Question about Beko WMI71641 Built in washing machin
My beko wmi71641 has had the following new parts , new motor new control board new pump new motor suppressor new Motor dc pcb . When put into rinse program fills and drains but that's it all h
All major parts replaced but still no spinning . Won't even start countdown once filled even though a new control board installed
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 63 Answers
HI WAS IT A NEW BOARD,OR USED?
Posted on Nov 30, 2014
vladmototole
  • 226 Answers
SOURCE: beko washing machine WME 7267 fills with water but will not continue through the cycle
See if the filter is clean or if the exhaust hose isn't blocked.
Posted on Feb 23, 2012
sodeep
  • 3267 Answers
SOURCE: beko not draining and spinning
This means to just restart the wash cycle. But I say the culprit is the lid safety switch. Make sure it is not stuck. This is the main reason washers will not spin.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Also must check water level device,if You do not know what is this or where is on machine then call a service.Maybe the hose is precipitate from device.
Posted on Apr 20, 2012
kevin_getz
  • 1031 Answers
SOURCE: beko washing machine not draining
If the drain hose is stretched too much to reach the standpipe, the hose can pitch.
Posted on May 22, 2012
caroldon
  • 17130 Answers
SOURCE: Beko DRCS68W not entering reset mode
If there is voltage on the thermostat but not going through even when the temperature is down it is possible that this could be defective. Now check using a multimeter to confirm the continuity on the thermostat and if the reset switch on this - if present - is off, if so press it down.
Now confirm the voltage from the control panel during the heating cycle and if voltage is outputted then it must flow. The connection must be checked on the heating element- trace to confirm.
Posted on Jul 04, 2012
  • 66 Answers
SOURCE: beko wme8227 stuck half way through cycle
Ring ds suplies 01782-625551 and ask for chell
Posted on Aug 16, 2012
How to clear E000051-0000 in IR3300 Photocopy Machine
E051-0000- At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
Main Cause- The horizontal home position sensor is faulty. The horizontal registration motor is faulty. The DC controller PCB is faulty.
1. Connector
Are the connectors of the horizontal registration home position sensor and the horizontal registration motor connected?
a. DC controller PCB (J304) <-> relay connector <-> horizontal registration home position sensor
b. DC controller PCB (J304) <-> relay connector <-> horizontal registration motor
NO:Connect the connectors.
2. Sensor lever (damage and interference),
Sensor
Is abnormal noise heard from the horizontal registration assembly in keeping with the motor rotation?
YES:
a. The horizontal registration assembly is out of place because of damage to the sensor lever. Replace the sensor lever.
b. The horizontal registration assembly malfunctions because of the presence of foreign matter. Remove the foreign matter.
c. The sensor is faulty and cannot detect home position. Replace the sensor.
3. Horizontal registration motor, DC controller PCB
Is the horizontal registration motor control signal generated by the DC controller PCB?
J304-1/2: 24 V, J304-3/4/5/6: motor excitation signal
YES: The horizontal registration motor is faulty.
Replace the motor.
NO: Replace the DC controller PCB.
Aug 17, 2016 | Canon IR 3300 Digital Copier
Why does the programme stop shortly after starting?
this is sometimes, because there is water left in the drum,because of a blockage in the pump,so machine aborts cycle,please check your pump my be a hairgrip,or coin,if it is ok,next thing i would check are the motor brushs,hope this helps.,
Jun 30, 2015 | Beko WMI71641 Built in washing machin
Beko WMI71641 won't agitate or spin - drum doesn't move!
your pump is blocked,at bottom of machine there should be a flap with a round plug in middle .unscrew,it will have water come out so use a bowl or big towel.the impeller should turn freely,once plug is unscrewed at front put washer into a drain program see if the pump turns.if this is free youll need to get the pump off(unplug machine first)and then feel inside the big pipe from the drum to pump.it may have a sock or something like inside.this means it will work but wont get out all the water.also note when trying to spin a pillow,or big towel the load will be uneven so it will reduce its spin speed so it doesnt destroy its self
Apr 16, 2014 | Beko WMI71641 Built in washing machin
My beko washing machine wont spin ive replaced pcb board but to no avail if anyone can help much appriciated
Hi christophe if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Oct 30, 2012 | Washing Machines
59.90 hp printer error
Hi there
This is related to the ETB motor and you need to make sure if its working. Try the following
ETB motor error
1 Clean the ETB unit intermediate
connector, J36. If the connector is
damaged, replace it.
2 Reconnect the connetors J38 for the
ETB motor and J1111 on the DC
controller PCB.
3 Replace the ETB motor.
4 Replace the DC controller PCB.
Regards
Saleem
Aug 29, 2011 | HP LaserJet 5550DN Printer
System error E010
A specific revolution is not detected from the main motor rotation detection
signal (MLOK*), causing the signal to go '1'. (main motor fault)
Possible cause .
The main motor (M101) is faulty. The controller PCB is faulty.
1) Connector
Is the connection of the connector (J903) of the main motor and the
connector (J06) on the DC controller PCB normal?
NO : Correct the connection.
2) Main motor (M101), DC controller PCB
Try replacing the main motor. Is the fault corrected?
YES : Replace the main motor.
NO : Check the wiring; if normal, replace the DC controller PCB.
Dec 30, 2010 | Canon iR1600-2000 PS
I need canon gp 405 Service manual that contain circut diagram as follows :- 1) IP Board ( Image processor PCB) . 2) DC - Controller . 3) CCD/PCB 4) Composite Power Supply . 5) Main Motor PCB . 6) Fixing...
this site have service manual which contain most of requested bits, including how to and what to do. it is not for faintharted do... :-)
http://www.scribd.com/doc/16699855/Canon-GP405-service-handy
if you find my answer helpful, please rate it, thanx!
Jul 31, 2010 | Canon Office Equipment & Supplies
BEKO DWD4310W Will not empty
yes it will be the main pcb that is at fault they normally lose a neutral to the pump when they go down
Jun 27, 2009 | Beko 24 in. D3731F Free-standing...
Error code 59.c0 in HPLaserjet 5550
This means a printer motor error has occured. From the service manual: C developing disengaging motor rotation error.
To fix:
Developing disengaging motor
error
1 Reconnect the connectors J16 for the developing disengaging motor and J1100 for the DC controller PCB.
2 Replace the developing disengaging drive assembly.
3 Replace the DC controller PCB. Calibrate the printer after replacing the DC controller.
So, at the very least you'll need the developing disengaging drive assembly and, if that doesn't fix it, then you'll need the DC controller board. My bet is the DC controller has failed.
Sorry for the bad news, but please rate this solution as fixya even if it wasn't what you wanted to hear. Thanks.
Jan 10, 2009 | Office Equipment & Supplies
Beko WMI71641 Built in washing machin Logo
Top Beko Washing Machines Experts
Tom Chichester
J D Wright
 Russ Hill
Russ Hill
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
