I keep getting " No Signal" with any input selection on the tv remote.
Additional comments to Kellie Mullen's previous description. Hopefully helpful.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 112 Answers
What are you connecting to tv have you got something that works on another tv in the house so you sure your source is reliable.
Posted on Nov 30, 2014
Testimonial: "I forgot my new tv has a built in dvd player. I was still using the old dvd box with connecting VCR,"
Why is (channel) scan option greyed out?
Often this happens when the input on the TV is not set to TV. Look for a Source or Input button on the TV or the remote. (If you are using a universal remote, you may need a different code to get this feature to work. Cheap universal remotes may not match the feature at all.) If there isn't a Source or Input button, you can check if there is a Menu item to change sources. On my TV, you press the Input button several times until TV is highlighted. Then press OK or simply wait and the TV will go to the new source.
Since this depends on the TV, please post a comment with the make and model of your TV for additional help.
I hope this gets you started.
Feb 15, 2016 | Televison & Video
Remote problems
what exactly do you mean by "tried to fix it"? I think that would help us find a solution - nothing you do with a remote for either unit should stop you getting a signal. I suspect all that has happened is that your TV is not on the channel that recieves the cable output, first thing to try is turning both units off by unplugging them from the power supply and leaving them for a couple of minutes, then turn the TV on first, then the cable box - hopefully it will auto select the right channel. If not then you need to pull up the on screen menu to select the input source (should work from the menu button on the TV remote even if you have no input from the cable box) - check the troubleshooting on this link for a more detailed description; http://www.olevia.com/support/troubleshooting_steps.aspx Hopefully this solves the problem, if not then here is the link for the user manual, which has much more detailed troubleshooting; http://olevia.fileburst.com/manuals/323_English_User_Manual.pdf If you need any help with the steps in that then please ask again. If you get no luck still then I would be tempted to suspect either a fault in the cable box itself, or the cable connecting it to the TV or the network. Doesn't sound like this is the problem from what you have described so far - give us more detail please and we can investigate more. Hope this helps :)
Jun 23, 2007 | Olevia LT32HVM 32 in. LCD Television
How best connect external DVD to TV: Composite or Component? Both available on both units
If the TV does have a component input, that will be your best choice. Component video provides an HD signal; composite is only an SD (480i) signal. However, if the TV doesn't have 3 RCA ports (red, green and blue) for the video itself, in addition to the red/white RCA audio ports, you may be missing an adapter that allows the port to be used properly. You'll need to set the TV to the external video input with a Source or Input button on the TV or the remote. If you press the DVD button on the remote, the TV will only attempt to get the signal from the internal DVD.
Please add a comment with the make and model of your TV for additional information. A number of TVs (like some LG models) share the composite and component inputs and use an adapter to reduce the input to a smaller area on the TV. Without the adapter, the TV can't correctly identify the signal. The component video adapter for my LG TV looks like this: http://www.amazon.com/LG-OEM-Original-Part-EAD61273107/dp/B00C5HXILE . There's a second one for the audio signal.)
I hope this helps.
Jan 06, 2016 | Philips Televison & Video
Need help to get coby tv to work
The basics here: with the original remote enter the menu and look for setup or auto program, select either CABLE OR AIR (WHICHEVER IS YOUR SIGNAL SOURCE) and run the auto program.
You should also be able to direct enter channels like 06 enter to manually go to a channel.
Lastly if you can hook the signal via a box to the rear inputs you can bypass the tuner in the set and see if it works that way.
if questions/comments press the "make a comment" button on this page.
Mar 25, 2012 | Coby Televison & Video
I have comcast remote and granddaughter turned tv on side panel. Now screen is fuzzy and I can't find remote that came with tv. I get picture back?
Hello Mary and thank you for choosing FixYa today for your online technical support needs.
When you say the TV is FUZZY, do you mean that there is no picture there at all?
It is possible that your grandaughter may have changed the VIDEO INPUT MODE SELECTOR on the TV by accident when she tried to turn it on with the controls on the TV itself.
Most TVs have a button right on the front of the set itself labelled INPUT which allows you to switch between the various input modes. That button should be located right beside the POWER, CHANNEL, and VOLUME buttons on the TV's front panel.
You may simply need to press the INPUT button and select the proper INPUT SOURCE for your Comcast cable box.
The proper INPUT MODE for your particular setup will depend on how your Comcast cable box is connected to your TV. If your cable box is plugged into your TV with an HDMI cable, then make sure your TV INPUT MODE is set to HDMI.
I hope this helps out, and please feel free to comment back to this page with any additional questions or concerns and I will respond back.
If you do need additional help, please be sure to include the exact model number of your TV and of your Comcast cable box as well as how the two are connected.
Good luck and take care.
Joe.
Feb 14, 2012 | Initial DTV-201 20 in. LCD Television
How to adjust color for better picture
Hello there,
For the Best Picture use the HDMI Cable and here are the Settings for the color setup.
Adjusting Your HDTV Settings
Using the On-screen Display (OSD)
The remote control or the control buttons on the side of the TV can control all the function settings. The
OSD allows you to adjust contrast, brightness and other settings. The TV will save changes made to the
settings, even if the TV is turned off.
The OSD consists of several menu options. The main menu options may vary depending on your
selected input source.
Note: Some of the main menu options may have additional submenus, for example, the TV Rating
submenu for Parental Controls.
The remote control or the buttons on the side of the TV can control all the function settings. The HDTV
Settings App allows you to adjust contrast, brightness and other settings. The TV will save changes made
to the settings, even if the TV is turned off.
The HDTV Settings App consists of several menu options. The main menu options may vary depending
on your selected input source.
1. Press the VIA button.
2. Press ? or ? on the remote control to select the HDTV
Settings App, and then press OK. The Main Menu will be
shown on the screen.
3. Press ?, ?, ?, or ? on the remote control to select one of
the menu options:
? Input
? Wide
? CC
? Sleep Timer
? TV Settings
? PIP
? Network
? Bluetooth
? Help
4. Press OK to select the option or feature you want to adjust.
5. Once the menu option is displayed, press ? or ? on the
remote control to select one of the items to adjust.
6. Press OK to select it, and then press ?, ?, ?, or ? to adjust the selection.
7. Press BACK once to return to the previous screen. To return to your program once adjustments
have been completed, you can do one of the following:
a. Press EXIT on the remote control.
b. Press the RED button on the remote control.
c. Highlight and select the RED X in any menu.
i hope this was helpful don't forget to Rate
Jan 26, 2011 | Vizio M550NV 55 in LCD HDTV
I cannot change the channel with the remote, and batteries are working...what do I need to do?
Look at the input or video select button. Change it once and attempt to change channels, if the problem persists continue to change the input selection until you can select channels.
THANK YOU AND PLEASE RETURN FOR ADDITIONAL HELP IF NEED BE.
Jan 09, 2011 | Craig CTV-41331 13" TV
I have hooked up my tv for a computer moniter and all it says is YPbPr no input signal can i get some help please
Dear Sir,
After switching your monitor as a TV you have to select input source as TV or DVI by using your monitor remote controller generally monitor set to VGA input.For using it as a TV you have to change the input from VGA to TV or DVI. It think it solves your problem.If you find any difficulty post a comment with more information about the problem,we will glad to assist you
good luck
Aug 27, 2009 | Polaroid FLM-2011 Television
LG 37in HD LCD tv not responding to any pressed buttons.
Based on your description, it appears that you have main board issues with your unit since your controls do not work and some inputs are NG.
Apr 24, 2017 | LG 37LP1D 37 in. LCD Television
Pioneer VSX-D608 Optical connection
The manual states that the default association of each digital input in as follows:
  • Optical 1: CD
  • Optical 2: MD
  • Optical 3: TV
  • Coax: DVD
Use the "Signal select" button to set the receiver to use a digital input, and the Dolby/DTS button (above "Signal select") to enable decoding.
As samz11 stated above, a remote is required to alter the digital input mapping.
Sep 19, 2008 | Pioneer VSX-D608 Receiver
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
