Fixed my problem: ANSWER 1 was correct!!! SIMPLE FIX:All I had to do was reduce the brightness setting. This fixed it...the first time I did it immediately it stopped...but when commercials came on it started blinking again only with certain commercials because of the brightness on the commercials...so I reduced the brightness setting some more and it no longer blinks! I'm so happy!!
    Scholar:
  • 154 Answers
Glad to help.
Posted on Nov 30, 2014
5 Suggested Answers
SOURCE: Won't turn on.
My Sony KDP is blinking 6 times. My guess is the blinking is a troubleshooting code. We just need to located the chart to describe the blinks.
Posted on Sep 29, 2007
premtech
  • 934 Answers
SOURCE: Power Button Blinking Red
Talli,
The number of blinks, called error codes, is crucial in determining what's wrong with your unit.. In this case the color wheel is faulty and needs to be replaced. In that unit the color wheel assembly is Panasonic p/n# TXFEN01RP4S and is available from many sources for about $390.00 plus shipping.
There are some companies like Tri-State-Module that have taken-up rebuilding color wheel assemblies but I can't be certain that this is one of the brand/models they support. If you can have it rebuilt you might save about half the price of a new one...
For your edification in the future here are the blink codes for your Tv:
1 | Load Shortage
2 | Over Volage
3 | Fan Sos
4 | Main 3.3v
5 | Lamp Disable
6 | Gc3fm-Iic
7 | Gc3fs-Iic
8 | Gc3i-Iic
9 | Color Wheel Stop
If I can help any other way just let me know...
Good Luck!
Bill
Posted on Dec 01, 2007
ctf1800
  • 4402 Answers
SOURCE: No power all of a sudden
im thinking you blew the chips again, i would use sanyo chips from mcm not cheap ones
This is a list of most of the commonly used STK devices and some that Sanyo made that are rarely, if ever, used. I will add links to the data sheets that I have, but some of them are not available. Some of the chips are versions made for a particular TV manufacturer, and Sanyo does not provide data on those, typically. It is generally best to use the same chip that is found in the set. However, there have been newer versions of some of these produced that are identical in performance and superior in certain applications. I will note my recommendations and the logic behind them, but I in no way, nor does HTS, take any responsibility for the accuracy of the information with regard to substitution of parts. Any substitution is your responsibility. I can only relate what I have found to work with parts that I know to be original Sanyo parts.
STK4273 replace with STK4274 if heat sink allows
STK4274
STK4275
STK4278
STK391-110
STK391-120
STK391-220
STK392-010 replace with STK392-040
STK392-020 replace with STK392-040
***The -040 has wider bandwidth and has higher current rating than the -010 and -020. I use in ALL cases to replace the older versions.
STK392-040
STK392-560
STK392-570
STK392-110 replace with STK394-160
STK392-120 Hitachi replaces these with STK394-160, for other sets it may not be a good sub. They have been fine in the Philips sets so far.
STK392-150 replace with STK394-160
***The 394 series replaced the 392 series and is cooler running. The subs listed here are the ones that I know to work in most sets.
STK392-180
STK392-210
STK392-220
STK393-110
STK394-160 (This is my choice to replace the STK392-110, -120, & -150 in most sets and are available in the Hitachi kits in the next post)
STK394-210
STK394-250
STK392-260
STK394-510
Suffixes
-L means bent pins for horizontal mounting
-E means lead free
-HIC in Mitsubishi parts simply means that it is an IC on a heat sink and is irrelevant to buying parts.
Posted on Feb 26, 2008
atelier mj
  • 70 Answers
SOURCE: tv stopped working and red light started to blink
this problem can be solve by changing the 2 IC of convergence. part # STK 392-110. It would take 30 to 60 minutes to open change and reclose.
Posted on Apr 23, 2010
I have an iphone A1303 and its charging and it shows the apple logo but its failing to turn on how can i fix that problem?
I don't know answer but one time, the screen contrast on my phone turned itself way down so I thought it would not turn on. Fixed it by going to settings - display & brightness and turned it up. Maybe your phone has same problem.
Have you called your phone carrier? Seems like they should be able to help.
Apr 22, 2015 | Apple Iphone A1303 16gb
Colors will not converge on my RCA SRS Focus, model D52130. When I make an attempt to automatically converge, it says to reduce the light in the room. We even covered up the screen with a blanket at...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 10, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
When viewing images on the LCD display ,pictures with White or bright parts to the image the display flashes between White and black is this a setting issue .the camera is a Dx 40x
You're seeing blown-out highlights. These are the portions of your picture that have been so overexposed that they've gone pure white, losing all detail. This is generally considered a bad thing and so the camera is warning you of that. Of course, the camera doesn't know what kind of effect you're trying for and thus it's just a warning. The correct fix in most cases is to use exposure compensation to reduce the exposure and bring back the details. This risks losing details in the shadows as they go pure black but that's not considered as bad. After all, we don't really expect to see much detail in the dark.
That was the long answer. The short answer is, repeatedly press up/down on the multiselector to cycle through the different views of your pictures.
Dec 18, 2010 | Nikon Cameras
Why is my screen sooooo bright? Over time, the screen has gotten very bright, I don't know how to fix the problem and would appreciate some help.
To adjust the brightness of LCD screen, hold down the FN key, repeatedly press the arrow keys to increase brightness. Or, hold down the FN key, repeatedly press the arrow keys to reduce the brightness.
Aug 13, 2010 | Dell Inspiron 2200 Notebook
Screen is too bright, can't fix it
For some nokia mobiles you cannot reduce the brightness of the screen. They have the default brightness settings only.
thanx
Jul 12, 2010 | Nokia 6111 Cellular Phone
Flashing display
You're seeing blown-out highlights. These are the portions of your pictures where you've lost all detail due to overexposure. That's not necessarily a bad thing, but usually is. The correct fix in most cases is to reduce exposure and shoot again.
That was the long answer. The short answer is to press up/down repeatedely on the multiselector to cycle through the different views of your photo until you find the one you want.
Jul 01, 2010 | Nikon D60 Digital Camera with 18-55mm +...
My hp 7540 crt monitor menu displays automatically blinks frequently. please hele me resolve this problem. it stays fixed on the screen, unable to do any work.
<div style="FONT-SIZE: 14px; PADDING-TOP: 10px" itxtvisited="1"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadBox1_lblProblem" itxtvisited="1">my hp 7540 crt monitor menu displays automatically blinks frequently. please hele me resolve this problem. it stays fixed on the screen, unable to do any work.</span> </div><!-- answer --><!-- from fixya rte -->
May 12, 2010 | HP S7540 17" CRT Monitor
My sanyo does not work
"Fix it."
This is what you posted as a solution to my problem.
Is this how you fixed your tv problem?
I'm guessing not since you posted your problem here. Your problem sounds like a broken tv, mine is a simple setting in the video menu.
This is a stupid answer and a waste of time. Don't post a bogus solution mongoloid.
Aug 17, 2009 | Televison & Video
Dark shadows similar to fingers of thunderstorm cloud have appeared on the display and worsened over time. They are fixed in position. Is there a fix? Is it time to replace our 2 1/2 year old Protron?
Not fixed but bearable by increasing brightness. I'll live with it until it gets worse then, probably, replace the unit. One other symptom for anyone interested is a dip in the top edge of the display just above the area of thunder cloud finger.
Jul 23, 2008 | Televison & Video
TV turns off when bright colors displayed
Yes your fix is in the threads here, I have answered many of the question on Mits as of other sets, you have a problem with this set Shutdown at bright scenes, it is a known problem and the answer lies here on threads, just search. This keeps from having to keep repeating the same answer. Thanks, hope this helps!
Dec 16, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
