Question about Skil Switch For 77 Hd77 Hd77m Wormdrive Saws
I have a hd77 worm drive that is blowing breakers we changed the swith and cord and the brushes seemed fine but still blowing breakers whats next? armature?
Could you show us wiring for new switch marquart switch
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
Sound like the coil is shorted to ground. Therefore it blows the breaker.
Posted on Nov 30, 2014
5 Suggested Answers
Asbestos 56
  • 191 Answers
SOURCE: i changed the switch and brushes. Still nothing.
is the commutator (part the brushes push against) all gouged up? What about wire after switch? Also sometimes the plug itself does not make good contact. Pull the switch and move the plug around in the outlet while you have the switch pulled (Watch out it may turn on) Make sure that there is power at the outlet, and try a different outlet.Check all your connections. My guess is the cord.
Posted on Nov 18, 2010
rowdy45176
  • 2176 Answers
SOURCE: I have a 3yr old
I think that you got it right. what I would do is take the armature out and take toa repair shop and ask them to put it on a growler. But after removing look for cut windings and raised commutator bars if either it is bad, also replace the brushes along with the bearings.
Posted on Jan 19, 2011
rowdy45176
  • 2176 Answers
SOURCE: Skill Wormdrive HD77 saw sparks
you have a problem with worn brushes or the armature might be failing. UNPLUG the tool and remove the brushes to check their condition length and look at the face of the brush for any unusual wear. Then look into the brush tubes themselves and slowly rotate the armature for discoloration/raised commutator bars.
Posted on Jun 24, 2011
  • 142 Answers
SOURCE: Skil HD77 that blows breaker
Check the cor first. The switch might have been wired wrong. The old style switch which is an Eaton seithc is wired differen t than the Marquart switch supplied now. An ohme meter will tell you which way the switch contacts work. Another common problem is the field leads will come loose from the rest of the winding and hit the fan on the armature. This can usually be repaired and taped back down so it no longer hits the fan.
Posted on Dec 16, 2011
Why does my skil worm drive saw burn blades
They are blunt. It isn't always easy to tell by just looking.
Feb 15, 2015 | Skil Circular Saw 7 14" HD77 Worm Drive
New brushes are sparking real bad
It sounds like the armature is bad. It should have an even dark ring around the bars of the armature commutator where the brushes ride. If one or two of the bars is discolored above and/or below that it could easily be bad. It could also be pitted between a couple of bars. Normally the space between the bars is even all the way around and nice and "clean cut" looking. If you have access to an armature growler you can test the armature. Hope that helps.
Jan 21, 2014 | Skil Circular Saw 7 14" HD77 Worm Drive
Can the cord on a Circular Saw be replaced? By whom?
you can replace it your self . you can cut cord shorter and put on a new plug. @ home depot you can replacement parts
Nov 15, 2011 | Skil Circular Saw 7 14" HD77 Worm Drive
What kind of oil do I put in?
They sell tubes of oil for the saws. If you can't find it You can probably use 90weight gear oil. the stuff in the tube smells about the same.
Sep 05, 2011 | Skil Circular Saw 7 14" HD77 Worm Drive
Skil HD77 that blows breaker no matter which plug in I use. This saw was bought on e-bay and does not appear to have abused except for new plug on very short cord. I checked end of plug and it appeaers to...
there is a direct short somewhere, recheck the plug end for correct wiring and if OK then it is in the cord or the motor itself, I would think the cord or plug first.
Sep 01, 2011 | Skil Circular Saw 7 14" HD77 Worm Drive
No power when i squeeze the trigger on the hd77
Troubleshoot the problem. It could only be a few things: 1) defective trigger/switch, in which case you can replace it by getting the part from a specialty tool store; 2) the cord itself, either where it plugs into the saw or at the plug end there may be a loose wire; 3) you've accidentally cut or nicked the cord--easily done--and there is a severed wire.
Jul 31, 2011 | Skil Circular Saw 7 14" HD77 Worm Drive
Skill Wormdrive HD77 saw sparks are coming off the brushes
Jun 23, 2011 | Skil Circular Saw 7 14" HD77 Worm Drive
ARE THESE SKIL SAWS DOUBLE INSULATED? YOUR QUICK RESPONSE WILL BE GREATLY APPRECIATED.
Look for the double insulated "square within a square" asbestos_56.png it should also have the words "double insulate somewhere.
Dec 09, 2010 | Skil Circular Saw 7 14" HD77 Worm Drive
When I depress the switch the blade moves 1/60th of a turn. There is power to the saw. I changed the bushes and switch and there is no difference.
I would like you to make sure that the brushes are indeed touching the armature. It is possible that the brush holder is not allowing free brush movement through them, and that would cause this problem. If that checks ouf fine, I would make sure the cord is in good condition, and you are certain you dont have an intermittant break in the cord. Your next step will be checking the condition of the field leads, and continuity of the bars on the armature. Pull the brushes, and remove the 4 long bolts that hold the motor housing on to the saw. There will be another bolt that connects the housing to the upper guard. After you slide that back(if you meet resistance it is the 608 bearing on the back of the armature). The armature will stay fixed to the rest of the tool. You will then take a continuity tester and test from one copper communtator bar to another, until you have tested them all. I would imagine you have a dead bar on the armature, and you will know this when you test between it, and another bar, and there is no response from the tester. Let me know if this works. If not, please post back.
Dec 04, 2010 | Skil Circular Saw 7 14" HD77 Worm Drive
Skil Switch For 77 Hd77 Hd77m Wormdrive Saws Logo
114 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
