Asda DVD player. Model number dvdhdmi01. I am trying to set up a one for all remote control but can't get it to pick up anything on the manual search method and there is no listing for it in the instructions. Does anyone know the code for this device
    Problem Solver:
  • 8 Answers
Send URC number from inside the remote control battery cover, with the brand name of the remote. Most manuals and codes can be found at http://www.remotes.com/ if they're original equipment. One for all is probably a universal, but they share links to them also. That also includes if your remote is compatible to the DVD. If not compatible, try a Samsung DVD code.
Posted on Dec 02, 2014
SOURCE: I'm missing the instruction manual
1. Manually turn on the component you want the remote to control (TV, VCR, DVD, satellite receiver or cable box). Note: If you press an invalid key during the Manual Code Search, the remote does not respond and the LED indicator light does not blink. If you do not press a valid Manual Code Search key (TV, VCR, DVD, SAT·CBL, ON·OFF, GO BACK), the search times out after two minutes. When the search times out, the LED indicator light blinks four times and turns off. The last programmed code under that component key is retained. 2. Press and hold the component key (TV, VCR, DVD, SAT·CBL) you wish to program. The LED indicator light turns on and remains on. 3. While holding the component key down, press and hold the ON·OFF key. The LED indicator light turns off. 4. After holding down both keys for three seconds, the LED indicator light turns back on. 5. Release both keys. The LED indicator light remains on. Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control. 6. Press and release the ON·OFF key repeatedly until your component turns off. Each time you press the ON·OFF key, the LED indicator light blinks, and the next code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code. (If it cycles through and the LED indicator light blinks four times and turns off, all codes have been searched. The Manual Code Search method is exited.) Press Stop when TV turns off.
Posted on Aug 13, 2008
SOURCE: dmtech remote control programming codes
I have been looking for the same codes myself and all I have found is: 0157 0159 0335 1994 2024 2031 0067 0312 0910 0208 0586
hope one of these work for you.
Posted on Dec 31, 2008
SOURCE: RCA Universal Remote RCR4258
ive got the same problem.
Did you ever solve it
Posted on Jun 02, 2009
The Jed
  • 42 Answers
SOURCE: cant locate a instruction manual for a rca guideplus remote
This manual (downloadable ~4.5Meg) has instructions for programming this remote on page 24 (or thereabouts):
http://tv.rca.com/RCATV/Assets/pdfs/F19625_1546045A_IB_e-00.pdf
A general guide on programming an RCA universal remote is on YouTube at:
http://www.youtube.com/watch?v=5YHGdPOy5dc
Hope this helps you.
Posted on Aug 22, 2009
  • 21 Answers
SOURCE: I Have a Thomson Universal
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/thomson/roc3205-manual.zip&area=other
Posted on Feb 06, 2011
Cant find the input button.
You should look for the user manual for your device. It should provide guidance to controls and cables. That guide may be on the brand site where you would try to track it through the model number. It is usually helpful to post the device, brand and model number so that a volunteer may provide better feedback. That said, here is a bit of information that may help. The remote with your TV may have a menu button which permits you to access settings. There are a number of "cable" choices within those settings. One permits input from the DVD player. Another permits input from cable/DISH TV. One permits input through a special high quality cable HDMI. If you pick the wrong one, you do not have a picture. You select these by scrolling with the up and down arrows and hitting the OK button. Let's say you find the selection for the DVD. You have to remember that you have been changing settings on the TV. Your remote will not control your DVD player (or DVR) unless you have pressed the button on the remote that changes it to a remote for such. Those buttons are usually at the top. And even if you do, the remote may still not control the DVD/DVR unless it has been programmed for that brand/model of DVD/DVR player. And you have to do that through the settings button on the remote. That usually requires you have the manual that provides the codes for a long list of products. But you may be able to use physical buttons on the player meanwhile, after you have setup the TV to receive the signal from that device as mentioned at the beginning.
Oct 14, 2017 | Televison & Video
Unlocking my DVD player
some others
new model pacific 1002mk2 (ASDA) using remote.;
press open on remote
press clear
press 1-3-6-9 Then 0(for multiregion)
Press close
It's important to note that you will not see anything happen on screen or display!
The buttons are small,so you'll have to be precise
1. PUT A REGION 2 DISC IN PLAYER
2. WHEN IT IS LOADING UP PRESS "SETUP"
3. PRESS "7" FOR MULTI REGION
4. PRESS "PAUSE/STEP"
5. PRESS PREVIOUS " |> "
6. PRESS SETUP
YOUR PLAYER IS NOW MULTI REGIONAL.. IS YOU WANT TO SET THE REGION IN STEP 3 PRESS 1 FOR USA OR WHATEVER YOU REQUIRE....
or
switch on.on the remote press "open/close",0,1,2,3,open/close and it plays straigt away. but nothing is shown on the screen.
or
It's true - a quality DVD player from Asda for £59.95. Highly recommended. This 1359 hack worked with my Pacific 1002 purchased March 03.
Note. There is no on screen display or any indication on the machine when entering the hack.
Switch machine on and using the remote control only:
1. Press 'open/close' button (the draw should be left open).
2. Press the 'clear' button.
3. Press '1'.
4. Press '3'.
5. Press '6'.
6 Press '9'.
7. Press '0' (zero for multi-region).
8. Press 'open/close' button.
End.
or
1. switch on dvd with remote (leave drawer closed)
2. Press: setup
3. press: 7 (note nothing will happen)
4. press: pause/setup button (again nothing will happen)
5. press: previous/I<< button (nothing will happen)
6. press: Next/>>I button (nothing will happen)
7. press: setup
Dec 05, 2007 | Televison & Video
How do I program a dvd player with the new xfinity x1 remote? The instruction manual does not tell us how.
It is my understanding the xfinity remote is designed only to control comcast set top box and TVs. It also can control audio receivers. It is unlikely you can control a DVD player with it.
At best you could try and use the programming instructions on page 5 of the manual and see if it picks up your DVD player. Otherwise it might be better to use the existing remote controller you have and program the Comcast set top box to it. You need to find the codes from the programming instructions of the original remote control and you will also need to know the model number of your comcast box.
Hope this helps.
https://x1.comcast.net/webportal/assets/pdfs/RemotePairingGuide4.26.11.pdf
Sep 12, 2014 | Televison & Video
I NEED TO NO HOW TO SET UP A ASDA 1 Device Remote Control, Model Number 11-1415
Setup procedure is too much to type in here, and is not practical. If you wish to get more details, check these links. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 04, 2013 | Televison & Video
I'm having problems programing my Philips RC19041006/01 remote that came with a Philips 15pf9936/37 15" LCD TV to work on a Magnavox MDV21001F7 DVD Player
Unfortunately, you will not be able to program your TV remote for the DVD Player. The MDV2100F7 was produced in 2010. Your Philips TV was has a manual with a copywrite date of 2003. Other documentation on the Philips site is from 2004 and 2006. (I am assuming that the MDV2100F7 is your model since no MDV21001F7 is listed at Magnavox or Funai (which made the unit).)
The codes in a universal remote control are only for devices released 6 months or more before the remote was programmed. A DVD player released 4 years later is likely to have a different set of control frequencies.
You need a newer remote or control everything with separate remotes. I wish that I had better news for you.
(The manual for the Philips TV is available from the Philips product site. For the Magnavox DVD player documentation, see the Magnavox (http://www.magnavox.com ) site or the Funai support site (http://www.funai.com/us ). At Funai, search for the model number but leave off the brand. They make units for a number of brands.)
Oct 04, 2011 | Philips Rc1904100601 Remote Control
I need the codes for an ASDA remote control, model no: URC20-D1F
URC20 D1F
Set up by Automatic Search
1. Turn TV on
2. Point the remote at tv and Hold SET and TV buttons at the same time and keep pressed for 3 seconds.
3. The LED flashes and the remote control starts the automatic search.
4.The OFF signal is automatically sent to the tv from the remote control.
5. Once the TV switches off press any button except SET to stop auto search.
6. Switch your tv on using the POWER button.
May 09, 2010 | Universal Remote Control Remote Control
Need remote code for DVD player
From my searches I don't think you will find it. Try going to http://www.sony.ca/view/cic_contact.htm and asking them directly for it. I can't see them saying no.
Sep 11, 2009 | Sony SLV-D360P DVD Player/VCR
DVD MALFUNCTION [MODEL PIONEER XV-DV131 (DVD/CD HOME THEATER]
I have the same problem with my XV-DV333. Search on inet and this came up: "... Pick Out One Of These! But I am unable to select any region using the remote control or the buttons on the player. What do I do? You need to get a Pioneer Service Remote. When you have it you should press: [ESC] [A.MON] [Numbers], where [Numbers] correspond to the region number you want to set. Be aware that you can only set this once, if you set the wrong region number for your area, there is no turning back. " WTF! Am I supposed to get a service remote to get this thing working again. I haven't done anything and it worked before:/
Sep 08, 2007 | Pioneer XVDV830/SDV830 DVD AUDIO HTP...
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
