Question about RC Toys
My mini rc helicopter lands in a few seconds of flying time. So I decided to replace the battery(because I thought it is a battery problem). After replacing the battery, problem is not solved. Helicop
I replaced the battery and tried, but problem is still there.
    Problem Solver:
  • 18 Answers
Some of those mini helicopters are just designed bad. Their motor is to weak, the whole setup battery-speed controller-motor-blades is slapped together "hoping it will work". The quality is ridiculous. One heli or one from a certain batch would fly descent, others woudl barely lift of and drop down after a few seconds. The best solution is to return it to the store and by something for more money. But if you want to experiment:
1) Try reducing weight: remove anything that is not necessary off of it. Also, try smaller/lighter battery with same voltage and current rating (smaller capacity=lighter)
2) Try slightly higher voltage. I.e., if it uses NiCD/NIMH batteries, add additional cell. With LiPo's it's a bit complicated, if heli is running of one cell (3.7V) adding another cell will burn it. If it is 2 cells, trying 3 cells might work or might overheat the motor.
3) Try replacing the motor with slightly stronger one. Now you will need to search online, ebay, hobby stores for similar size that you can fit in. Not the easiest thing to do.
4) Again, get rid o fit. it's not worth your time, unless you like to experiment. It will never fly the way you would like it to.
Posted on Nov 30, 2014
micromend
  • 748 Answers
SOURCE: my rc helicopter can not fly it spin in floor
Hi
This type of helicopter uses a fixed pitch blade. Have you recently replaced one or all the blades? If the blades are correctly positioned then once the motor comes to speed, the pitch of the blade creates enough lift to overcome the force of gravity. The problem you're having can only be that the motor is not coming to speed or the blades have been replaced but the pitch is now at the wrong angle.
Posted on May 13, 2010
SOURCE: heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Posted on Apr 23, 2010
SOURCE: my rc helicopter wont fly high?
flew at first hit sealing won,t fly now hit the trim button,s but still wont fly
Posted on Dec 05, 2010
  • 65 Answers
SOURCE: i just bought a knight hawk helicopter flew it a
k tell someone from the store
Posted on Dec 25, 2010
SOURCE: I have Brookstones silver bullet
Sometimes the metal weights fall out of the top rotating bar causing the blades to be out of balance and the bottom blade to hit the tail. Check to see if both the weights are in the top bar.
Posted on Jan 13, 2011
There aren't green light in charger
Search Results
    How To Fix Your RC Helicopter - YouTube
    ? 4:22
    https://www.youtube.com/watch?v=R65JJYwSH50
    Jun 28, 2010 - Uploaded by R/C 101
    Does your RC helicopter spin out of control in the air or ... thing that the video says but there nothing wrong about it the remote is fine but the propeller .... i have a brookstone RC stunt copter that i have not used in a few months. i .... however when I come to fly it, it makes a sound but the wings aren't working.
    All comments on How To Fix Your RC Helicopter - YouTube
    https://www.youtube.com/all_comments?v=R65JJYwSH50
    where can I buy new gears and pinions for my mini rc helicopter?. Read more Show.... The two pins on the charger port aren't working they won't charge ..... The charging light is off meaning the battery is charged. Any ideas? ..... So, the motor spins the correct way but there is no gear to transfer the power to the rotors 'A'.Missing: silver ‎bullet
    rc helicopter light flashing Remote Controls Questions
Jan 19, 2016 | Brookstone Rc Mini Helicopter Silver...
Spins to left, will not take off/lift?
GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC ...
www.amazon.com/Hercules-Unbreakable.../B00AAOJ...
Amazon.com, Inc.GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC Helicopter (Color ... you can remove the 8 or so screws that allow you to pull the fairing off, remove .... Also we purchased our helicopter from HobbyTron.com through Amazon and .... won't spin, so the entire helicopter spins, and doesn't generate enough lift to fly.
GYRO Nano Hercules Unbreakable 3.5 CH Electric RTF RC
Amazon.com, Inc.Nano Hercules Unbreakable Glow in the Dark 3.5CH RC Helicopter ... It can go forward, backward, up, down, left, right and hover. .... It worked for a few flights and now the copter will not fly off the ground. ... and ive had it for a year now and everytime I start it up and it takes lift off it starts to fly backwards but otherwise ok toy.
Hercules Unbreakable 3.5CH RC Helicopter - HobbyTron.com
Dec 26, 2015 | HobbyTron Nano Hercules Unbreakable 3.5CH...
I recently purchased a Fast Lane Hawk 4 rc helicopter. After a few small "crashes", it shakes and doesnt fly well. Does the top rotor need replacing, and if so, can I get the parts for it?
I have the same one, i have searched long and hard for parts for this without much sucsess, allthough i have found this on ebay, the blades and rotor look very simular
http://www.ebay.co.uk/itm/Metal-3-Ch-RC-Mini-Helicopter-Main-Tail-Blade-SET-G-/140315300745
Its slightly diffrent but i think the blades should fit the hawk 4. In the mean time i shall keep looking.
Sep 20, 2011 | Toys
My helicopter flew for a few seconds and then feel to the ground. It seems as if the controller does not work with the helicopter
Check your battery pack to see if the controller lost power or the battery pack in the RC ARF to ensure that, the copter can receive.
Dec 22, 2010 | RC ARF Falcon 40 Helicopter
I have 3 s107 and I it says 3 channel on the box and the transmitter says A B C but will only let me select 2 of them. What's the trick on flying 3 at the same time?
Mine's exactly the same as yours. Although the transmitter shows A B C the switch has only two positions, so there's a choice of two only. I doubt it's possible to fly 3 at the same time.
Nov 08, 2010 | SYMA Toys industrial New Syma S107 Radio...
My rc helicopter wont fly high?
May 13, 2010 | Radio Shack Indoor Micro Mosquito Rc...
Building a RC helicopter for college
You might want to get on google and search how to build Remote Control Helicopter. you will find a lot of useful info. If you have never flown a RC heli thought I suggest you get a sim for the computer. I have been flying now for 10 years and they are not that easy to fly. I still have problems and always am learning some thing new. here is one link to look at.
http://www.angelfire.com/blues/heli_project/
Jan 29, 2010 | Apache Colco Ah 64 Longbow R/C Helicopter
Toys Logo
80 people viewed this question
Top RC Toys Experts
LP
Tom Chichester
Kevin K.
Are you a RC Toy Expert? Answer questions, earn points and help others
