Why replace yellow toner - Office Equipment & Supplies
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Most printers won't run without a full set of cartridges each with ink to print. This ensures that you spend on cartridges even if you are happy to use just black for a while.
Posted on Nov 30, 2014
Error code SC363
yellow toner is not loading
replace new yellow toner if it did't work replace the yellow toner pump
Apr 27, 2014 | Ricoh Aficio SP C410DN Laser Printer
Replaced toner and maintenance kit -keep getting yellow lights on exclamation and toner
If the toner and the exclamation lights are blinking yellow after replacing the toner and maintenance kit, then you will need to reset the photoconductor counter. But if the exclamation and the toner lights are steady on yellow, then that means there is something wrong with the toner.
Jul 27, 2010 | Lexmark E260dn Laser Printer
HP LaserJet 2820
Push the button to align another color and open the door and take notes on where the carousel should be when changing a toner, Not sure why it would bypass yellow altogether but may be resolved by manually changing out the yellow. When you open the door to the toner compartment there should be something on the door that depresses something in the machine which will unlock the carousel and allow you to turn it by hand when you depress the same lever with some type of tool that will fit in the slot. Rotate the carosel until the yellow is where it should be when replaceing it then let go of the locking mechanism and replace the yellow toner. hopefully between changing the toner out and powering the machine off/on will get you back in business... Hope this helps you out and if it does please list as a fixya... if not, you may need to upgrade the firmware and that's not to hard if your on the network already...
Sep 24, 2008 | HP LaserJet 2820 Printer
Yellow toner will not print
If you let the yellow toner get to the point where the toner cartridge was totally empty, there is one thing you can try which may help. From the "menu", select "maintenance", then go to "clean developer" and choose the yellow. The machine will then churn for a few minutes. What happens is there is a tube that moves the toner from the toner cartridge down to the developer unit ( which is behind the imaging drum). If the toner was allowed to totally run out, there is an area of the tube which may have little or no toner in it. Each time you print, there is a spring auger within the tube that draws the toner to the developer. By running the "clean Developer" it turns the auger and re primes the tube.
If this does not fix the issue, and you have replaced the imaging unit, then the yellow developer is defective and would need to be replaced. This involves quite a bit of work and is not considered user replaceable.
Aug 20, 2008 | Dell 5110cn Laser Printer
REPLACING CARTRIDGE
You should be able to replace just the needed color.  Select menu, arrow right until "Engine" is displayed, select, select "Replace Toner" select color cartridge desired. follow directions on screen.
Jul 29, 2008 | Minolta magicolor 2350 Laser Printer
Ricoh cl4000dn toner bottle sensor
The toner bottle sensors don't go bad too often. Do you have an extra yellow toner bottle? Try replacing that first. Compare the tray where the yellow toner bottle sits to the other three colors, and make sure nothing where the toner bottle connects is broken or bent.
Jun 22, 2008 | Ricoh CL4000DN Laser Printer
Samsung CLP-510 Toner Bleed
The following can cause bands (vertical on a normal page)
Faulty Toner cartridge
Faulty Drum Unit
Faulty Transfer Belt
Contaminated Fuser
Damaged or dirty LSU glass
Jan 09, 2008 | Samsung CLP-510 Laser Printer
Insert Yellow toner
There is a cheap under the toner... it is probably corrupted... with a screw driver you should take it out and replace it with the old cartdrige toner.
Nov 08, 2007 | Dell 5100cn Laser Printer
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
jasbo
jasbo
