Question about Kubota Garden
Kubota L 3300 rear PTO will not engage when very cold weather solution please
Cannot force the engagement lever any further If I operate the tractor drive it around for 15 minutes or so then the PTO will usually engage it works well in warm weather please advise thanks
  • 4 Answers
Try using a lighter gear oil - some oils are thicker in really cold temps - like molasses while its warm drain it and use a lighter grade, - check the manual and go with a thinner type - ask local car parts store. sometimes the manual will give a type for colder weather. Good luck
Posted on Dec 01, 2014
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
wadembly
  • 462 Answers
SOURCE: Electric PTO on 1500 series Cub Cadet won't engagewithengine hot
its the electric clutch on the engine that engages the belt to run blades check the centrifical clutch or electric clutch
Posted on Jun 28, 2009
  • 95 Answers
SOURCE: Craftsman 26hp Garden Tractor PTO not working
If you changed the belt make sure it did not interfere with the wire that runs from the pto clutch, sometimes that belt can rub on the wire and wear through it,also if you had the clutch off make sure you aligned the steel retainer bolt that sets in the alignment hole on the pto clutch,this keeps the clutch from spring when disengaged if you don't get that pin through the hole in clutch it can push on the clutch and bind it.Also it may be possible to plug that pto switch in backwards.Also if you jumped the fuse out it may now have burnt the switch or wiring somewhere.
Posted on Jul 30, 2009
mickey813
  • 472 Answers
SOURCE: Blades will not disengage
SOUNDS LIKE THE CABEL IS BAD IF IT HAS ONE OR THE ENGAGEMENT IS BENT
Posted on Oct 08, 2009
Testimonial: "This is what I concluded too. I have ordered the part, and we'll see."
wireguy212
  • 1627 Answers
SOURCE: JD 6400 tractor, PTO light flashes when engaged
The most likely problem is the pto solenoid valve on the rear of the tractor.It could be the speed sensor but you won't know until you get the codes read by the dealer.I have had to replace the b.c.u. for this problem but it is not common.
Posted on Oct 20, 2009
PTO lever engages in the wrong position in a Kubota ZD323.
Check and make sure that any links are not bent and make sure that the switch that engages the PTO is not out of adjustment.
Jul 14, 2016 | Kubota Garden
I have a kabota tractor and the Pto will not engage on the bush hog
pto is on the tractor, not on the bush hog, if it won't engage you have pto problems on tractor, needs to be serviced
Dec 01, 2015 | Kubota T1600H Mower tractor
Kubota F3680 stalls when PTO is engaged
there is not enof power so olter the tick over
Jun 28, 2015 | Kubota Garden
Why wont my john deere d140 move when I ngage the double foot pedal
The drive belt may be broken, or it may have slipped off a pulley.
Aug 03, 2014 | John Deere Garden
Ford 5000 pto
i believe the lever is on the left side that operates the pto. on some models it will have a plate stating its the pto, you'll have to start the tractor, and engage the clutch, then engage the pto, and release the clutch. Others you simply engage the pto once you've started the tractor
Jul 17, 2014 | Garden
How to operate pto on ford 5000 tractor
There is a lever on the left side of the tractor next to where your left foot is on the foot rest. It should move to the rear of the tractor to engage the PTO and toward the front to disengage. Hope this helps
Jul 17, 2014 | Ford 5000 Tractor
PTO CONTROLS. How do you engage and disengage PTO.
The tractor is not a 6300 is it.If it' not you need to adjust the cable for the p.t.o. until it will stay down.Don't turn the turnbuckle too much at a time because there is a fine line between the won't engage and the won,t disengage adjustment.
Sep 06, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
John deere 2010 tractor. pto grinds and wont engage
Mar 11, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
157 people viewed this question
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
