Question about Zanussi Washing Machines
Dryer on zanussi zwd1471w not working,new element has been fitted
New element fitted
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
Most often that I have found that when a dryer doesn't heat it's not the heating element. But more often one of the temp limit switches. Either the upper or lower limit. An ohm meter can check these.
Posted on Nov 30, 2014
3 Suggested Answers
apart4u
  • 213 Answers
SOURCE: how to fit a door seal on zanussi washer dryer WDT 1085
Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Posted on Jan 19, 2010
  • 353 Answers
SOURCE: I have a zanussi zwd1471w,the spin cycle will
check your filter
Posted on Jun 11, 2010
Replace Zanussi ZWD12270W faulty dryer heating element
Just for the record, the heating element went on mine too and I'd only used it less than half a dozen times. The engineer said that it went because it hadn't been used enough (it gets moisture inside somewhere). He said if I didn't use it I would have the same problem after it had been replaced. So make sure you dry something every couple of weeks (he said at least once a month).
Nov 30, 2013 | Zanussi ZWD12270 Front Load Washer / Dryer
My Zanussi TCS 65w tumple dryer will not heat
sounds like it needs a new heating element
Jul 16, 2012 | Zanussi Dryers
The element has blown on my Zanussi ZBF860 oven. I
You should be able to remove the element without removing the oven. Open the door and remove the back panel, normally 4 screws. This will expose the element. Then it should be 3 or so screws holding the element to the frame, remove these and slowly pull the element towards you carefully, then remove the 2 wires from behind and make sure they don't fall back into the oven as you will need to remove the back panel to get them. Then reverse process to install new element. Hope this helps.
Mar 15, 2011 | Zanussi ZBF360 Electric Single Oven
Fan in main oven boken
Sounds as if your oven heating element has failed. You need to fit a new one.
Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
Dec 31, 2009 | Zanussi Ovens
Main oven wont work
It is the oven element that has failed
Remove panel at rear of oven compartment, there you will see the element, just undo any screws that you can see and pull the element towards you, carefully detach the wires, but don't loose them inside or you will have remove the oven to get the wires back on.
Fit new element and Bob's your uncle ,you've cracked it.
Plz leave feedback for this solution.
Thanks.
Dec 13, 2008 | Zanussi Ovens
Zanussi TD 4112 W Not warming up
I've taken the back cover offf the dryer and found a burnt connection to the heating element. Will try and repair.
Oct 14, 2008 | Zanussi TD4112W Electric Dryer
Zanussi WJD1667W not drying at all
I've got this machine, and all washer dryers tend to have two heating elements and it sounds to me that the heating element for the drying side of the machine's functions needs replacing. You could probably find a cheap element for the machine somewhere and get it fitted for a small sum.
Let me know if this rectifies your problem
WD Pro
Apr 24, 2008 | Zanussi WJD1667W Front Load Washer / Dryer
Washing Machines Logo
46 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
