Question about Bosch Washing Machines
Bosch Classixx WVF2402GB/02 is not heating up to dry clothes
Resetting machine and adjusting temperature dial.
    Problem Solver:
  • 59 Answers
Look at RepairClinic.com
Posted on Dec 03, 2014
SOURCE: BOSCH washdryer WVF2402GB/02 - not spinning clothes
Remove the kicking plate on the front-bottom of the machine. You will see o circular lid there, turn it on anti-clockvise to open. All of the water blocked will come from there, be careful. Look carefully that there are some objects blocking the water draining. Then turn on the machine on draining programme, the plastic rotor should turn fastly when the machine is on. If it is not running, change the pump motor. If it is running, but machine is not draining again you can understand that there is an objeck stuck on the hose between drum and pump motor. Lay down the machine on its rear facade, you will see a large and black hose between drum and pump motor. When you remove it, you will see that there is something that blocks water running. Good luck :)
candogan62
Posted on May 28, 2009
  • 662 Answers
SOURCE: I have a Bosch washing machine /classixx 6 12 Expr...
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
Posted on Jun 14, 2010
  • 662 Answers
SOURCE: Got the Bosch Classixx 6 Express 1400 washing machine cant
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently. Means the machine is locked, for children. I think if you do it again it locks.
Posted on Jun 17, 2010
  • 662 Answers
SOURCE: Got the Bosch Classixx 6 1400 Expresswashing
Pl rate me 'very helpful' for the free help, thanks!
SOURCE: bosch classixx 1200 express lights flashing
Bosch 1200 classixx express washing machine. Upon switching on my machine, a little while later all of the lights on the control panel were flashing except the Start button. I tried to push the buttons but there was not the usual sound made upon depression of any of the buttons. They continued to flash. I switched the power off and cleaned out the pipes at the front of the machine to eliminate any obvious problems. Please help
Posted on Sep 25, 2012
Bosch classixx dishwasher not heating water on cooler wash works on hot wash
Most dishwashers don't heat the water. They run on whatever temperature water you have it set for. They have heating coils on the bottom but that's for drying, not heating up the wash water.
Nov 30, 2014 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch washer dryer not heating up on drying cycle.
The problem may be with the heating element or temp limit switch.
To check with an ohm meter you will need to pull the top, the front, and the drum out. If all check good then it may be the circuit board.
Nov 30, 2014 | Bosch Washing Machines
Bosch Classixx WVF2402GB motor will not run
Remove the front lower panel, screws underneath. Be prepared for water, drain out from drain hose. Check filter for clogging, clean out. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if they are any shorter than 1 cm replace brushes.
Dec 09, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Washing machine malfunction
The latch might be an issue . Move the dial on pump mode . Try activate the door lock with a screw driver move it to the right and should activate the machine. If that works then the latch is the issue and can easily be repaired by removing the door.
Aug 09, 2008 | Bosch Classixx WFL 2462 Front Load Washer
My bosch classixx 1200 express
Close the door and turn the dial to drain
Jan 11, 2018 | Bosch Classixx WFC 2465 Front Load Washer
Inner drum seal wvf2402gb/02
This video will show you how to change a door seal on this Bosch WVF2402GB/02 front loader washing machine
we have all bosch repairs in our channel
You can get seals on eBay
Apr 07, 2008 | Bosch Classixx WVF 2402 Front Load...
My WVF 2402 washer/dryer washes clothes ok but doesn't dry them.
Sorry I'm way late with this but I've only just noticed it. Unplug the machine from the mains! Remove the lid (with a torx screwdriver) and you'll notice a small circular device with 2 leads attached on the top of the machine, in the centre there's a small button, press it and it should click......you've fixed it This is a thermal cutout safety device designed to switch the drying heater off if it becomes too hot. The probable cause for this is that you've over filled the machine and the air didn't circulate freely. as a rule of thumb, dry 1/2 as many clothes as you wash.
Mar 23, 2008 | Bosch Classixx WVF 2402 Front Load...
Washing Machines Logo
94 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
