Question about Microsoft Xbox 360 Console
My Xbox 360 hasn't got the green ring on and it won't start up. It has the green power button and the fans start but that's it it doesn't go any further than that
  • 296 Answers
If you only have the green power light and no ring with no video then you need to check your hdmi or video connections. If the connections are poor or even if the tv is off the outside ring lights will not even come on.
Posted on Dec 27, 2014
penheadsprod
SOURCE: Console wont boot up
It's probably not dying. Just spend the time replacing the thermal paste on the heat sinks with Silver Thermal Paste from Radio Shack. Takes awhile, and you have to do it right. Don't be lazy and impatient with it while prepping the surfaces, and maybe it will all be alright. I switched out those 'X' clamps on mine with 4- 5mmX12mm machine screws, and 4 - 5mmX20mm machine screws...4 - #10 washers to even the mother board with the rest of the casing, A #10 Teflon washer on top of the motherboard(to keep it from shorting out in the future, and for heat expansion), another #10 metal washer on top of that, and then screwed them evenly into the heat sinks..Works fine now... Had to grind a few of the washers to have a flat side, and drill some 3/16 holes to make the casing holes a little bigger than factory size...but it was easy.
Posted on Feb 17, 2013
  • 33 Answers
SOURCE: 360 Xbox problem Three red rings
3 Red lights problem is one of the most common problem of Xbox 360. You will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Posted on Mar 05, 2009
ionfreek458
  • 52 Answers
SOURCE: xbox 360 red ring
first of all, 3 red lights USUALLY means that you have an internal hardware error. microsoft has a garuntee that if your xbox DOES get the 3 red rings, you can send it in to them and get you xbox fixed or a totally brand new one for FREE. but before you do that, you should check ALL of the cords to make sure that they are plugged in right. there is a reported 33% of the Xbox 360 that were produced have a serious problem- once the motherboard reaches a certain temperature is bends, causing some solder balls to lose contact with the GPU and motherboard.
If there is anything that you want to be sure of before you take apart your XBOX 360 is assurance that what ever your going to do to it, is going to work!
just go to this website:
http://top3redlightfixes.com/XBOX3RedLights/xbox_360_3_red_lights.php?gclid=CIeBnJi1pJYCFQgRFQod0lsd7A
my friend used this site and got his xbox fixed in no time and he learned some suff too.
Posted on Oct 21, 2008
SOURCE: red light on my xbox 360
Turn console of, hold sync button down wich is the small white button next memory card slots, while holding turn on console and wait till it boots. If this does not work go to system blade, select memory, press y on the HD symbol, press xx left bumper right bumper xx, select yes. This will restart your console from scratch though all profiles and saved data will be lost, but it will clear any corupt data.
Posted on Sep 16, 2007
  • 44 Answers
SOURCE: my xbox 360 is not displaying any picture just sound
its overheating but will give u red light eventually try googling X-Clamp fix i fixed many with same problem
Posted on May 14, 2008
SO MY XBOX 360 ISNT WORKING THE POWERE BUTTON TURNS GREEN FOR A SECOND THEN GOES RED. WHAT IS WRONG?
Try plugging it in correctly but if it has 3 rings you have the rings of death and your xbox is dead.
Jul 30, 2011 | Microsoft Xbox 360 Console
Orange light flashing in powercell pack.console not turning on. tried different powercell pack still not working .used power surge adapter
Hi,To troubleshoot this problem, try the following steps:
Examine the power indicator light that is located in the center of the Ring Of Light on your Xbox 360 console. If there is no power to your console, the indicator light is off and the fans are off.
* Press the power button. The power button and the power indicator light are located in the center of the Ring of Light on the front of your Xbox 360 console. If your Xbox is functioning correctly, the power will turn on.
* Press the eject button on your console disc drive. If your console turns on when you do this but does not start when you use the power button, there may be a problem with the power button or the console faceplate may not be attached correctly. Contact Xbox Customer Support for more help.
If the above step does not resolve the problem, examine the power cord where it connects to your console and to the power outlet. Disconnect and then reconnect the power cord at each end to make sure that you firmly connect the cord.
If this does not resolve the problem, see whether the power cord is plugged in to any device other than a typical power outlet. For example, the power cord may be attached to an extension cord. If this is the case, remove this device and then plug the power supply directly into a power outlet.
If the problem is not a connection problem, examine the light on the Xbox 360 Power Supply.
* A green light indicates that the power supply is functioning correctly. If the light is not green, contact Xbox Customer Support for more help.If these steps do not resolve the problem, your console needs service.
Thank you!
May 11, 2010 | Microsoft Xbox 360 Console
My xbox 360 delays everytime it powers up when you turn it on the middle of the power button turns green fan comes on takes 1 min for the outer rings to turn green and full turn on have tried different...
Sounds like you have a GPU problem. Sorry to tell you this, but this problem usually leads to the red rings of death. If you still have warrenty you should probly sent it in for repair. If not then you should try the x clamp fix. Just look it up on youtube. It will work I am 100% sure. Just make sure you follow the directions correctly. This shoud fix your problem and prevent you from getting the RROD
Feb 16, 2010 | Microsoft Xbox 360 Console
Controller wont hook up with console ?
Is this a new controller?
Are the batteries new/recharged?
This is the sequence summary on where you are going to focus:
Step 1 - Controller
Step 2 - Console
Step 3 - Console
Step 4 - Controller
Step 5 - Both
Assuming your controller is a wireless version, Lets start!
Step 1 | Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
Step 2 | Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
Step 3 | On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
Step 4 | On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
Step 5 | After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Light indicator on console
Green light in the center- power is on
Green light on one quadrant - controller is connected
Four green lights rotating on four quadrants - ready to connect with controller
Light indicator on wireless controllers
No lights - no batteries
Green steady light on one quadrant - connected
Blinking green lights - its either its ready to connect or the batteries are dying
*Make sure that you have a fully recharged rechargeable batteries
*Make sure that you have a functioning/new non-rechargeable batteries
*If the steps above aren't working use another Xbox360 controller and follow the same steps.
If the new/working controller is connecting with the console this means that the previous controller is faulty - needs replacement.
If the new/working controller is not connecting with the console this may mean that the console is faulty - needs repair.
*NEVER TAMPER WITH ANY OF THE TWO AS TAMPERING WILL VOID EXISTING WARRANTY.
Nov 23, 2009 | Microsoft Xbox 360 Console
Xbox 360 won't turn on
Sep 01, 2009 | Microsoft Xbox 360 Console
My controller and xbox wont connect
To connect the controller to your Xbox 360 console, follow these steps:
  1. Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
  2. Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
  3. On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
  4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
  5. After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Aug 28, 2009 | Microsoft Xbox 360 Wireless Controller
My xbox 360 and wireless controller will sync but then it wont show that they are connected and even though i turned on my console by using the button on the console it just shows the green light turn on...
  2. Make sure that your Xbox 360 console2_bing.gif is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console2_bing.gif.
  5. After the Ring2_bing.gif of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Aug 15, 2009 | Microsoft Xbox 360 Console
While trying to power up my xbox 360 the power brick has an amber/Orange light. When I hit the power button on the 360 I get a green center light and a quick green flash on the power brick, but then...
The red ring of death occurs when an Xbox 360 overheats and melts some of the internal solder that holds components together. This occurs because microsoft distributes them with low quality solder to save money. There are many people who can solve this problem in every state. I live in Rhode Island and there is one person who lives right down my street who does it. You can also send it back to microsoft if it's been less than 3 years since you bought it, because that will be covered under the warranty. -Good luck, and I hope this helps
Jun 11, 2009 | Microsoft Xbox 360 Console
Have sound no picture and 2 green rings around power button
They are green?!? usualy when people have problems with  the xbox 360 hardware, the lights turn red. This xbox 360 may have a birth defect... Best thing to do is call 1800-4my-xbox. Talk to a representative about sending your xbox in, ONLY if you have not voided the warranty. If so, you will most likely have to buy a new xbox or new motherboard for it.
Also try changing your video settings to tv instead of hd, or hd if it is plugged into a hd tv. You might have toggled the HD switch on the video/audio chords.
Dec 31, 2008 | Microsoft Xbox 360 Console
Dead Xbox 360
Yes, the power brick has a yellow/orangeish light, It does not turn green when I try to power on the console.
Aug 20, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
73 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
