Question about Epson L800 Ink Tank System Inkjet Printer 220V
Ink & paper light flaxing
Ink indicator & paper indicator flass
Canon iP2600 Printer yellow light flaxes message says an ink cartridge is not installed properly
have you tried cleaning the printheads ?
There is an option for cleaning head in printer's properties : select this and you will be able to clean printehads for the canon iP2600
Jan 19, 2012 | Canon Pixma iP2600 Photo InkJet Printer
I replaced my black cartridge and now my ink/paper light remains lit and when i press it, after a few noises, the green power light begins to blink. i have recently replaced the color cartridge as well.
It is important for you to post the make of your printer. Anyway, it sounds like your new cartridge is faulty, which is not unusual. First of all, turn your machine off, unplug it, wait a minute, then plug it in and turn it on. If the problem is still there, try another new cartridge. If the problem goes away, get a refund for the one you just replaced.
Feb 17, 2011 | Office Equipment & Supplies
Power light on my printer wont stop flashing, causing it not to print
Is it possible that it's out of ink or has a paper jam? On certain printers, the power light blinking is an indicator of a problem - no ink, low ink or paper jam. What kind of printer is it?
Oct 07, 2010 | Office Equipment & Supplies
I have never had a problem with this printer until now. I have installed new black & white as well as colored ink, but the power & paper lights flash, and both of the ink-out lights stay on. The...
Sad to hear that mate. I've still got mine and it works like a dream. I can leave it for years without printing anything and after a few head cleans it still prints like new.
Try and get another one because its that good and replacement ink costs
Sep 21, 2010 | Epson Stylus 880 InkJet Color Printer
Red paper and ink lights blinking
red paper light is blinked as it is indication that plz insert paper in your printer, and ink light blinks because your printer is low on ink, kindly get your printer cartage refilled.
Mar 19, 2010 | Epson Stylus 1400 InkJet Photo Printer
My red lights are both flashing and printer will not responed
Both red lights flashing? One should be for paper jam and the other for low/insufficient ink. I presume this is a deskjet/injet printer. The combination of these two lights flashing usually indicates a more serious issue rather than just low ink or paper jam. It is indicative of incompatibility of ink cartridge. After a while some cartridges just could become incompatible with the machine. All things being equal (i.e. no paper jam issue) a replacement of your ink cartridge will resolve this issue. Just get brand new ink cartridge/cartridges. It is usually ok to replace only the one that has become incompatible. But the issue is you need to troubleshoot to determine. You may not have the resources to do this, so better to replace both or replace one-by-one.
Sep 15, 2009 | Epson Stylus Photo R260 InkJet Printer
Epson Stylus Photo 1270. All lights flashing. Whats wrong and how can I fix it?
Hi Guys
I had the same problem with all lights flashing nothing working, happened after a panic power shut down. As with peter after the paper button was released, printer lit up like a christmas tree again. I played around with the button combinations and found that holding down the ink button instead of the flashing paper button cleared the problem. Great tip guys saved me a lot of money. cheers me dears clive.
Mar 02, 2009 | Epson Stylus Photo 1270 InkJet Printer
Printor indicator brinking and paper light is always on
Printor indicator light is brinking and Paper indicator light is always on and never disappear even if I feed the paper and push the paper button
Nov 16, 2008 | HP Business Inkjet 1000 - Printer - colour...
LIGHT FLASSING CANT PRINT
Error 50: Purge cam problem. mfc/dcp has to be taken to service. No chance to fix it by yourself. sorry!
Mar 29, 2007 | Brother MFC 210C All-In-One InkJet Printer
Epson L800 Ink Tank System Inkjet Printer 220V Logo
27 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
