Question about Honda Dewalt Dg6000 Generator W/ Gx340 Engine 11 Hp
What could be wrong if the generator cranks up but will not produce power?
  • Honda Master
  • 1,169 Answers
Depends the length it sat unused. Can be anything from the simple loss of magnetize of the alternator's rotor to complete alternator failure.
Posted on Nov 30, 2014
Testimonial: "thanks"
    Master:
  • 373 Answers
Are your breakers tripped? Test the power side of the breakers and if there is no voltage there, then the generator may be shot.
Testimonial: "so replace the breakers possibly?"
Need help with diagnosing generator not producing power
may be a bad breaker or a shorted wiring problem. not generating any power, I would ck. the brushes inside the generator.
May 19, 2013 | Briggs & Stratton Power Products 5,550...
The generator went off on its own due to low speed alarm
You didn't mention the model???? Check the mag pickup sensor for cleanliness, and also it should produce approx 2V AC during cranking
Dec 06, 2010 | Caterpillar Electrical Supplies
I'm dumb. Can I hook an inverater to my generator and produce more enegry than my generator produces???
Please understand that the generator produces power from fuel with an engine wheras the invertor is one which genrerates power from a stored battery using the principle of frequency switching a DC source to induct and produce AC.
Now you can have an uninterupted power supply setting with the invertor backed up by the generator so that when the battery voltage goes down you can start and charge the invertor and also supply the extra energy .
the ratings of both must also be considered.
Sep 25, 2010 | Electronics - Others
Blowing oil in carburator and running ok otherwise
Your breather valve may be stuck, and the intake valve (not sealing well) / rings (worn or sticking) may be pressurizing the crank case.
You might also have too much oil in it, but that would also cause it to produce copious amounts exhaust smoke.
Jun 25, 2010 | Briggs & Stratton Power Products 5,550...
Wolf 800 generator. Engine will run but very electrical power is
is the engine running at the correct speed
3000 rpm to produce 50hz
3600 rpm to produce 60hz
Mar 06, 2010 | Electrical Supplies
Coleman 6750 powermate with yamaha mz360 electro ignition cranks and runs fine but doesn't put out any power brushless how do i get it to produce power again?
One of two things:
1. The rotor has lost all the magnetism it needs to get started generating. It needs to have a tiny bit to get started.
I have used the system of a couple series 150 watt lamps between the generator and the utility power. Search Google for description of this method. I have used it and it works.
2. You have blown diode(s) on the rotor. They would have to be replaced. I have not found a source and had to make my own.
Oct 24, 2009 | Coleman Electrical Supplies
Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
Mar 24, 2009 | Yamaha 4500 Watt Electric Start Generator...
20KW Guardian Generac does not produce 12 volts to run engine
The problem is that the printed circuit board inside the generator draws a little current from the battery even when the generator is not running. Over the course of a few days this can make the battery weak enough to be unable to get recharged by the built in running charger which results in not enough power to run the electronic governor on the generator. Usually the spark plugs will work even with a fairly low battery.
Most of the Generac generators come with a built in trickle charger that runs off of the transfer switch load terminals. If your built in charger isn't doing the job it's either broken or you have the wrong sort of battery installed in the generator.
Regards,
Carl
Jan 11, 2009 | Electrical Supplies
Honda Dewalt Dg6000 Generator W/ Gx340 Engine 11 Hp Logo
Top Honda Air Tools & Compressors Experts
John Trevino
Renee Knafel-Bullock
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
