Question about Frigidaire Affinity ATF7000E Front Load Washer
My frigidaire affinity dryer is flashing e64?
  • Frigidaire Master
  • 1,249 Answers
Most likely suspect is the heating element. Part runs under 100 dollars. If you can't do the repair yourself, prepare to spend at least twice that amount.
Posted on Nov 30, 2014
I am getting a error code E64 on Frigidaire affinity model# FASE7021NW0 It still get hot but keeps cutting off, what should I do
Hello friend, that's a great question!
From my understanding your Frigidaire Affinity dryer is displaying an error code of "E64". An "E64" error code stands for the heater circuit is open. This could be a possible problem with your heater, wiring harness, or even a miscommunication within your dryer. In order to clear out any miscommunication you can perform a reset on your dryer and to do that you need to unplug the power cord for at least ten minutes. If this does not help to resolve your issue I would recommend having a professional technician out diagnose and repair your dryer to help avoid any future issues or unnecessary part purchases. Hopefully this information is helpful. -Matt
Mar 02, 2015 | Frigidaire Dryers
My Frigidaire Dryer (Model #FASE7073LWO has a error "E64" listed on the window. What error is this in reference too?
E64 means Heater Open Circuit. Either your heater coil is blown or you have some bad wiring to the heater coil.
Dec 16, 2014 | Frigidaire Dryers
What is error code E64 and how can it be fix
Good Afternoon Friend, this is Z. Thank you for your inquiry!
Normally error code E64 is an indication that the heater circuit is in the open position. This is not a simple DIY job; I would highly recommend consulting a professional to move forward accurately. The certified technician will need to check the heater coils and connections for open circuits. Depending on the diagnosis the heater or wiring may need replacing.
Jul 13, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
How can i fix an e64 code for frigidare affinity dryer
I understand you are receiving an E64 code on your Frigidaire Affinity dryer. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If further troubleshooting is needed, please leave me your model number, so I am able to better assist. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
I have an error code 64 on my dryer. I am out of work doing chemo right now. can anyone tell me what the problem is
If your Frigidaire Affinity dryer is beeping at you and giving you the "E64 CALL SERVICE" business, chances are you have a bad heating element. The good news is, with a screwdriver, a pair of pliers (a multimeter if you have one) and a new heater element you can fix this yourself and save a couple hundred bucks.
Below I outline a step by step process to do this on the Frigidaire Affinity, but this guide may help with other dryers, as they basically all function the same way.
A WORD OF CAUTION: You will be handling a lot of thin sheet metal components. Be careful as it is easy to cut yourself on them.
First you'll want to unplug the dryer. Then disconnect the vent hose and the water feed (if applicable). Be sure and shut off the water valve first, or you'll have a mess!
http://therandomfix.blogspot.com/2013/07/frigidaire-affinity-e64-error.html
Apr 03, 2014 | Frigidaire Brand New Frigidare Dryer Motor...
MY FRIGIDAIRE AFFINITY FRONT LOAD DRYER THE PROBLEM IS IT WILL START DRYING BUT AFTER ABOUT 2-5 MINUTES A BUZZ SOUND WILL COME ON WITH THE E64
Hello Marcheller, thank you for your question! Typically error code E64 is an indication that the heater circuit is in the open position. This is not a simple DIY job; I would highly recommend consulting a professional to move forward accurately. The certified technician will need to check the heater coils and connections for open circuits. Depending on the diagnosis the heater or wiring may need replacing.
Aug 15, 2013 | Frigidaire Affinity ATF7000ES Front Load...
ERROR CODE E64 FOR FRIGIDAIRE AFFINITY
Please CALL Frigidare. We have had the same problem with our dryer and now the washer quit! Our set is only 3 years old! With all of the problems reported on the Internet there should be a recall on this set! They need to be informed! I am highly disappointed in the short lifespan of the Affinity Washer and Dryer. Dont know if I would purchase this brand ever again!
Mar 02, 2012 | Electrolux EIED55H Dryer
Frigidaire Affinity ATF7000E Front Load Washer Logo
79 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
