Question about Intertherm Heating & Cooling
Intertherm lp gas furnace model number m6rl060a be no power to unit breaker ok
Breaker is ok not sure what else to look at
  • 46 Answers
If you have recently changed your filter sometimes the door doesnt go back on right to depress the door switch. if you have power going to the unit the next place in line is the door switch. it looks like a light switch in your refrigerator and the door must be in place properly to depress it all the way
Posted on Dec 02, 2014
Therinnaiguy
  • 1420 Answers
SOURCE: breaker keeps tripping
If the breaker itself is more than 15 years old, replace it. If it continues to switch off, check the amp draw of both the inside and outside unit.
Posted on Sep 12, 2007
  • 49 Answers
SOURCE: intertherm furnace explosive burner ignition
You absolutely must stay with Therin's recommendation. You do have a block or a cracked heat exchanger and this is nothing to toy with. Carbon Monoxide is very serious and dangerouos. All of your new furnaces should be power ventilated and you need to retire that one.
Posted on Nov 20, 2007
  • 49 Answers
SOURCE: Intertherm E1EH-015HA FURNACE no heat
Sounds like a downflow electric furnace? If so it sounds like you have 15kw worth of electric heat, you might have a defective heating sequencer, witch is what they call a dual on one plate.
Posted on Nov 28, 2007
hotuna
  • 288 Answers
SOURCE: elec. intertherm FURNACE
It would help if I knew what type of system you have, lets start with the thermostat. If you disconnect the wires to it, does the heat turn off? I have seen thermostat wires pinched inside the wall, thus bypassing the thermostat controls altogether and it would run constantly. If you send a reply, tell the type. Wall furnace, central unit, heat & cool, gas, electric or heat pump. If you dont know tell me how many wires you have at the thermostat and the colors. You should know this, as you have changed it.
Posted on Jan 13, 2008
meBNme
  • 334 Answers
SOURCE: weak flame in intertherm furnace
Ok, so we can rule out the ignitor. (standing pilot systems can develop problems that will cause such symptoms.)
Check the gas pressure, make sure you are getting 11 to 14 PSI.
You need that after the regulator all the way to the manifold.
Also check for cracks in the heat exchanger, causing the wind from the blower to distort the flame pattern enough to cause improper contact with the flame sensor.
Make sure the burners and flame channels are clean of rust, and dibri build up, allowing the flame to properly contact the sensors.
Posted on Jan 19, 2009
Manual for model C7BAM03648C-C
According to the web, the model C7BAM03648CC is a Westinghouse refrigeration unit. Are you sure you didn't get the number from the top portion?
C7BAM Cased Vertical Coil
• R410 refrigerant-non-ozone depleting
• All aluminum micro-channel coil eliminates formicary corrosion
• Piston metering for all 13 SEER matchups
• Field installed TXV accessory for 14 SEER matchups
Recent Intertherm furnaces have "M" or "CMF" numbers.
Either way, you will probably have to contact a local dealer because their website is useless.
Intertherm Gas Furnaces
Mar 19, 2015 | Intertherm 56000 Btu Gas Furnace
My intertherm elec. furnace will sometimes not come on when the thermostst activatesit, I have to trip and reset the curcuit breaker then it will work ok for a day or so, where do I start to look?
It could be several things,a weak transformer,a poor connection, bad relay. I would contact Intertherm with your particular model number. http://www.intertherm.net/
Jan 15, 2015 | Heating & Cooling
Intertherm furnace model # MMHB-070ABHR-06 red light blinks two times
Number of flashes mean different things for diff models. The meanings of those flashes should be posted somewhere on the unit; usually inside front of the bottom service panel. Though you can't truly diagnose a problem by number of flashes they can give you an idea of where to look for a problem. There are a ton of videos and how-to's about furnaces on youtube by real service techs. Most modern furnaces have basically the same set-up and features so don't worry about your paticular brand; but of course that would be the best place to start looking. You could start here to familiarize yourself with your brand of furnace:
http://www.youtube.com/results?search_query=Intertherm+Gas+Furnace+&oq=Intertherm+Gas+Furnace+&gs_l=youtube.12...62316.62316.0.63907.1.1.0.0.0.0.202.202.2-1.1.0...0.0...1ac.Ko9QBdxK6OM
And then here:
http://www.youtube.com/results?search_query=gas+furnace+won%27t+light&oq=gas+furnace+won%27t+light&gs_l=youtube-reduced.3..0.5619.10061.0.11544.11.5.0.6.6.1.741.1982.0j1j2j5-1j1.5.0...0.0...1ac.1.5-0zJyxNMEo
Hope this helps.
Dec 21, 2012 | Heating & Cooling
When I turn on my furance or ac the blower is always on even though the fan is set to auto. When it is on heat it never gives off any hot air, so it never warms up the house. I had someone look at it and...
If this is a mobile home furnace they usually have a two stage gas valve. Generally they just have a delay in opening fully and are convertable from L.P to natural gas or vice versa. It is a possibilty that the gas valve is bad. If so it will have to be replaced. First I would have someone check your thermostat to see if that is what is causeing the blower to run . does the burner ever light? I wouldsuggest that you hire a service tech. who is knowledgable on intertherm furnaces. I don't recommend anyone who is not trained to change gas valves,because of safty concerns. I hope this helps you some. Thanks
Nov 12, 2010 | Intertherm Heating & Cooling
I have a suburban lp furnace and duotherm air/heat pump roof unit. duothern thermostat. 20 amp breaker kicked ( reset breaker) & furnace quit. NOW furnace fan comes on but does not light, and the front...
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Jan 23, 2010 | Dometic Rooftop RV Air Conditioner
Disconnect assembly has overheated and needs replacement. where can I find a new puul-out disconnect assembly for my intertherm furnace model FEH-015HA-03
Those parts are readily available. You can get them at intertherm.com or google hvacparts.com and have your model and serial number ready. You are talking about the pullout at the bottom left of the unit correct. If you have a breaker within six feet of the pullout you can remove it. But be very careful and turn off all power before you try.Rus
Dec 04, 2009 | Heating & Cooling
My blower motor will not stop running,and my ignitor doesn't light.
I am assuming you are talking about a Natural Gas or LP furnace. The blower motor is powered by a separate 120 volt circuit, so flipping the 240 volt breaker for the furnace will not shut it off. There should be a regular light switch at the furnace that will turn off the blower for servicing the unit. When you take the cover off the unit, there should be instructions on how to re-set the igniter. If it won't re-set, try shutting off the gas for a few minutes, then turn it back on and then reset. If none of this works, and you can't find the owners manual, call a service technician.
Feb 22, 2009 | Electric Circuit Breaker Kit for Furnace
I have an Intertherm heat pump model number E1EH-010HA. Last night we had a bad storm and our electricity went out and we had a water leak, now out heat pump isn't working. There is power to the...
Your furnace will either have circuit breakers or fuses at the bottom in the panel below the blower. Also, there MAY be fuses in the disconnect box outside that gives power to the heatpump. Intertherm furnaces are famous for leaking water onto the left side of the electrical panel in the furnace which is also convieniently where the low voltage transformer is located. If you consider yourself electrically competent, check to see that you are getting 240v to your transformer and if you are the check to see if you are getting 24v out of the transformer. If you can't find the problem in any of these steps, I would recommend contacting a qualified professional to check the system out.
Jun 18, 2008 | Intertherm Heating & Cooling
Intertherm gas furnace model number m6bb070abfc01
Check for a open limit switch caused by a dirty filter or poor air flow
Dec 24, 2007 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
