I have an acer aspire e3-111-c2kg. It is about 2 months old and when I switched it on today it just has a black screen and won't load
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 884 Answers
Hi there
Firstly, don't do anything drastic that would void the warranty since it is only 2 months old.
One of the possibilities is that it has been switched to external monitor only. <Fn> + <F5> is a display toggle which switches the display output between the built-in screen, an external monitor (if connected) and both. Try this first.
You can get a full user manual here, if you haven't got one with the machine.
Drivers and Manuals
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Nov 30, 2014
tat4u
  • 520 Answers
SOURCE: acer aspire 5610 wont boot windows XP
turn on pc enter bios setup select default settings save and restart.have os disk in drive wait for screen display any key to start from cd.press any key to load disk.in options select install windows ( not repair) your system will find existing os ,now you can choose repair or install fresh copy.if you choose to install fresh copy delete partition first and create new partition and format.
Posted on Mar 02, 2008
mumma_1
  • 903 Answers
SOURCE: I can not get my Acer Aspire 5920 to load after turning on.
Try to see if it will boot in safe mode, by pressing F8 while the laptop boots up. If it allows you to boot in safe mode, try to do a system restore when you know that laptop was working with no problems. You can do this by clicking on start>all programs>accessories>system tools>system restore and choose a date and time when you know that the laptop was working with no problems. If this does not work or you cannot boot in safe mode (be aware that everything will look big in safe mode and when the computer reboots if asked how you want to start windows, choose start windows normally), try doing a recovery. This will restore your computer to the factory default settings when you purchased it. You can do this by booting the computer, when the acer screen appears hold down the ALT key and continuously press F10, this will open the recovery manager and you can restore it from there.
I hope this helps
Posted on Jan 20, 2009
leecom72
  • 4806 Answers
SOURCE: acer aspire 1 netbook won,t boot up.
Hi
When you first turn the machine on hit F2, that will take you into the bios menu, i don't know what version your machine is using, but the information is usually on the first page, you should find it easy enough because it will be next to the CD/DVD drive.
Posted on Feb 01, 2009
hakimmadina_
  • 155 Answers
SOURCE: acer aspire 9300 black screen (display adapter)
I have been fixing computers that has long beeps and short ones. It is usually attributed to memory problem connection. Open the memory compartment at the back of the PC then detach the memory card. Clean with cloth softly enough not to destroy the circuit board or a pencil eraser to clean-up dust that caused the connection blockade. Reconnect after cleaning.
Posted on Jun 21, 2009
bhagyavichar
  • 414 Answers
SOURCE: laptop turns on but then nothing. just a blue
probably ur system's software is corrupted or ram is faulty..proceed with the following step(s) only if u r a professional..
1)a) open it/them, rub itz teeth gently with a eraser, to remove any
oxide and or carbon formed..resit them again into the slot(s)..
b) replace the ram with a standby n see..
2)reinstall os..
the above often take place with some error message(s)/blue screen..
but if there's no such displaying, esp if hangs/stops/power off during installation..
[plz give priority to step1(b), it may b the sole cause]..
thereare also exceptions, where it is found that any hardware component onthe system is loose or incompatible (see addon cards, the ram(s), thehdd, all data cables n power cords, may b dusty, cpu overheating, see filter/power/south bridge/crystal clock generator section of m/b esp mosfets and capacitors..etc..
when u get into the os, plz do the following:
hva licensed and UPDATED antivirus installed (i prefer avg/kaspersky,remember, without updation a full version antivirus is useless)..
download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'removeall the unnecessarystartup items from here..(if u can't find what toremove, post me/us inur comment with all the items listed in each nevery tabs herein)..
remove all unnecessary software from add/remove programs..
download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
contact ur system admin/vendor....
Posted on Nov 12, 2009
Acer aspire m5 won't charge
it sounds like one of three things:
1. Battery itself no longer functions
2. Laptop Charger has inadequate amperage
3. The motherboard is defective (most likely).
If you have another battery, or a friend with the same battery, you can try that first (and someone else's laptop charger).
If the problem is the motherboard, you can try to have it repaired but I don't trust many companies to do this kind of work. I outsource my motherboard jobs to a company called Laptop Rescue (http://www.laptoprescue.com/laptop-repair-2/). Coincidentally, they also sell laptop chargers in case that's the problem. Hopefully it's just a charger or battery issue and not a motherboard.
http://www.aurabuy.com/cheap-4400mah-battery-for-acer-travelmate-4740-4740g-4740z-4750-5335g-5335z-5340g-5542g-6495tg-8473g-8472t-tm5740-paypal.html
Apr 06, 2013 | Acer Aspire One PC Notebook
Acer Aspire 9300 1 long and 2 short beeps
Have the same problem and i solved it after 1 month tries
the problem was in NVIDIA Graphic card
the solution was by by heating the NVIDIA Graphic card for 5 min or more
Sep 26, 2012 | Acer Aspire 9300 Notebook
Acer aspire 5349 won't boot
I had the same problem. I clicked on F2. in Bios screen I press f10 (save and exit), and windows started.
Apr 02, 2012 | Acer Aspire 9300-5349 Notebook
Acer Aspire 7520 black screen wont boot
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
Dec 19, 2009 | Acer Aspire 7520-5185 Laptop
Acer aspire 9300 notebook black screen while in use
If there is power beside you,why not connect you laptop to the family power,it will be good to your acer aspire 9300 battery life .Pay attention to your acer aspire 9300 laptop have been 2 years old,i think it most properly some problem to your acer aspire 9300 battery.
Sep 24, 2009 | Acer Aspire 9300 Notebook
Plugged in; worked yesterday; 8 months old. today: nothing. black screen, no sound.
try to run virus scan , then try to reinstall the operating system
Aug 07, 2009 | Acer Aspire One PC Notebook
Hi My 10 month old Acer Aspire 8920 has no display on the monitor. It starts up and then screen goes black Help Lynne
lynne, if its 10 months old it should be under warranty no display can be blown video card or even screen and is expensive if you have to pay for repair
Jun 23, 2009 | Acer Aspire 8920-6671 Notebook
Acer 5315 goes to black screen with cursor
If it's only 5 months old, then it's still under warranty. Right now, I'd advise taking it back to have it fixed instead of taking it apart to replace hardware and possibly voiding a warranty.
Feb 15, 2009 | Acer Aspire 5315 Notebook
Acer aspire 1 netbook won,t boot up.
Hi
Feb 01, 2009 | Acer Aspire One Netbook 8.9" Notebook
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
