Question about Christmas Lights Etc Toys
How do I pick a right bulb for Christmas tree and string lights? Some are 2.5V some 3.5V some 5V... Some say 2.5-3.5v. I replaced some burned bulbs with generic 2.5-3.5V bulbs from stores and they are
Replacing bulbs with various ones. It seams there are different voltage bulbs, even when the same voltage rating, they have different power/currents/resistances
    Problem Solver:
  • 17 Answers
If you are lucky, it is very simple. But then, it can get complicated.
Given that you are talking about classic incandescent (non-LED) bulbs:
Strings are made of certain number of bubs connected one after another (in line, daisy chained), so voltage is split among them. 10, 25, 35, 50 are common numbers. If your string has 75, 100, 150 or so, it is built with 2 or more groups of lights. I.e. two groups of 50 bulbs in-a-row. (two groups are connected in parallel, so both are getting 110V).
If in doubt, pull one bulb out and count how many bulbs turned off.
Divide 110V with how many lights you have in the string (one group) and that is an approximate voltage of each bulb.
50 pcs - 2.5V
35 pcs - 3.5V
20 pcs - 5V
10-12pcs - 12V
35-50 pcs in-row sets are most common. If you buy generic 2.5V-3.5V replacement bubs, they will work in any 35-50 pcs set. The brightness difference will be small.
You should replace the burned bulbs as soon as possible. Each bulb has what is called "anti-fuse". When it burns, it creates an open circuit. This means, that all 110V will show at the contacts of a burned bub. inside of the wire is aluminum wire wrapped about contacts that hold the filament. This wire is coated with oxide that acts as an insulator. 110V is enough to burn through the oxide insulator, and burned bulb gets bypassed, allowing other bulbs to stay on. However, as 110V is now divided to smaller number of bulbs, meaning each bulb gets higher voltage. After several bulbs are burned, the voltage becomes too high, and all of them burn.
This was an easy part. However, there are some differences when you look at different manufacturers and types of lights.
I.e., 2.5V bulb will usually draw 150mA at 2.5V. However, some longer strings, or strings with three groups of racing lights use
2.5V 100mA (0.25W) bulbs. If you believe your string should use 2.5V bulb, and replacement one is dim when installed, try 100mA bulbs. Search the web or eBay.
If you have similar problem with other voltages, and you don't remember exact model and manufacturer f lights (who keeps boxes anyway?) that you need to research different versions of certain voltage bulb. Again, Google it or eBay/Amazon, are good places to do it. takes some time to find the answer.
Another difference are Sylvania Stay-Lit lights. They don't use anti-fuse bulbs. Often, they use 2.5V 70mA bulbs. No aluminum wire inside. They are patented to stay lit even if you remove the bulb, or break it. Inside of the socket they have electronic circuit (thermistor I think) that "senses" missing or burned bulb, and takes over the current for other bulbs, with almost the same voltage drop/resistance, as the bulb would have. In this case, there is no risk for other bulbs to get higher voltage and burn.
I recommend to use proper replacement bulbs (with no anti-fuse). As a temp solution (if you want all bubs shining and it will take time for right replacement ones to arrive), bulbs with anti-fuse will work (i.e. 2.5V 100mA) but when/if those burn the aluminum wire inside makes a short, deceiving the purpose of stay-lit electronic circuit and puts more voltage/stress on other bulbs.
Hope this helps. Good luck!
Posted on Nov 30, 2014
  • 49 Answers
Now this is one I ask myself. Why Dont the same people who sell a certain brand of lights sell a pack of replacement bulbs of the same brand? Most lights come with a few replacement bulbs but it just seams easier to use and old set that match others I have for "spares bulbs" and buy a new set for a tree or bush or an item not next to other older set(s). Otherwise if you still have a bulb one can check the ohms with a multi-meter and compare the with another. Voltage would have to match and then would have to look for some bulb with the closest ohm. Like I said. Why not sell bulbs for the lights you have sold. Seems the cheap ones are the only ones that are more standard then bigger names cause they just seem to change (improve) their design. Good luck.
My prelim xmas tree has sections where all the bulbs are burn out , what can I do to fix the problem
Replace the bulbs where they stop working
sometimes when one bulb burns out it stops the circuit so by replacing the one burned next to the one working the rest might come on ... depends on the string
might just have to replace that string
Nov 18, 2016 | Cars & Trucks
Tip
Replacing a Christmas light Bulb
Replacing a Bulb The ideal replacement is one from an identical "replacement" string bought at the same time as the "operating" string. Anything else is a much less desirable option. Many strings have two separate circuits of bulbs. Within each circuit, all the bulbs are wired in series. They each see the same small fraction of the line voltage, but only as long as the bulbs operate identically. Different strings can have bulbs of significantly different resistance, yet all bulbs will operate at the same voltage, as long as the bulbs are similar within a circuit. But if we place a high-resistance (typically dimmer) bulb in a generally low-resistance (typically brighter) circuit, that bulb can see far more voltage than it was designed to handle. In that situation, the bulb may simply burn out in a fraction of a second. Another issue seems to be warm-up time: All incandescent bulbs increase their resistance as they warm up. But even bulbs with the same ultimate operating voltage can warm up at different rates. And if a fast-warming bulb is placed in a slow-warming string, it can quickly see much more voltage than expected, and may blow out. It is much, much better to buy two strings to operate one string, and then use the other simply for replacement bulbs. But that requires prior planning. For existing strings, there may be an option: If two or more strings were bought at the same time, we can take one out of service, put it in a zip bag and use it for replacement bulbs. For existing lone strings, there still may be an option: Convert a 100-bulb string to a 50-bulb operating string and a 50-bulb dark replacement string. That can be as simple as taking bulbs as needed from one half of the string and using them in the other half. Of course, then we end up with half a string that looks like it desperately needs work. An alternative is to cut the string in the middle and end up with one fully-working short string plus a short string of replacement bulbs that we can keep in a bag. Typically, three wires are twisted together across most of a string, but only two are twisted at the start, middle, and end. So if we look for the two-wire section in the middle, we can cut there (after first turning the power off). On the working half, we can fold each of the two just-cut wires back upon itself and wrap each separately with tape, or separately insulate with electrical heat-shrink tubing.
on Dec 07, 2009 | Kitchen Appliances - Others
REPLACED TUNER BUT STILL WONT PROGRAM CHANNELS. WORKS GREAT WITH BLURAY AND DVDS JUST NOT TV CHANNELS
Replacing tuner does not guarantee the reception of channels. There are certain conditions for the tuner to work ie voltages at different pins. Please check all the necessary voltages at various pins of the tuner. I hope you will get your answer.
Good luck friend.
May 27, 2015 | Televison & Video
Need a replacement power supply for a Evernote scanner
Sorry Gregory, gave you the wrong number.
You could try something like this. Various voltages and currents with different adapter plugs. This is on Ebay UK but I would think there are others, don't know where you are.
Ebay item number: 201154296095
Specs:
1.Rated Input Voltage: AC 110V or AC240V
2.Vibration Input Voltage Range: AC95V-265V
3.Input Rated Current: 0.4-0.6AMP
4.Input Power: 90W
5.Efficiency: >88%(TYP)
6.Out Power: 90W
7.Output voltage: 15V/16V/18V/19V/20V/22V/24V(0/+0.5V NOLOAD): DC15V-24V
8.Output voltage: 15V/16V/18V/19V/20V/22V/24V(-0.4/0.5V@rating load): DC15V-24V
9.Output current: 15-20V/4.5A@22V-24V/4.0A: 4.5AMP(max)
10.Overload protection: YES
11.Short Circuit Protection: YES
Dec 17, 2014 | Office Equipment & Supplies
How can you power a light bulb
Can you give more information?
A light bulb is powered by connecting a voltage, via the right sort of base. Bulbs are rated at different voltages, some high, eg 240VAC, some low, eg 6VDC.
Is that what you meant?
Dec 09, 2014 | Knowledge Adventure...
How do i fix christmas tree lights
Assuming the wires to be good, if the string of lights consists of more than one section (for example, a string of 100 lights is made up of two sections of 50 lights each) and the lights of only one section are out, you have a bad bulb (or possibly more than one) that must be located and replaced. If your light string is only a single section set (a set of 50 or 35 or 10), it's most likely also a bad bulb but it could also be one of the fuses located in the plug. Light sets come with a few replacement bulbs and usually two fuses. Take the plug and slide open the little compartment door and you'll see them. Replace them and try the set. If it still doesn't work, it's a bad bulb. On multiple-section sets, the fuses in the plug power all the sections, so a working section eliminates the fuses as suspect.
Dec 15, 2012 | Christmas Lights Etc Santa's Toy Truck
My head light is notworking my single light work break light work just the head light fuses are good blub works what should i look for
Check you light switch. It should be a simple series circuit consisting of bulb, fuse, switch and of course the wiring. Make sure the bulb is really good and making good contact. You may want to do voltage checks at various points if you have a voltmeter. If you can follow the wiring make the voltage checks otherwise remove the bulb and carefully make voltage check at the contacts making sure not to short out. With light switch on check the voltage and ensure you have 12vdc. That will tell you for sure that the bulb has proper voltage. Check the voltage with the headlight switch on and off. If no value replace the fuse. Sometimes fuses are deceiving and look ok when they are not. If you can also check the voltage across the light switch by using a voltmeter. Ensure that you have 12vdc when switched to the ON position. Do not attempt this unless you know how to use a voltmeter as you could short the ciruict by accident. I had a Harley Police so may have been a little different but the concept same.
Apr 02, 2012 | 2002 Harley Davidson XL 1200 C Sportster...
How wiring diagram for christmas lights work
All the bulbs in a section of lights are connected in series, meaning one after the other, like links in a chain. If one bulb goes out the chain is broken and that section goes out. All modern light sets have bulbs which have a built-in feature called a shunt. The shunt in the bulb is supposed to short out if the bulb filament burns out. The advertising wording would be something like 'if one bulb burns out, the others stay lit'. It usually works, but there are limits. Sometimes the shunt in the burned-out bulb fails to work and the chain remains broken. You have to find the bad bulb and replace it. Also, every time a bulb burns out, if the shunt is working and the other bulbs stay on, the power to each remaining lit bulb increases. This puts a strain on the remaining bulbs, which is why you should always replace burned out bulbs as soon as you discover them. If you don't and more bulbs in the same section burn out, you can reach a point where there's too much power for the remaining bulbs to handle, and all (or at least many) of the remaining bulbs will burn out, necessitating a replacement of the string.
Dec 15, 2011 | Christmas Lights Etc Santa's Toy Truck
Toys Logo
135 people viewed this question
Top Christmas Lights Etc Toys Experts
Gil Shultz
Frank Walker
Level 1 Expert
Tom Chichester
Are you a Christmas Lights Etc Toy Expert? Answer questions, earn points and help others
