Question about Singer 8280 Mechanical Sewing Machine
After replacing the needle in my singer 8280, the needle clamp is not holding the needle tight, the needle falls down even after tighening it..how do i make the needle get fixed?
When i removed the needle the whole clamp came down. i tried fixing the clamp, but i think i didnt not keep the clamp in its proper slot and tried scewing it.. i feel the screw has become blunt.. what should i do?
    Scholar:
  • 81 Answers
Try jiggling and wiggling the needle clamp while shoving it up. Turn it back and forth slightly while doing this, too. The screw has a flat end, not a pointed one. When you put the needle in, make sure that the flat side is facing in the proper direction, usually toward the back. Wiggle and jiggle it while shoving it up, too. Make sure the screw that holds the needle is loose enough to allow it to go all the way up. There should only be about 1/8" inch of the fat part of the needle shaft showing. Check out the manual, http://homeappliance.manualsonline.com/manuals/mfg/singer/8280_2.html?p=18 This should take you right to the page you need. Good luck.
Posted on Dec 01, 2014
  • nirmalakaru Dec 03, 2014
    Thanks Perkins, im now able to fix the needle, but when i start stitching either the thread gets cut or the upper thread gets clogged like a bunch at the bottom of the fabric...pl guide me to fix it..thanks in advance.
  • Perkins Byrd Jan 03, 2015
    Sorry for the late reply:( I'm thinking that the tension needs to be adjusted. Start out with 1 and move it up slowley until the top and bottom threads look right. Check the manual I sent you, also. You may be using the wrong needle also. Are you sure you have it in right?:) Also, be sure you have the bobbin in correctly. You may have the thread in the bobbin holder backwards. Let me know if you need more help and I'll try to answer quicker. Pung61@att.net
  • 352 Answers
It sounds like you have lost the tread guide. When you press the clamp as far up as it will go, there should be a slot in the post underneath the clamp visible. You may need to use a mirror to see it. The thread guide snaps into that slot and keeps the clamp from falling down. Take it to any repair shop. It will not be expensive to repair.
Posted on Nov 30, 2014
SOURCE: Singer 7442 - Needle hitting bottom
FIRST DETERMIN NEEDLE BAR POSITION TURN STITCH REGULATOR TO LARGEST STITCH, THEN TURN HAND WHEEL TIL' NEEDLE IS ABOUT TO ENTER NEEDLE PLATE.
AT THIS POINT THE FEED DOGS SHOULD BE JUST AT OR JUST UNDER PLATE. IF SO NEEDLE BAR IS, IN CORRECT POSITION,AND TIMING WILL BE SET AT THE HOOK.
TO SET TIME REMOVE NEEDLE PLATE TURN HAND WHEEL SO NEEDLE IS IN LOWEST POSITION. USING A SMALL RULE RAISE NEEDLE BAR 3/32 OF AN INCH ( OR 3 MM FOR A METRIC RULE) .HOOK POINT SHOULD BE IN CENTER OF NEEDLES WIDTH. LOOSEN THE 2 SHAFT SCREWS
SLIGHTLY,TURN HOOK TIL CENTER OF NEEDLE. TIGHTEN SCREWS. IF NEEDLE BAR IS OUT OF TIME. BRING HOOK TO CENTER OF NEEDLE AND LOOSEN SCREW IN LEFT COVER. RAISE OR LOWER NEEDLE BAR TO SET 3/32OF AN INCH. THE 3/32 MUST BE VERY VERY CLOSE.
Posted on Dec 19, 2007
SOURCE: Singer 8280 is not giving me a useable stitch due to tension is not properly feeding resulting , no interlocking
Make sure that the thread is not getting caught on the handle. I was having the same problem and tried everything only to find that my thread was caught.
Posted on Dec 15, 2008
  • 69 Answers
SOURCE: Singer Athena automatic needle threader does not work.
Check on the threader and see if the part that goes through the eye of the needle is bent. This is a very common problem. The threaders are becoming more and more difficult to replace. If the piece is bent, you can usually use a pair of tweezers to straighten it out.
Posted on Feb 09, 2009
SOURCE: Singer Ce-150 Error 19
The top little circle you think you're supposed to wrap your string around - the one that you wrap the thread around to fill the bobbin -- thats not what you're supposed to wrap it around. Im an idiot, and thats what I was using. My friend Amanda showed me what I did wrong.. LOL
Posted on Apr 29, 2009
bargainbox
  • 1388 Answers
SOURCE: my 8280 modle singer: I sewed a zipper for a
If you are not able to free this easily, you really should consider taking it to a service technician to look at it in case you do more damage to the needle bar and elsewhere trying to fix it yourself.
Posted on Sep 08, 2009
Metal boot shape piece goes inside needle bar then needle they keep falling out. Metal fell out trying to change
Would you please say what model you have? I gather that there's now a problem with your needle clamp, and it won't hold needles? Those clamps can be replaced inexpensively--you just slide the old one off and the new one on--but I could be more specific about where you can buy a replacement if you supplied the model number.
Jul 02, 2015 | Singer Sewing Machines
My singer machine keeps disaligning. I put a new needle in and when coming down it dosen't go into the hole. Even if I activlly hold it in place and it goes in once as soon as I let go it goes
If you are pulling the arm towards you or pushing away from you then you will need to have the needle arm adjusted. Pushing and pulling of the arm will only cause damage. Many times this needs to be adjusted due to the constant movement of the machine. There is usually material on the Youtube to explain how to adjust needle arm.
Dec 19, 2014 | Singer 8280 Mechanical Sewing Machine
The thread keeps bunching up near the bobbin and no amount of rethreading and lubricating is helping.
1.upper tension may be to tight--try 3 to 5
have you tried a new needle
2.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
3.Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
4.also check to see if the thread has come off the thread take up lever
Sep 12, 2011 | Singer 8280 Mechanical Sewing Machine
Needle fall down again and again not fit
Hi,Try another size/number of needle instead. Your needle is undersized to your needle clamp.
Also try to tighten the screw of the needle clamp...
Hope this may solve your problem.
Have a nice day!
Thanks for using fixya.
Jan 30, 2011 | Singer 2263 Mechanical Sewing Machine
The thread in the needle keeps bursting each time I make a stitch. And the machine is very tight. It is not free like before
I think that your thread may be old or of not good quality. Try a good quality, non linty brand and rethread your machine. Clean your machine and oil according to your manual. Even treat your machine to a new needle.
Nov 02, 2010 | Singer 8280 Mechanical Sewing Machine
My Singer Athena 09 drops the needle when ever the material is heavy. It usually doesn't break it just comes out of the part held by the screw. I need to buy stock in singer needles, as this happens way...
it sounds like the needle clamp screw is not tight enough or is stripped out
some needle clamp screws have a **** where you can put a flat screw driver in to tighten & if that doesn't work then you need to check on getting a new needle clamp screw
Oct 26, 2010 | Singer 8763 Curvy
My 8280 modle singer: I sewed a zipper for a shirt, but the needle hit the hard part of the zipper, so the needle broken, when I replaced a new needle, but found that that machine stuck, even I push the...
Sep 07, 2009 | Singer 8280 Mechanical Sewing Machine
Sewing machine
Simple solution..
take the thread off your machine, set your tension to the middle setting. rethread your machine up to the needle. before threading the needle, put your presser foot down. If your thread pulls hard, then the machine is threaded right. If it pulls easily, you need to chead the thread thru the tension wheel.
Kelley
Rule of thumb.
Loops on the bottom, problem on the top.
Loops on the top, problem is on the bottom.
May 02, 2009 | Singer 8280 Mechanical Sewing Machine
New singer 8280 needle hits overcasting foot and breaks
so, it sews for a while?  It sounds to me like the screw that holds the needle in place is loose.  As the needle moves up and down the screw loosens until that one fateful stitch, it comes out completely.  Try to tighten with a screw driver.
the other possibility is that it breaks if you are sewing over a bulky seam, like a flat fell.  as the presser foot "toes up" to go over the lump, the needle hits and there you are.
holler if that doesn't help.
Jan 18, 2009 | Singer 8280 Mechanical Sewing Machine
Singer 8280 Mechanical Sewing Machine Logo
105 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
