Sc 900 error code appear
Memory clear
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 884 Answers
Hi
You don't mention the make or model of your printer/copier, but a quick Google would indicate that it is a Ricoh machine.
I give below a link to a site which lists many models of many makes of printer and error codes. their description and cause, which will help you identify what is wiring and correct it:
Error Codes Ricoh Aficio SP4100N Code 900
On this site you can change the make, model, and error code on your machine by using the drop down menus near the top of the page. Also you can download a pdf format Service Manual for the machine by using the link just above the error table.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Nov 30, 2014
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press 1 , 0 , 7
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
Sharp photocopy machine showing error code Sc 542
SC 542 Basically the machine is telling you that the fuser did not reach its target temperature in a specified amount of time. In normal circumstances this code will appear if the thermistor is not maintained or replace periodically or in abnormal circumstance the heat lamp blew. This is a Service Tech reset code. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won't come ready until the prior error condition is cleared. basically you will have to care a service tech to clear it
Aug 03, 2015 | Sharp Office Equipment & Supplies
HOW TO CLEAR SC 990 MESSAGE IN RICOH AFICIO 2022 APPEARS WHEN SWITCH ON THE MACHINE?
Hi
I have found this explanation of the error message:-
Description: Software performance error
The software attempted to perform an unexpected operation
Causes: • Software defective • Internal parameter incorrect • Insufficient working memory • When this SC occurs, the file name, address, and data will be stored in NVRAM. This information can be checked by using SP7-403. Note the above data and the situation in which this SC occurs. Then report the data and conditions to your technical control center.
This can be confirmed here:
Error Codes Ricoh Aficio 2022 Code 990
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Cheers
Dec 31, 2014 | Ricoh Office Equipment & Supplies
How do I clear error code sc542 on model 3510sf
go to maintenance mode. press clear/stop press 1 0 7 and start key(hold) until maintenance mode is displayed. look for fuser SC reset.
Sep 18, 2014 | Ricoh Aficio SP 3510SF
Ricoh 3045 sc865-01 , any solutions ?
In general the SC 860-900 refer to HD acces error.
SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
Feb 20, 2013 | Ricoh Aficio 3045 Digital Copier: 45cpm....
Hi . my copier is aficio 700 .The error is sc 900 .that relate to electical counter .I Check the connection between the NVRAM and controller. Replace the NVRAM. Replace the controller. but the error not...
Other possibilities
A095/A096/A097
SC 900
[SC900] - replace fuse 8 0 4, DC power supply
A109/A172/A199
SC 900
[SC900] - replace black total counter
A133/A195/A217
SC 900
[SC900] - CN4 0 3 SCU PCB, poor connection
A133/A195/A217
SC 900
[SC900] - replace SCU PCB, see FSM page 5 64 for rom and dip switch info
A193/A224/A264
SC 900
Total counter error: Fuse #5 on PSU blown
A193/A224/A264
SC 900
Total counter error: Total counter defective
A229
SC 900
[SC900] - NV ram defective
A230/A231/A232
SC 900
[SC900] - re load copier firmware
A246/A247/A248
SC 900
[SC900] - replace counter harness
A292/A293/B098
SC 900
Electrical counter fail - Replace Mechanical Counter
A292/A293/B098
SC 900
Electronic counter error - Replace NVRAM-B098 9590.
A292/A293/B098
SC 900
[SC900] - replace IOB PCB
A294/A295
SC 900
[SC900] - NVRAM defective
B010/B188
SC 900
Electrical total counter error - NVRAM data defective
Jan 28, 2011 | Ricoh Aficio 450 Copier
Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
Feb 02, 2009 | Gestetner DSm615 Digital Imaging System
Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Ricoh 1232c copier error code sc 517
The error is about the fusing unit for to reset the code you must enter into the service menu and reset the SC code 517
For to enter the service menu you should do the follow steps :
1.Enter the service menu by pressing the follow keys in order: yellow key[clear modes] then press "107" number one after other and then press and hold the red key [clear/stop]
2.Hold it down until service mode do not appear if not appear after 10 seconds try again.
After you will be in service mode press the follow numbers :5810 and then will apear on the screen "SC reset" set the value from "0" to "1".
Then turn off and after 5 seconds turn it on the machine.
Please replay if this do not help and write the SC code good because i cannot find the code SC517
Oct 29, 2008 | Office Equipment & Supplies
49 people viewed this question
jasbo
jasbo
