Question about Water Heaters
My boiler comes on and then shut down the plot light up then go out.
  • 352 Answers
You did not provide any information on the boiler so I cannot provide a lot of help. What ever device senses that the flame is lit is not working. It may only be dirty. You should call a company that services boilers and schedule a service call.
Posted on Nov 30, 2014
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Boiler ries to fire on heating or hot water but then shuts down after 10 seconds to F1 with the flashing red light, any ideas. clearly same principle as any boiler but I'm looking for someone who has...
that would indicate that the boiler is not firing up
If oil fired, been there done that
it is out of oil
the oil filter is clogged
the nozzle could be clogged/burned
the igniter wires need adj/replacement
if gas fired - similar issues but no experience
Dec 08, 2014 | Water Water Heaters
I have a halstead finest gold combi when I turn the boiler on the boiler goes into its ignition sequence when it comes to ignite the boiler fires but after the igniter stops the boiler cuts out completely...
Difficult to get too specific without knowing if you have gas or oil. Also, I am going under the assumption you mean the burner shuts down, not the whole heating system. That being said, all heating appliances have whats called a safety curcuit. Each control has the ability to shut down if certain critera are not met. There is a sensor that senses light down the blast tube. If no light is sensed in a predetermined time period, then the sensor cuts power to the burner. This stops delivery of fuel so if it does ignite you wont blow up.
(I suspect that the ignitor and burner shut down simultainously.)
It may be the sensor (cad cell eye) is doing its job, however why is the question. Could be a number of things including the fuel delivery, ignition, improper air adjustment, etc.
No qualified professional should diagnose a problem unless they are in front of the appliance. I recommend you find a licensed qualified heating techician. Hope this helps.
Feb 04, 2013 | Water Heaters
Water to hot for gas boiler boiler gos off
It could be dyslexia, but I think you want to know what may be wrong with your boiler in this case!
This is a VERY old design. The diaphragm is on the water section, this operates a switch to turn ON the pump, and a further device causes the diverter valve to divert boiler water from CH duty to HW duty.
From your description it appears that the boiler is shutting down on internal boiler water temperature (too high), your 'briefly too hot' HW symptom may be caused either by the boiler side of the secondary heat exchanger being blocked/caked in sludge, OR the DHW side of it being scaled. Either way a new or replacement (descaled) secondary heat exchanger MAY inprove things. It's not easy on these old clunk-pots, and EVERY disturbed seal will subsequently leak, so get a good supply of o-rings and fibre seals before you start ("you" being the competant fitter you employ)
Dec 20, 2012 | Water Heaters
Ferroli boiler error code A3
boilers need a certain amount of water pressure to operate as specified--there may be a pressure regulator valve, allowing a certain amount of water to your boiler, and when water is drawn elsewhere, there may not be enough getting to the boiler---this is one possible solution, but there are easily 20 more, and that is where a trusted plumber is worth it's gold...very difficult to diagnose most plumbing problems without being onsite
Mar 03, 2010 | Water Heaters
Halstead boiler reluctant to stay on
next time it turns off let it cool and clean with a cotton swab with rubbing alcohol after brushing.
Aug 31, 2009 | Water Heaters
I have Crown Tobago boiler that cut off two days ago
Possibly due to a power failure, control unit needs to be reset. Hit reset button. Hold for 30 seconds. Also no fire typically due to nozzle clogged, no fuel which means control will shut down. Water in fuel will also shut boiler down. Clogged filter will decrease fuel flow. Electric eye face is dirty which will also shut it down. If you have a two line system, open up bleeder and see if you get a good flow. Check electrodes for burned ends or out of gap specs.
Aug 04, 2009 | Water Heaters
Boiler shuts down after an hour or so irrespective of heat level
Why did it shut down?Hi tempture which would be the hi limit,or like of water?Is there still power to the boiler?
Mar 16, 2009 | Water Heaters
Boiler kept shutting down.Re-starts but drops not keeping pilot.
there ic a low water cut-off on all boilers, also a over pressure switch that can shut down the unit. You should really call a service company out to look at the problem due to the potential of a serius problem with thee unit and see whats is the problem with the unit. Boilers can explode and do allot of damage to a person and property if this happ[ens. GOod Luck
Jan 07, 2009 | Water Heaters
Water heater pilot light
it also sounds as though the pilot injector could be blocked so when the boiler comes on it extinguishes the pilot & then when the burner goes off boiler shuts down, or also the pilot rate maynot be set right, so when the main burner kicks in it robs the pilot of the gas it requires.
It could be that, or there is lack of ventilation for the boiler, so you get flame lift off when the boiler fires?
Dec 14, 2008 | Water Heaters
Water Heaters Logo
56 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
