Hi. My floureon CCTV system was working fine till a few.days ago when the box started to make a whirring and knocking sound. It seems like its coming from the hard drive but I am not certain. All I can get on screen now is the Floureon logo. Grateful for your help. Mick Randall
Sounds like the hard drive has died how old is it they get quite warm and there on 24 7 so they generally have short life spans .
FYI the Flouron factory went bust a few months ago. The hardware is cheap and nasty. Your problem however seems to be the HDD or the HDD cable. I would replace the HDD cable first and if no luck change the HDD. If your DVR is stuck on the startup screen you can unplug the HDD to see if it will boot up. If it does then you know its getting stuck on the HDD.
SOURCE: Hard drive not being recognised by laptop
double check the cable.
drive get the power and spin too there is a problem with the Cable.
SOURCE: WD Passport Hard Drive Malfunction
Unfortunately, you have probably lost all the files on the drive. It may be possible to take it to a PC Repair shop and have them run specialist software on it, although the clicking sound indicates a hardware failure, rather than software. You have my deepest apologies, but this does happen... although rarely.
SOURCE: Western Digital hard drive problem
Ok. I have a WD 500 and I have ran into similar problems. First, shut your computer down. Unplug the hard drives USB cable and the power cable. Wait for about 2 minutes. Plug the USB cable into the computer, plug the power cord in...wait for 30-45 seconds and then start your computer. That hopefully should solve your issues.
SOURCE: Maxtor Basics 1Tb external hard drive not working
Apri il prompt dei comandi e digita cd.. e premi enter tante volte quante servono per andare in C:> ; ora digita CHKDSK X: \F dove X: dovrai sostituirlo con la lettera assegnata all'HD in cui non riesci ad entrare, premi enter. In poco tempo corregge gli errori, non si sa (almeno io) come si sono formati, e tornerai a riveder le stelle! Te lko auguro ame ha funzionato
SOURCE: Simpletech 500 GB Hard Drive not working
The red light is an indicator of drive failure. The fall it took, especially if the drive was on at the time, could easily cause the drive to break something internally so that it will not function. I found SimpleTech drives to fail pretty easily, even when you're not dropping them. That's been my experience, anyway.
Data recovery is a very expensive proposition. If the hard drive doesn't respond to the interface as normal, they have to be pulled apart and data extracted from the internal platters. This isn't something you can do without a full safe room (dust-free, wearing special suits and all) because any dust can ruin the platter. Since it's so involved, it's usually really, really expensive. Generally, most people don't bother when it reaches that point unless it's business files (like all of your financial data, for instance).
However, if it's something you really need that bad, DriveSavers is one of the best:
http://www.drivesaversdatarecovery.com/
