Question about Dell Series 11 948 Print cartridge Standard Capacity 1 x black
How to disassemble a Dell 948 printer?
Taking the white cover off.
    Top Expert:
  • Dell Master
  • 74,482 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to some popular brand printers and other devices are given in detail with illustrations.
Posted on Nov 30, 2014
How do I disassemble a Dell 948 printer?
Ron Worth,
Dell does not have any disassemble instructions for the printer. You can click the link below for viewing the online manual.
Dell 948 AIO Printer
http://dell.to/1vAFZ3R
Thank You,
Dell-Jesse L
Dell Cares
Dell Social Media and Communities
Nov 30, 2014 | Dell 948 All-In-One InkJet Printer
Printer message cover open
There is no replacement part available from Dell. Temporary fix is removing the hinge spring under the small concave white plastic piece (you can remove that also) allows the cover to close. The nub under the cover has to press a "lid closed" switch which is not possible if the lid hinge is broken.
See this link:
http://www.fixyourownprinter.com/forums/inkjet/66032
Jul 27, 2011 | Dell 948 All-In-One InkJet Printer
Can't download application 948 Dell All in one printer
You can download the application from this link
http://download.cnet.com/Dell-AIO-Printer-948/3000-2116_4-185937.html
May 26, 2011 | Dell 948 All-In-One InkJet Printer
My Dell 948 printer produces a thick black line on documents
Leave the cover up and run a 'copy.' Look closely at the fluorescent scanner light and note if it seems equally bright from end to end.
If it does, the photo-assembly that acts as an image receiver is probably sick.
If it is, with the labor cost and potential non-availability of parts, you might be better off replacing it unless still under warranty.
Jul 02, 2010 | Dell 948 All-In-One InkJet Printer
Clear Paper Jam message on my Dell 948 nAll in One
press cancel button,, for 30 seconds, it will reset, either, press, on/ off button once.
Jan 17, 2010 | Dell 948 All-In-One InkJet Printer
How to remove glass on dell 948
You have to lift the document feeder up and out of the slots in back.
I would also recommend removing the screws from the back cover and taking it off. Then take the two front screws off on the top holding both the ledt and right top covers. Remove those covers, and also remove the one screw holding on the plastic strip along the back of the glass.
Then remove the glass. Be careful cleaning the scan head. That lamp is very fragile.
Dec 30, 2009 | Xerox WorkCentre XL2130f Laser Printer
Dell 948 printer. Black(2 inch) Vertical lines when I print
You need to check the glass for any white-out or other smears that don't belong, if the glass is clean then the scan assembly has elements that are burned out which will cause dark streaks.
Jun 30, 2009 | Dell 948 All-In-One InkJet Printer
Paperjam when paper doesn't even go through the printer
i guess there might be a torn paper stuck up inside but'll have to cnfm only on opening the cover
May 25, 2009 | Dell 948 All-In-One InkJet Printer
Dell All-In-One 948 InkJet Printer
This might not be the issue but I had a similar problem when I first got the printer. Open the top-( where the ink is loaded), look at the back on the right there is a small bus cable ( flat wire usually white) make sure it is pulled in all the way into the top. Be carefull as the prongs can break. This took care of my clicking clacking when the machine came on.
Good luck
Nov 14, 2008 | Dell 948 All-In-One InkJet Printer
Dell Series 11 948 Print cartridge Standard Capacity 1 x black Logo
62 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
