New washer- WTW5000DW0 / C43742143 clothes not spinning
Spin cycle seems to not be working as clothes are dripping wet after a cycle completes.
    Problem Solver:
  • 5 Answers
Are the clothes very very wet ? is the machine emptying properly? you could check that the pump isn't blocked or partially jambed I'd start at the pump first, barring that it could be the main program controler
Posted on Nov 30, 2014
aborcass
  • 2651 Answers
SOURCE: washing machine works, but wont do spin cycle- clothes sopping wet but clean
first off check to make sure its spinning at all. although the waters draining is it really spinning? are the clothes stuck to the side walls as if they had??if so i would tip machine back and look on floor and around the inside of cabinet approx 12 in. from ground level looking for oil,( transmission oil) . if present youll need a new transmission and clutch assy
Posted on Mar 04, 2008
  • 351 Answers
SOURCE: Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Posted on Mar 08, 2008
  • 68 Answers
SOURCE: Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Posted on Jan 17, 2009
  • 100 Answers
SOURCE: dripping wet clothes
will be an UNBalanced load, maybe there was not enough clothes in the load so in that case the drum would not be able to distribute the load evenly so gave up on the spin, hence wet stuff!
Posted on Jan 28, 2009
Just_Bobz
  • 448 Answers
SOURCE: spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Posted on Feb 21, 2009
WSM2480 Clothes Still Wet After Slow Spin Cycle
It's possible that the tub didn't drain properly in the allotted time and the remaining water is slowing your drum from coming to maximum extraction speed.
Jan 10, 2014 | GE WSM2420D Unitized Spacemaker Washer /...
Clothes too damp after spin cycle
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Washing Machines
Clothes are too wet when finished washing. water drips from clothes.The spin cycle seems to be spinning as the clothes are against the outside wall of the tub. we have the extra spin cycle used aslo and it...
Transmission is bad. Buy new washer. Best brands are (Kenmore, Whirlpool, Maytag).
Thanks and Please Rate me! Tips provided by www.HoustonRefrigeratorRepair.com Brian Gillespie (GOFAR Services, LLC)
Aug 26, 2011 | GE WPRE6150HWT
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Jun 10, 2010 | Maytag LAT3600A Top Load Washer
Clothes are still soaking wet after spin cycle
But is the washer empty, if there is still some water in it, there could be something in the drain line,
if all the water is gone, then it sounds like the washer is not reaching the full speed of the spin cycle.
Unless someone can remove the drain line and check the pump, and check the clutch of the machine,
I am sorry to say you should call an appliance person and have them make a service call.
If you where to post the model # of the washer, someone could look at the manual of it and see
how the washer works and what the pump is. I hope it is a simple fix for you.
Mar 21, 2009 | Washing Machines
Spin cycle leaves clothes very wet
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Feb 09, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Jan 17, 2009 | LG WM1814CW Front Load Washer
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Washing Machines Logo
648 people viewed this question
Top Washing Machines Experts
