Question about Hardware & Accessories
UNABLE TO GET AUTO POWER ON AND OFF TO WORK PROPERLY
HAVE SET IT TO COME ON AND THEN GO OFF FOR 1 HOUR AND ALSO 2 HOURS WITH NO PROBLEMS. HOWEVER WHEN I PROGRAMME IT TO COME ON AT SAY 0900 AND GO OFF AT 2100 IT WILL GO OFF BUT THEN APPEARS TO TURN ITSELF ON AGAIN DURING THE NIGHT AS IT IS ALWAYS ON FIRST THING IN THE MORNING i.e. PRIOR TO 0900. CAN YOU HELP PLEASE? THANK YOU, DAVID HENNELL
    Scholar:
  • 149 Answers
David, did you wire this unit in yourself and do you still have the installation manual with the wiring diagram?
This can be caused by the wire[s] controlling the 'Advance'
function[s] and the wire[s] controlling the 'Override' function[s] being incorrectly connected. Check the wiring diagram for details.
Posted on Nov 30, 2014
  • 16 Answers
SOURCE: resetting outdoor light timer
I would unplug the timer. Change the setting to 6 hours then plug back in.
Posted on Jan 12, 2009
SOURCE: where to find intermediate gear -about 1/2 " in diameter.
The following is a link to the only site I have seen that sells just the gears for the Intermatic timer clock motors. I took my clock motor apart and this was the gear that was bad. The first link is to the site and the second link is to the picture of the gears to make sure it is what you are looking for. http://www.stuartsinger.com/ballclock.htm#Replacement Parts
Picture of gears: http://www.stuartsinger.com/Ball%20Clock%20Web/Ball%20Clock%20Pics/Gears.jpg
Hope this helps, Chuck
Posted on Oct 27, 2009
SOURCE: I bought a westek daily
Your question is a bit hard to understand.
You have a plug-in timer.
It's connected to a space heater.
The timer powers ON correctly.
But for some reason the heater does not turn ON?
I think you should check the wattage of your space heater and compare it to the wattage of your timer.
A lot of plug-in timers are pushed to the limit at 1000Watts
Your space heater is 1200W or 1500Watts probably.
Buy an appliance timer to handle the space heater load.
Intermatic HB113C timer handles 2000Watts
It will be safe.
Set two on-off functions per day
http://www.smarthome.com/25071/Intermatic-HB113C-120V-Heavy-Duty-Mechanical-Appliance-Timer/p.aspx
Posted on Nov 09, 2010
SOURCE: Clock is set properly.
I answer questions for free.
I know timers and electrical devices, and have tested most of the brands.
You posted under the Woods 7-day timer 59018 or 59028.
Here is the manual:
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
There are several programmable timers today that look like Woods, and each brand has different programming.
If you do not have Woods, add a comment and I will walk through programming your brand
1) You have the clock set correctly which implies the wiring is correct. Good job!
2) Programming review:
Each program requires ON time to be set, and then OFF time to be set
For example you set Program1 ON 5:00PM for ALL days.
And then you set Program1 OFF 11PM for ALL days.
3) Programming steps:
Press PROG button until Timer 1 ON appears on display
Use Hour button to set 5 PM
Use MIN button to set :00
Default selects ALL days
(If you want other days, press DAY button until display shows correct block of days)
Press PROG button again to save Program1 ON
4) Now for Program1 OFF
5) To set Program1 Off
Press PROG button until Timer 1 OFF shows in display.
Use Hour button to set 11 PM
Press PROG button again to save Program1 OFF
6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time.
If you want to set another program, press PROG button until Timer 2 ON displays
7) After setting programs, press Clock button so current time shows.
8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
If you need more assistance, add a comment.
If instructions help, give it a 4-thumb
Posted on Nov 11, 2010
SOURCE: My timer is set on auto-from dusk to dawn. Comes
You posted under Intermatic ST01C battery operated timer.
Battery operated timers cannot be exposed to freezing temperatures.
Answer below fits ST01C timer, and other similar timers.
If timer worked at one time, then timer is installed correctly. This is true for all timers.
Most in-wall timers have 1 year limited warranty.
ST01C uses CR2 battery that needs to be replaced periodically.
ST01C manual says to reset timer as last-step troubleshoot.
Programming must be entered again afterwards.
Open following link for ez programming steps and battery info.
http://waterheatertimer.org/ST01C-program.html
If you are having a problem, then buy Utilitec LW60419-0192773 at Lowes.
You can install yourself using information on following link:
Utilitec does not have battery and can be exposed to cold.
http://waterheatertimer.org/Program-wire-Utilitec-LW60419.html
Another dawn-dusk Timer is Honeywell Aube T1033
http://waterheatertimer.org/Aube-timers.html
Aube is also battery operated like ST01C and it cannot be exposed to freezing temperatures.
Sylvania SA170 offers ez-set zip code feature for dawn-dusk operation.
Sylvania does not have a battery
http://waterheatertimer.org/Sylvania-timers-and-manuals.html#SA170
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 22, 2011
Magellan roadmate 2036 how to set my local time
1. From the
Main Menu screen, tap the Settings icon .
2. Tap
System.
Setting Languages
1. Access the
System Settings menu (above).
2. Tap
Languages.
3. Tap on the desired language.
4. Tap the back arrow .
5. The Magellan RoadMate receiver will reboot if you change the language.
Setting Auto Power
Auto power is the duration of time that the Magellan RoadMate receiver remains idle before turning off
automatically.
1. Access the
2. Tap
Auto Power.
3. Tap on the desired duration.
Setting Brightness
1. Access the
2. Tap
Brightness.
3. Tap in the brightness slider to set the brightness of the display.
The
Dim on Battery Power option will prolong battery life by dimming the display while using internal battery
power. Check to turn this option on.
Setting the Time Format
1. Access the
2. Tap
Time Format.
3. Tap on 24 Hours or 12 hours with am/pm.
Selecting the Time Zone (daylight savings on/off)
1. Access the
2. Tap
Time Zone.
3. Check Auto Time Zone or select your time zone from one of the cities in the list.
Jun 27, 2011 | Magellan 2036 GPS Receiver
I have an i-connex ipod docking station model 583258 with clock/alarm and radio but I have been unable to set the clock as I have mislaid the instructions. I am usually pretty good at working these things...
1. Fit the DC power and switch on the appliance by pressing the standby button 2. To set time, press CLOCk button to alternate between 12 and 24 hour format. 3. Press and hold CLOCK button until the set hour flashes on display 4. Adjust time using SKIP/SEARCH 5. Press CLOCK to set the time, same procedure for minute
To set alarm
1. Press AL SET 1/OFF 1 button, then press and hold the same button until the alarm time starts flashing 2. Press SKIP/SEARCH to to set time as above
Jan 17, 2011 | Audio Players & Recorders
How to set on/off time?
Aube T1032 is 500W 7-day timer with full range programming
Aube T1034 is 500W 7-day Sunrise/sunset timer
Aube T1070 is 500W 7-day timer that turns lights ON at sunset and OFF at programmed time later in evening, say 11:00 pm
1) T1032 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI032.pdf
b1129f1.jpgAube T1032 buttons
Switch must be wire for display to show
Move slide switch to ON
Open door to see buttons
Set clock with present hour minute and day
Choose 12 hour or 24 hour format
Review operating mode : Auto for programs to run
Make a chart of your on-off schedule so there are no overlaps and conflicts when programming
Press PGN button
Display shows ON P #1 >>> this means you are setting ON time for program 1
Set hour minute day for ON time for program 1
Display shows OFF P #1 >>> this means you are setting OFF time for program 1
Each program 1-7 has ON time and OFF time plus day of operation
2) T1034 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI034.pdf
Timer must be wired for display to show
Open small door
Review buttons
Review operating mode: Auto if you want timer to turn on-and-off with sunrise sunset
Set the clock with present time / Choose 12 hour or 24 hour format
Use Hour button to set hour MIN button to set minute
Use CODE button to set daylight savings time
Set Sunrise-sunset parameters using tables that show in manual
Make a chart of programs
Set programs 1 thru 7
The above steps are 4 EZ steps for painting the Mona Lisa >>> please re-post question with detailed question
T1070 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI070.pdf
You select mode
Pick your city's coordinates from chart so timer knows when sun goes down
Make a chart of the times you want timer to follow
Select program number
Set days you want that program to work
Set time for that program to turn off lights
Oct 11, 2010 | Aube Technologies Aube 7-Day 40-500w Light...
Unable to set time and date on Sumsung t301g Tracfone
I had the same problem. I had the phone on when I called to set up initial service. After activation I left it on (it was charging) and tried to set time and date but couldn't get anywhere. Finally, I turned it off (hold "pwr / end" button till it turns off). When I turned it back on I got a message that time and date were now automatically set. This was about an hour and a half after intial phone call. Don't know if that wait time had anything to do with it.
Jan 02, 2010 | Cell Phones
After about 1 hour the picture begins to flash and set powers off
There's a possibility your power supply isn't working properly, if it was your ballast the one causing it to turn off, you would hear a clicking sound, and i doubt it's your lamp since you do get an image, i recommend you go todiscountdashmerchantdotcom so you can get a detailed troubleshoot this way you can make a decision on which part you do need to fix this situation
Jul 01, 2009 | Panasonic Televison & Video
Work for some hours and auto & power off
What you are waiting for there can be two types of problems:-
1. the firmware or S/w gets corrupted or you need upgradation or reformating and installing of the mobile o.s again or also you can try by resetting your phone to factory settings.
But these type of problem is very rare.
2. the most possible cause is the failure of your battery. I have the same problem and when i replaced the battery the phone is working properly
Jun 17, 2009 | Nokia 2300 Cellular Phone
Cuisinart DCC2000/how to set it to keep coffee warm for 4 hrs
From my Cuisinart DCC-2000 Series Manual: The AUTO OFF feature is used to shut off the coffeemaker at a preset time, anywhere from 0 to 4 hours.
To program the Variable AUTO OFF:
1. Turn the function knob to "Auto Off". Press and hold the "Hour" button for 2 seconds. The clock display will start blinking.
2. Program the coffeemaker to shut off from zero to four hours after brew cycle is finished by using the "Hour" and "Minute" buttons (see "TO SET THE TIME").
TO SET THE TIME:
1. Turn the function knob to "Clock".
a. SET HOUR: Press and hold the "Hour" button to scroll through numbers quickly. When number displayed approaches the desired setting, press and release (pulse) the button to advance one digit at a time. After setting the correct hour, the default will be the last time set unless power is shut off.
NOTE: When the number count passes 12, the PM light will be displayed on the LCD.
b. SET MINUTES: Press and hold the "Minute" button to scroll through numbers quickly. When number displayed approaches the disired setting, press and release (pulse) the button to advance one digit at a time. After setting the correct minute, the default will be the last time set unless power is shut off. To finish setting time, turn the FUNCTION KNOB to any other setting or simply wait until the numerals stop blinking.
(P.S. The picture of the coffeemaker shown above on this page is not the correct model I have as a DCC-2000. The picture shown has a coffee pot. The DCC2000 has a coffee reservoir and a dispensing lever for dispensing coffee into mug or cup.)
Jun 13, 2009 | Cuisinart Coffeemakers
How to set the auto off??
I had same problem. Could not find manual on-line so I tried different techniques. You can reset the auto-off feature to extend the "On" time up to 3 hours max. You do it by (1) placing the control switch in the "Off" position. (2) Simultaneously push the "Hr" and "Min" buttons. The time display will start flashing the hold time. (3) Push the "Hr" button to cycle through the available hold times, 1 - 2  or 3 hours. When set, turn the selector switch momentarily to any other position to finish the programing.
Apr 25, 2009 | Krups Crystal Arome Plus Time 467 Coffee...
Coffee brews and then immediately shuts off Cuisinart DCC-1200
To program the Variable Auto Off: 1. Turn the FUNCTION KNOB to the ?Auto Off? position. Press and hold the ?Hour? button for 2 seconds. The clock display will start blinking. 2. Program the coffeemaker to shut off from zero to four hours after brew cycle is finished by using the ?Hour? and ?Minute? push-buttons. (see ?To set the time?)
May 20, 2007 | Cuisinart DCC-1200 Coffee Maker
Connection Problems
If you have other Optical Drive in your computer like a CDwriter then installed it where that LG 52x CDROM drive. Observe if the same problem occur after 2 or 3 hours. Try connecting the CDROM drive to the IDE ports (Secondary IDE port) like setting its jumper to Master. Ensure that the connection to its power supply is firm. Change the setting of your POWER OPTIONS which is under the CONTROL PANEL and change the setting for TURN-OFF HARD DISK to NEVER.
Apr 08, 2007 | LG (GCR-8523BB) Internal 52x CD-ROM Drive
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
