Question about Roland Music
I lost the internal data of roland e96
Replaced the internal battery
  • Sandrine Sims
    Sandrine Sims Dec 03, 2014
    try cleaning the battery contacts
    Problem Solver:
  • 7 Answers
If you are referring to the User Data, then yes that would be gone.
Time to reset and start re-programming
Posted on Nov 30, 2014
Does the gt10 have an internal battery for the user memorys if so how long does it last
Generally, any unit such as this will have a backup battery for the user changeable areas' memeory. The normal span is 6-8 years, but i change all mine at 5. You should read the manual for your device and/or contact Roland customer service. Here's the info-
http://lib.roland.co.jp/support/en/manuals/res/1810803/GT-10_e2.pdf
Roland Support
Mar 17, 2016 | Music
I have a roland e96 trouble. Fist indikator in lcd internal battrey low, but not change the battey. now my roland e96 is blank.
You need to replace the battery. It will most likely be a coin sized battery in a slip in holder on the main board. If you need help, here is ROland Customer Service contact info-
Support Roland
After that, you can reset the E96 back to the factory settings by following the directions here-
Roland 96 Initializing the 70 86 96 Restoring the Factory Settings...
Mar 18, 2015 | Roland Music
I replace my battery in my roland xp 80 but it still say battery low on screen. what do i need to do
It's always possible the new battery had lost it's charge before it was installed. Check it with an ohm meter for it's voltage. Other than that, either the contacts in the battery holder may be in need of cleaning or the battery wasn't installed correctly.
Jan 12, 2015 | Roland Music
I have a roland e96 that showed the message_INTERNAL BATTERY WEAK every time i switch on and the display of screen is empty
It's likely a coin battery, like the type in a computer, used to keep the bios or settings ram user settings (whatever)memory
Nov 30, 2014 | Roland Music
The roland d10 powers up but none of the buttons or keys work? the screen just says "roland d10 synth"? please help!
The unit name is part of the boot sequence, it should go beyond that and boot up completely. If it gets stuck there, there is surely some problem. Maybe a depleted internal battery, I don't know. Ask a local service center, maybe there's a combination of buttons you could check out while on the phone prior to bringing it in for repair...
Jan 07, 2013 | Music
Does anyone know hot to change a Roland E-70 musical keyboard's internal battery?
Well I did it. Remove 14 screws marked with arrows. Be careful separating the top from the bottom as there are several cables to deal with. The only cable I disconnected was the larger Ribbon Cable. The CR 2032 battery slides out by lifting the end of the retainer about 1/16 of an inch. Then simply slide in the new battery and make sure it is seated. Then just reassemble.
Aug 18, 2012 | Music
I wanna learn the circuit diagram of roland gw8
You would have to get the circuit schematic from Roland and they may not give that out as it is proprietary. I have circuts for Fantom and Yamaha Tyros and believe me you won't learn anything beyond the block diagram. The circuit details are BURIED inside chips that you probably can't even get data sheets on and certainly can't get or understand the firmware of the internal operating system.
Feb 16, 2011 | Roland GW8 Keyboard Arranger
Where can I take my roland juno keyboard to be repaired lost soun
juno, lovely instrument, try the synthesizer repair centre in london
Feb 06, 2010 | Roland Juno-D
SR-16 gives message "ERROR: 01" when powering up
You likely have lost the internal memory data. This can be due to a power surge or that the internal battery has been depleted. The battery may need to be replaced.
You should reset the unit and reload the data, The manual is available online. Search Google for it.
The manual STRESSES the importance of backing up the data.
If you don'thave the backup, you MAY need to find another SR-16 owner to clone the data from.
Jul 01, 2009 | Alesis Sr 16 Stereo Drum Machine
Music Logo
Top Roland Music Experts
Vito Vacirca Jr.
Rabbit Brains
Rabbit Brains
Matthew Spark
Matthew Spark
Are you a Roland Music Expert? Answer questions, earn points and help others
