...) How can I get a system to channel the sound only to my ears?
Hello, you need to use wireless headphones, which are supposed to be connected into the audio output left and right. Often sell the headset has been with the appropriate connections to all TVs. Anyway you should tell the seller the type of audio output connection on your TV there. I hope that was helpful!
Let me know if you need further guidance
Feb 26, 2011 | Televison & Video
Does the Microsoft LifeChat LX-2000 Headset work on the ps3
Yes, every head set is capable of receiving audio sounds only require the type of connectivty. For example, the headset may require pin connection so long as the device PS3 has audio outlet. Also, wireless headsets that communicate by wii fii would require powering on the wireless signal acquirer. Thereafter each device should ascertain signal transfer. usually, the PS3 would require powering on any wii fii accessibilty buttons to search an acquire wireless signals in this situation audio.
Jan 12, 2011 | Microsoft LIFECHAT LX-2000 RETAIL Headset
Audio from tv is not restored by turning off power on headphones
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections.. your current “work around” is your only solution.
Best of luck
Dec 31, 2008 | Sennheiser RS 120 Consumer Headphones
Connect head set to sharp lc-26d43u tv
The audio out from those jacks requir amplification and will not drive a head set. Get an inexpensive stereo receiver and run the audio out of your TV to the receiver and use the receiver for your headset.
Jun 29, 2008 | Sharp LC-26D43U Television
No sound from TV to headset
I suspect that your TV audio output is digital and your wireless headset amp is analog..........the two won't work together.
Dec 10, 2007 | Recoton Advent Radio Communications
235 people viewed this question
 Grubhead
Grubhead
