Question about Dewalt DW744X 10" Portable Table Saw
How do you hook up the white wire off the motor to the two remaining wires in the switch box
I had the motor rebuilt and I don't know where the white and black wires go back
3 Suggested Answers
  • 15 Answers
SOURCE: where do the wires from the motor (red white and
the motor wires come out of the top of the switch
Posted on Oct 10, 2009
SOURCE: need to wire cable which is missing from pressure
problem solved,bumped into a eletrician today and put me right on the matter. up and running. many thanks.
Posted on Nov 24, 2009
My shredder jammed so I took the top off of unit in order to clean. When I pulled the top back it pulled all of the wires loose. Being inexperienced I should have made a "diagram" of where the...
I'm afraid i cannot help you to tell you where each specific wire goes first because the wire colors mean nothing without sources and destinations but i can tell you this:Each wire has an elastic memory so that the shape it had before you opened it should remain the same. This means that you can deduce where each wire goes. Also you should have an electrician do the connections as there could be some voltage/amperage issues.
Jan 01, 2012 | Office Equipment & Supplies
I am replacing a two way switch with a two way Trimatron dimmer 6681 The dimmer has 1 black wire hot, 2 red wires and a ground (green) The box has 2 black, 1 red and 2 white What do you connect...
The best thing you can do in that situation is match the wire colors of the dimmer to the colors of the screw terminals on the switch you removed. Unfortunately, its too late for that - so here's my best guess: One of the black wires in the box will be coming from the same romex cable as the red wire. Take THAT black box wire and connect it to one of the red wires on the dimmer. Take the red box wire and connect it to the remaining red wire on the dimmer. Connect the black dimmer wire to the remaining black wire in the box. The two white connectors in the box get tied together - they don't get tied to the dimmer. And the ground (green) wire on the dimmer just connects to the bare ground connection in the box itself - or to the metal backbox - or cut it off and don't use it.
Jul 15, 2011 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
The Casablanca 88U33M Scandia Ceiling Fan only has three wires, a black, a white, and a green wire (ground). How do you wire the fan and light on seperate switches?
If you want to control both the light and the fan using 3-ways, then just wire 2 sets of the 3-way circuits. For this you need two sets of 3-wire between the switches, and one 3-wire cable from the switch location to the fan/light box.
At box #1 (a 2 gang box), you will run a power cable (marked cable #1) into it. From there you run 2 sets of 3-wire cables (identified as cable #2 & cable #3) to the other switch location, which will also be a 2-gang box (box #2).
Also from box #1, you will run a 3-wire cable (cable #4) to the fan/light box (box #3).
Hook up is as follows:
Box #3: connect black of cable #4 to black (fan), connect red of cable #4 to blue (light), connect white of cable #4 to white (fan/light), and connect the bare to the green.
Box #2: Connect white of cable #2 to identified terminal on 1st 3-way switch (#3). Connect red & black of cable #2 to the remaining screws of 3-way switch #3. Next connect white of cable #3 to identified terminal of 2nd 3-way switch (#4), and connect black and red to remaining screws. Tie all grounds together and terminate to both switches.
At box #1, connect black from cable #1 to whites in cables #2 & #3, using a wirenut. Connect white in cable #1 to white in cable #4. Connect black and red in cable #2 to 3rd 3-way switch (#1) and connect black and red in cable #3 to 4th 3-way switch (#2). Connect black in cable #4 to identified terminal of 3-way switch #1, and connect red in cable #4 to identified terminal on 3-way switch #2. Tie all grounds together and to the switches
Jul 04, 2011 | Casablanca Fan (88U33M) Ceiling
Need to know how the wires go on a kobalt 230 volt air copressor
When looking at the switch it self, There will be 4 contacts. On the switch 2 will be labeled Line (Power in) and 2 will be labeled Motor (power out to motor) . Hook the black and white wires from the power cord to the line side (Either contact, it does not matter). Hook the 2 black and white wires from the motor to the contacts labeled Motor on the switch. The remaining 2 green wires (one from the motor and one from the cord) are to be grounded to the case on the switch.
Oct 01, 2009 | Coleman Powermate 60 Gallon Air Compressor
Need a basic diagram to wire a ceiling fan.
Depending on how your place is wired will dictate the solution here.
The light box in your ceiling should have two or three wires. Black and White, or Red, Black and White.
If you have two wires (one switch to control everything):
Black is power - hook this to the fan's power wire (and the fan's light wire if applicable)
White is neutral - hook this to the fan's neutral wire.
If you have three wires (two separate switches):
Red is power for the light - hook this to the fan's light wire if applicable
Black is for the fan - hook this to the fan's motor
Sep 18, 2009 | Hunter 52" Ceiling Fan With Light And...
WIRING DIAGRAM
Sep 18, 2009 | Panasonic FV-08VQL4 Fan
Have new switch for belle 110v cement mixer
This should be pretty easy. you should have either two or four wires in the box and two or four hook ups on the switch. the wires in the box must stay aligned with the matching colors so if your switch has four connections but you only have two wires hook them up to the post opposite each other top to bottom. (they need to both be on the same side) if you have four wires but only two switch posts wire nut the two white (or blue) together and switch the black (or brown). The important thing to remember is the power needs to come in on go into the switch or breaker first.
let me know if this wasn't helpful
Mar 21, 2009 | Electrical Supplies
Installing washing machine motor P/N 35-5022, need wiring schematic to hook up to machine internals
Is there a white or black connector that clips on the motor switch? it should be an easy unplug and plug the new motor in.
I dont of any Manufacturer that uses single wire connectors any more.
Are you sure you got the correct motor?
Apr 22, 2008 | Maytag Legacy Series Top Load Washer
Dewalt DW744X  10" Portable Table Saw Logo
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
