Question about Pool & Spa
How do I remove the spas from house to house ?
Can I replace a non color changing spa light without draining the spa?
All the free standing spas I ever worked on, all the lighting & controls are accessable through the cabinet of the Spa. The "In ground" spa lights are pretty much treated like a pool light. whereas the light fixture is in a housing that is normally unscrewed from the top of the mounting ring & with a little "tip & lift" housing & cord come out of the water
Dec 10, 2013 | Pool & Spa
A hose fitting is spraying water
Need to help us more: the definitions you used are too generic - "Hose; Strange End Fitting; & What is it for" doesn't provide any help to identify so that we can assist. Pictures always help.
Nov 22, 2013 | Evolution Spas Ventura 90-jet, 6-Person...
Can I use salt instead of chemicals to keep my spa2go clean and sanitized?
Salt is not recommended in Portable Spas as it can be extremely corrosive to metal parts inside of the Power Pack, as well as drying out the vinyl parts, covers, etc, which can cause them to fail very quickly. The recommended sanitizer is Bromine. Make sure you are using quality chemicals if you are having problems balancing your water.
The manufacturer recommended chemicals are available from Oceantis, the only authorized service provider for all of Comfortline Products spas in North America. They can be contacted at (855) 772-6269
Portable Spas Accessories Parts and Chemicals Oceantis Oceantis Cape...
Sep 26, 2013 | Comfort Line SPA2GO INFLATABLE 4 PERSON...
I have a comfort spa portable hot tub with the pump housed within I am hearing a clicking noise and the dispaly shows the temperature readings ascending and the error code sn - what is the problem
This indicates a sensor failure. Either the temperature sensor has failed, or it has become disconnected from the control unit. If you find that it is still in place, replace the sensor.
Jul 11, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
What does FL mean on my hot tub?? water doesnt circulate but is still sort of warm...
FL could be a code for low flow. If you have no circulation this sounds like it. If your pump runs and you have no flow you could have a problem with your pump. Or if you have the tub drained then it could be an air lock, if you open the drain valve till you get water out that should fix that. Also check to be sure the isolation valves are open under the spa. I hope this helps.
Feb 07, 2010 | Qca Spas Dream Series Dream Master Hot Tub...
Filter for QCA Aruba xl
QCA has used 4 different sized filters in their tubs through the years.
  • c-4326 4-15/16" x 13-15/16" 25 sq ft
  • c-4950 4-15/16" x 13-15/16" 50 sq ft
  • c-4995 4-15/16" x 23-5/8" 95 sq ft
  • c-5397 5-5/16" x 17-13/16" 80 sq ft
you will need to measure the inside height and diameter of housing and see which one will fit best.
Jan 30, 2009 | Qca Spas Majestic Series Aruba Xl Hot Tub
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
