Question about Drills
How do I repair Black & Decker Cordless Screwdriver KC9024?
Not used in a long while and possibly needs new battery plus service
  • 1,169 Answers
Will cost more to repair than to replace it. B&D didn't make the replacement battery pack available. They are a pair of Nicads welded together but finding correct physical size that are welded together will be hard.
Posted on Nov 30, 2014
danny_murray
  • 55 Answers
SOURCE: My cordless Black & Decker
Most likely it is the switch has gone bad or just a loose connection on the switch . you can take it apart and check the switch connections and make sure they all have a good connection.If they do then you should take a volt meter and make sure that when you puch the button they get proper voltage if not then order a switch and replace it .
Posted on Dec 05, 2008
SOURCE: Black & Decker Pivot Plus Cordless Drill/Screwdriver AC Adaptor
extend the handle straight and all will be reavealed! Just in front of the triger inside the piviot point.
Mike
Posted on Jan 14, 2009
  • 1214 Answers
SOURCE: how to change drill bit
Grab the end of the chuck in one hand, and the outer ring of the chuck nearer the motor, and twist the chuck end. try both directions until it loosens.
Posted on Jan 28, 2009
  • 3 Answers
SOURCE: fixing a cordless drill battery charger
usually transistors have three legs, diodes have two arms all very confusing isn't it? resistors have two arms as well but not three legs or only two legs and no arms its all about arms and legs isn't it do not attempt this repair if you live at home
Posted on Aug 27, 2009
  • 2219 Answers
SOURCE: NEED BLACK & DECKER MODEL KC 9036 chargeable
It is not worth trying to get batteries for this , the whole thing costs £10 in the UK, which is less than you would get the batteries on their own.
Posted on Apr 11, 2010
What settings on a universal charger do I use for a Black & Decker 2.4 V cordless screwdriver
I would say that a output voltage of not more than 2.8 volt and the output amp should not exceed 60% of the Amp hour rating of the battery. Example if the battery is a 2000 mah battery the charging amp should not be more than 1400 milli amp or 1.4 amp
Jan 12, 2014 | Black & Decker 9072CTN Cordless...
I need the instruction manual for a PD600 black & decker pivot plus. The black & decker website sells them but when entering the model says none found...weird
Go to the Dewalt service website at http://servicenet.dewalt.com, put your model number in the parts search box and you'll be presented with two versions of your tool. Select one and you'll be taken to a page where you can view or download the manual, parts breakdown, or order parts. There are only four replaceable parts for your tool.
Jul 01, 2012 | Black & Decker Pivot Plus Cordless...
How do remove the battery from my black and decker pivot plus drill
It's in the **** end. You must unscrew all the black screws in the lower handle. Remove the black heel. Then unplug the Red wire. Carefully pull out the battery pack. Then unplug the black wire
You can order a new battery from HERE
Jun 22, 2011 | Black & Decker Pivot Plus Cordless...
How do you turn it on?
Click on the link below to access the Black & Decker Pivot Cordless Drill/Screwdriver owners manual, inside this manual will show you how to turn it on:
http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/5145342-00,PD600PD600G.pdf
Feb 04, 2011 | Black & Decker Pivot Plus Cordless...
Black & Decker Nickel Cadmimum replacement battery
Check the store where you purchased the screwdriver but you will find its cheaper to buy a new screwdriver with new batteries than to buy just the batteries.
Jul 12, 2010 | Black & Decker 9072CTN 2.4V Cordless...
My old black & decker power screw driver will not accept a charge. I cannot get it charged up.
Black & Decker stopped doing battery packs for the older screwdrivers, like the 9018, some time ago so you cannot get them.
However you can still buy replacement NiCad, Sub C, 1.2v, tagged batteries that will do the job on the older 2.4v models as NiCad batteries for use in power tools are exempt under the European ban on importing NiCad batteries where used in power tools (Specific Exemption).
When you open up the screwdriver look at the positioning of the batteries and the tags/connectors and solder them together the same way.
So all you need is a soldering iron to join the centre tags together and then trim the end tags, top and bottom, to the width of the live/negative connectors and you have got a new battery pack.
It doesn't have to be pretty but after a small investment and a little effort it sure beats paying out £30 to £50 for a new screwdriver. I have done this for my older Black & Decker and Bosch screwdrivers which all work like new again.
Apr 08, 2010 | Black & Decker Pivot Plus Cordless...
I have a pink black & decker cordless drill which I use for small household tasks. However, my husband uses this too for small jobs. My problem is the ac adapter has gotten misplaced & I need one....
Contact Black and Decker (Dewalt) at 800-235-2000-you should be able to get number for an authorized repair center that can supply it for you-but it may be cheaper to replace the whole thing.
Mar 11, 2010 | Black & Decker Pivot Plus Cordless...
this one dosn't charge. It takes batterys. how do i change them
Dec 20, 2008 | Black & Decker Pivot Plus Cordless...
Drills Logo
83 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
