Question about Dell 948 All-In-One InkJet Printer
How do I disassemble a Dell 948 printer?
The white cover will not release at the back. Are there screws in the blind holes?
    Sergeant:
  • Dell Expert
  • 124 Answers
Depends what you need to get at though. HP don't let general public get their service manuals, but if you add info on what you need to deismantle somone might be able to help
Posted on Mar 02, 2015
  • Official Brand Answer
  • 560 Answers
Ron Worth,
Dell does not have any disassemble instructions for the printer. You can click the link below for viewing the online manual.
Dell 948 AIO Printer
http://dell.to/1vAFZ3R
Thank You,
Dell-Jesse L
Dell Cares
Dell Social Media and Communities
Posted on Dec 01, 2014
SOURCE: Dell 948 wireless printer
hi,
u need to have wireless internet connection, first uninstall the printer sw, while reinstalling choose wireless install, follow inst, connect the printer, configure wireless adapter by choosing the correct wireless nw and by entering the security key(WEP, WPA), if wireless adapter not detected then, unplug all cables from back of printer,removed wirless adapter, press power button for 20 secs without any cables connected, connect cables, restart printer, connect the wireless adapter, u will get msg nw card detected, then try reconfiguring by entering the correct keys, in case if u dont know the security key contact ur internet service provider, once correct details are entered it will configure successfully, unplug usb cable from printer and pc, install printer sw, issue resolved, if there is no communication then check the firewall settings, anything relating to printer give full access, restart pc, try printing,
ps: if usb cable is connected to printer the nw card will be disabled.
Posted on Nov 14, 2008
SOURCE: How to install 948 printer.
how do you connect the cords
Posted on Dec 11, 2008
SOURCE: Dell All-In-One 948 InkJet Printer
This might not be the issue but I had a similar problem when I first got the printer. Open the top-( where the ink is loaded), look at the back on the right there is a small bus cable ( flat wire usually white) make sure it is pulled in all the way into the top. Be carefull as the prongs can break. This took care of my clicking clacking when the machine came on.
Good luck
Posted on Feb 05, 2009
  • 3 Answers
SOURCE: Dell 948 printer- won't print in black and white
I had this problem. It's actually very easy to fix:
- Click Print -> Properties
- Go to "Advanced" tab
- "More options"
- Deselect "Use color cartridge for all black printing"
- Select "Use black cartridge to print black and white"
- Click "Ok"
You should be able to select the "Print in black and white" option now and stop all the frustration!
Anthony
Posted on Aug 16, 2009
SOURCE: refilling a dell 948 color ink cart #11
Alright, I gave in and busted open my Series 11 KX703 color cartridge to figure out how to refill it. As Inksaver pointed out there are six columns which ultimately lead into three ink wells the bottom two (next to the cartridge head) are magenta, the upper right two are yellow and upper left two are cyan. Each well has one sponge in it that soaks up the ink. Each of the six columns has a hole predrilled in the center of it just below the top layer of plastic (about 5/16" from the left and right edge and 1/4" from the top and bottom and 1 3/16" (midway) from the top and bottom for the center two holes).
When I do it again (with a new cartridge since this one is busted), I'd drill three holes, one lower right and the two center holes, push the metal syringe down into the foam about midway and inject each of the foams with new blood. If someone else tries let me know how it goes. Hope this helps.
Posted on Feb 27, 2010
How to disassemble a Dell 948 printer?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to some popular brand printers and other devices are given in detail with illustrations.
Nov 30, 2014 | Dell Series 11 948 Print cartridge...
Dell 948 Printer Problem
Try uninstalling the printer software from the computer then reinstall.
Dec 10, 2013 | Dell 948 All-In-One InkJet Printer
Printer message cover open
There is no replacement part available from Dell. Temporary fix is removing the hinge spring under the small concave white plastic piece (you can remove that also) allows the cover to close. The nub under the cover has to press a "lid closed" switch which is not possible if the lid hinge is broken.
See this link:
http://www.fixyourownprinter.com/forums/inkjet/66032
Jul 27, 2011 | Dell 948 All-In-One InkJet Printer
Can't download application 948 Dell All in one printer
You can download the application from this link
http://download.cnet.com/Dell-AIO-Printer-948/3000-2116_4-185937.html
May 26, 2011 | Dell 948 All-In-One InkJet Printer
Cover won't close, found broken plastic washer in back of unit
Hello, if there is a broken plastic on this dell printer and you wanted that to be fixed you need to call up dell and have them replace that for you, i think you cannot get replacement for that one for a local tech or store. Thank you for using Fixya
Mar 05, 2011 | Dell 948 All-In-One InkJet Printer
My Dell 948 printer produces a thick black line on documents
Leave the cover up and run a 'copy.' Look closely at the fluorescent scanner light and note if it seems equally bright from end to end.
If it does, the photo-assembly that acts as an image receiver is probably sick.
If it is, with the labor cost and potential non-availability of parts, you might be better off replacing it unless still under warranty.
Jul 02, 2010 | Dell 948 All-In-One InkJet Printer
How to remove glass on dell 948
You have to lift the document feeder up and out of the slots in back.
I would also recommend removing the screws from the back cover and taking it off. Then take the two front screws off on the top holding both the ledt and right top covers. Remove those covers, and also remove the one screw holding on the plastic strip along the back of the glass.
Then remove the glass. Be careful cleaning the scan head. That lamp is very fragile.
Dec 30, 2009 | Xerox WorkCentre XL2130f Laser Printer
Dell 948 printer. Black(2 inch) Vertical lines when I print
You need to check the glass for any white-out or other smears that don't belong, if the glass is clean then the scan assembly has elements that are burned out which will cause dark streaks.
Jun 30, 2009 | Dell 948 All-In-One InkJet Printer
I need a picture of the refill holes on a series 11 Dell color ca
Remove the top before refilling.
Otherwise you risk that the colors get mixed.
That happened to me when using holes drilled from the top.
Apr 22, 2009 | Dell 948 All-In-One InkJet Printer
Good luck
Nov 14, 2008 | Dell 948 All-In-One InkJet Printer
Dell 948 All-In-One InkJet Printer Logo
98 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
