I have a genx mp4 player model-gmp4-01. the moment i connect it with my pc through usb it gets charged automatically but i am not able to access its files like removable disk. also the windows does no
I have a genx mp4 player model-gmp4-01. the moment i connect it with my pc through usb it gets charged automatically but i am not able to access its files like removable disk. also the windows does not show any message of found new hardware. i have windows vista os, please help......
    Sergeant:
  • 399 Answers
The USB cable is probably strictly a charging cable, not a sync cable or a dual charging/sync cable, so it will only charge the player but not make it visible to/accessible by your computer. You can get a sync cable or if you already have a multi-port USB hub that you use to connect devices to your computer (mouse, flash drive(s), etc.), try connecting the player through an available port on the hub.
Posted on Dec 21, 2014
  • 476 Answers
SOURCE: philips mp3 player sa6045
This player shows the "Do not disconnect" message when it is doing something critical such as transferring tracks or updating firmware, which could corrupt the player if disconnected part way through.
The player shows the "OK to disconnect" when it is idle. As the message says, it's ok to disconnect, as the player will not corrupt if disconnected when it is idle.
These messages mean that the player does not need the "Safe to remove" procedure.
It is ok to disconnect part way through charging. Also the player will condition the battery once it is fully charged, so it's ok to leave it charging.
Occassionally batteries can "memorise" when constantly disconnect and reconnected without fully charging and discharging. To help prevent this, fully discharge the player (leave on until dead) and fully charge and condition (leave charging for about 12 hours) every couple of weeks or so.
Posted on Feb 12, 2008
  • 6 Answers
SOURCE: Found New Hardware MTP Device. Pop-Up
here is the solution:
http://amritbera.blogspot.com/2008/11/mtp-problem-solved.html
Posted on Nov 26, 2008
SOURCE: mp4 ipod not detect driver
free download firmware Ipod ixus nano 2
Posted on Dec 04, 2008
  • 79 Answers
SOURCE: How to put the songs in the MP4 Player
If it has a reset button on it press it(look carefully it will be very small),if it doesnt,type the model number into google and see if you can update the firmware.good luck
Posted on Apr 10, 2009
SOURCE: mp4 player ikasu
yes drag and drop or paste files when you have opened it in my computer
Posted on Apr 21, 2009
Mp4 player not working
Check your MP4 player's system requirements.
Some MP4 players are only capable of working with certain operating systems and hardware, so refer to your player's documentation to ensure it is capable of functioning with your PC.
Change the USB port your MP4 player is connected to if you have confirmed your PC can function with your MP4 player.
Disconnect other USB devices, and try connecting your player to another USB port if you are still having problems.
Try restarting your PC if it is capable of working with your MP4 player.
Restarting your PC resets non-functioning USB ports, which may be your problem.
Make sure your USB cable is connected properly.
If your player requires you to install drivers, make sure you install them.
Try connecting your player to another PC to see if the new PC recognizes it.
If it does, chances are your computer does not support the hardware necessary to run your player.
Reset your MP4 player if your PC is still unable to recognize it.
Resetting your player varies depending on the manufacturer and model, so refer to your player's documentation.
Contact your player's manufacturer if you are still unable to get it to work with your PC.
http://applestore.altervista.org/mp3mp4.pdf
Aug 25, 2013 | Intel Computers & Internet
I have a 4GB Craig MP4 player and earlier today it was working perfectly fine. It turned off automatically and later I went to turn it back on to listen to it and it won't turn on or charge when connected...
Quite often there is a fault with USB charging. Do two things to confirm its not totally broken. First try another USB charger. Second and better- charge from a power outlet at home.
kc
Mar 09, 2011 | Audio Players & Recorders
Hae bought 2gb Veg MP4 players. Can add music files to players when connectd to computer. But have tried to charge on numerous computers and they won't charge. Anybdy got any ideas or know how to fix? ...
Try to charge it via a battery charger. Change a USB cable to connect PC to make sure the USB cable is good. And change PC to charge the mp4 player. Compare the results, you will know where the problem is.
Jan 09, 2010 | Umax Vega108 MP3 Player
How can i charge my player
Your player should have came with a wire which connects your mp4 player to your USB drive in your computer - this is probably the thing that helps you input songs/videos into the player.
On the packaging/instructions of the player, they should say whether your player can be charged by the computer. If yes, then just plug the wire (mentioned earlier) into the USB drive and it should be recharging automatically.
Remember that the player is getting the energy from the computer - if yours is a laptop, remember to plug in the charger!
Hope this helps :)
or
just leave it in the usb slot (usb 2.0, because 1.1 won't work) and it will charge itself if its enabled to charge by the usb slot.
Jun 23, 2009 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
My pc accepts mp4 hardwear momentarily then rejects it
A connection is possibly loose, seems like a hardware problem that would require service. Check the usb connector and its pins.
You have tried it on two other pcs? what was the result there did it work? If it worked on both fine, then the issue is on your computer and not on the mp4 most likely.
Please clarify.
Jan 30, 2009 | Audio Players & Recorders
MP4 Blues.............:'-(
If you're only using the port to charge and not to link data to the mp4 device, then we might assume that the chargeable battery in the mp4 device is no longer good. If you have run the battery down, way down, you may not be able to recover it to a charge again. Leaving the device on till the battery goes too far down will do this as well.
If it's a data issue where you can't connect, then I suggest you go in the the device manager on you pc and delete the usb devices and let the computer 're find' your mp4 player. You may have the same mp4 player numerous times in the usb section and the pc has given up on the connection.
Apr 21, 2017 | Coby MP-C7085 MP3 Player
Av1 I - scream mp4 player
Replace battery.Most media player batterys only last 12 months.RICHARDM69
Oct 05, 2008 | LG LMG-100 Digital Media Player
Can't get the usb port to accept the mp4 player.
Switch on your Mp4 player and connect it to the usb port. Your computer should produce a message "New Hardware Detected". If you don't get such a message either the lead, the usb port or the Mp4 player is faulty.
If you do get such a message, if your computer can't find and instal the right drivers automatically there will be another message or the Found New Hardware wizard will appear. By following the onscreen instructions your computer should be able to search the internet for suitable drivers.
In any eventuality, when connected the Mp4 player should appear in the My Computer window and if it doesn't it isn't connected.
Jun 26, 2017 | Samsung YP-T9JQB Digital Media Player
Tevion Mp4 player keeps connects and disconnects during downloads.
Well i think maybe your usb cable might be loose or the mp4 player is damaged. I really want one though...
Jul 31, 2008 | Audio Players & Recorders
101 people viewed this question
 Grubhead
Grubhead
