Question about Microsoft Computers & Internet
Why I can not turn my PC RoHs
I connected all the accessories, connect to the ELECTRICITY, startup screen and nothing NO LIGHTS
    Top Expert:
  • Microsoft Master
  • 23,222 Answers
Make model and OS please.
Posted on Nov 30, 2014
2 Suggested Answers
Danmart
  • 291 Answers
SOURCE: Internet not connecting
What type computer? Wireless network ? FROM the language you are using [" picks up connection"] It is wireless. You may be picking up "outside" signals. When they are weak, you may get something!,then u loose it. Thats why "pending & nothing happens"
Posted on May 01, 2008
Why I can not turn my PC RoHs]
I am not sure what country you are in but in the USA it is 115.
Nov 30, 2014 | Pool & Spa
Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
How can I fix my laptop screen? It is black when I turn it on.
it's probably not your screen, it's your motherboard. if you get lights and some noise when you turn the power on but nothing on the screen wait about 30 seconds then press enter. then wait a couple of minutes with the sound knob turned to the right. if you get a windows startup jingle you're lucky and it's your screen or a bad connection, if you don't then it's probably your motherboard. sorry
Jan 11, 2011 | Compaq Presario CQ60-220US PC Laptop
MacPro 8-core fails to startup. No power.
If nothing is happening, then you probably have a bad power supply or you have bad connections between your power supply and motherboard. You can take the cover off and make sure that everything is plugged in well. Make sure to touch the side of the case to dispel all static electricity before you touch any of the components. If the machine fans turn on and then it refuses to boot, you might have a bad hard drive or a motherboard issue. If you hear any beeps at startup, you can look those up online because every beep configuration is a clue to something wrong with the machine.
Jul 19, 2010 | Apple MacPro 8 Core 2.66GHz Quad Core...
Blank screen when turned on, then there are 2 lights that flash they both have a lock symbol before them one is with an A and the other is with a 1. Everything else lights up but screen is just blank/black
follow these steps & ur issue might get resolved(80% chances):
turn off ur notebook-->take out the battery-->disconnect the charger if its connected to the notebook-->now press & hold the power key for atleast 20 seconds, remember that u have to press & hold the power key & dont release the power key till 20 seconds are over--> & ensure that the notebook is not connected to any power source while u r performing this step niether the battery nor the charger--> also there shouldn't be any peripherals connected to the notebook-->once 20 seconds are over & u have released the power key-->connect the battery & the charger back to the notebook & now try to turn on the notebook-->u might not get a blank screen & ur issue might get resolved....(This whole step is known as power drain & it is done to remove the extra static electricity which sometimes get stored in the notebook & gives a blank screen in return.)
Jul 08, 2010 | HP EliteBook 6930p Notebook PC
Walkman cannot be turned on
The battery is dead, get a new battery. Its probably a bad one or you charged it to much, and killed it.
Dec 04, 2009 | Sony NWZ-E438F Digital Media Player
Power Problems!!!
i think you have LCD problem but first you check the pC startup full or not.
if pc complete startup then you connect with monitor .
i hope you something see on screen
if not problem solve then mail me
and tell me what happen
aftabsura@yahoo.com
Apr 09, 2009 | HP Compaq Presario v3000z Notebook
Dell dimension 5100 - no power
It seems that your SMPS power supply may be having some fault...try to replace it...
Dec 02, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
E machine no power
Make sure the RAM is seated, the CPU, any video card and the Power supply is properly connected.
If you power it on, still get no POST (beep at startup from the PC speakers) its time to replace the motherboard.
Feb 01, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
51 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
