Question about Home
How can I repair a Villeroy Bocht Cult watervalve there is not any screw to unlock the valve handle
I tryed to pull off the handel nut did not succeed maybe there is en need for a special tool ?
  • 6 Answers
SOURCE: How to remove agitator from Maytag A410 top loading washing machine
Remove the screw holding it down with a 1/4 inch nut driver.Look at the agitator from above and you will see a hole ,there is 1 only.Once you find tha follow from the hole up until you find the set screw and remove it
Posted on Jun 24, 2008
  • 140 Answers
SOURCE: DOOR HANDLE INSIDE BROKEN 98 SIERRA
It helps to have a flat pry tool to get the door panel off but, other than that it's not too hard. Autozone has a tool in the help section that is made to work with those and they have the replacement push clips that always seem to break.
Posted on Dec 31, 2008
SOURCE: How do I remove the manual window winder handle ?
I have to do the same with my door handle on my excel. The Window winder is held on by a sort of circlip thingy and they do make a special tool to remove it, and i would reccommend buying it or even borrowing one from a local mechanic. it is possible to remove it with a screwdriver and some wire but it is very hard and fiddly as you have to do it blind.
Posted on Jan 30, 2009
  • 2692 Answers
SOURCE: The faucet leak is from the top gasket around the control handle.
Yes, Grone will give provide a daagram and parts list.    All you need to know is the model number. The beasst source for parts is the manufactor. Can you match it up? Is it single lever or two handles? Can you go to a grone dealer and look it up in their model book? THey can also provide the rebuild parts.
Posted on Apr 25, 2009
  • 102 Answers
SOURCE: villeroy & boch flush mechenism needs to be replaced
V&B US phone number is or used to be 877-505-5350 they should be able to help.
Posted on May 26, 2010
Black water drain valve won't open
First try threading handle back into valve, turning clockwise and pushing in with a little force, it may have just backed itself out. If that doesn't work, you'll have to pull handle right out and get the longest wood screw you can get and slide it in hole where handle came out and thread it into knife valve far enough to hold and pull. Then replace valve after emptied and cleaned.
Mar 23, 2014 | Coachmen 2013 Brookstone Ruby 340 LS
Tip
How to remove a front right door panel concorde sedan four door 96
How to remove a door panel, first u must open the door and unscrew the screw that is in the door handle then with a flat head screw driver unhook the plastic conectors to the cover of the handel becarfull not to pull to hard gently pull it as needed then pull the door handle as if opening and then pull the cover of handle out wards and then un detach the electric conector for the door locks then on the bottom handel unscrew the screw that is in the handle then pull out the case that holds it. then unscrew the screws that are on the inside towards the interior of the car there are two then two on the bottom then on the side that opens there should be on or two then pull the panel upwards and then towards your self you should be able to also detach the electric conector for the windows then when your done fixing it the instalation is reverse make sure that you conect the window and door lock conectores and make sure that the door falls in place with window latch. good luck buudy.
on Aug 22, 2010 | Dodge Intrepid Cars & Trucks
Dripping bath faucet circa 1985. Can't ID model but appears to have 2 screws holding front of casting to main body for disassembly . Faceplate is square in shape and black in color HELP!
  • 1 Close the hot and cold water valves in the cabinet beneath the sink to shut the water supply off to the bath faucet.
  • 2 Remove the bath faucet's handle to access the valve cartridge. The faucet handle is removed by first detaching the handle's insert cap using the tip of a screwdriver or utility knife to expose the handle screw. Remove the handle screw with a Phillips screwdriver, then pull the handle off the valve cartridge stem.
  • 3 Loosen and remove the cartridge valve nut with an adjustable wrench. Some faucet models retain the valve cartridge with a snap ring and are removed with snap ring pliers.
  • 4 Pull the old valve cartridge out of the bath faucet base, using pliers.
  • 5 Insert the new replacement valve cartridge into the faucet housing and replace the nut or snap ring removed in Step 3, using an adjustable wrench or snap ring pliers.
  • 6 Reinstall the faucet's handle onto the valve cartridge post, then secure the handle's screw, using a screwdriver.
  • 7 Replace the insert cap into the handle to cover the handle's screw hole.
  • 8 Turn on the hot and cold water valves beneath the sink to restore the water supply.
  • Jun 15, 2011 | Kohler Plumbing
    I am repairing my Delta 200 faucet. Having a problem getting the spout off. How is that done? Thanks
    Remove the set screw holding the handle on. Pull the handle off and then remove the large diameter slotted nut holding the ball valve in place. After you remove that the spout, remove the ball valve abd then just pull the spout up and off. You may have to work it back and forth and you may have to spray some WD40 and let it sit overnight. It will come off.
    May 23, 2011 | Delta Model 200: Classic Single Handle...
    HOW DO I INSTALL A SEAL KIT
    A metal ball controls the temperature and flow of water from the spout in the vast majority of Delta single-lever faucets. That ball rests on three rubber seals, each seal suspending the ball with a single spring. Over time, wear on the seals, the springs and even the ball itself typically results in leaks. Thankfully, repairing the faucet is relatively simple, and Delta even makes repair kits with the replacement parts needed for each model.
    Turn off the valve that controls the main water supply. The valve is located next to the water meter, inside or outside the house, and must be twisted in a clockwise direction.
    Remove the plastic cap from the center of the faucet's handle by prying the cap free with the blade of a dull knife or a flat-head screwdriver, then remove the screw in the center of the faucet handle with a Phillips-head screwdriver. Pull the handle off the faucet assembly to remove it
  • Remove the single bonnet nut that surrounds the faucet valve with an adjustable wrench. Grip the bonnet nut at the base, which is ribbed to give the wrench a surface to grasp, and turn in a counterclockwise direction to remove it.
  • Remove the circular, white plastic cam that surrounds the top of the faucet, pulling it off and revealing a rubber seal, which you also remove. Next, pull the metal ball out of the faucet assembly and pry out the ball's supporting rubber seals and their springs with a screwdriver (the springs slide onto the bottom of each seal, so they will come out along with the seals).
  • Slide one replacement spring onto each of the three replacement seals that come with the Delta repair kit for your faucet model, then insert each seal into the assembly. Insert the replacement ball from the repair kit, then cap it by putting the replacement rubber seal over the ball, followed by the plastic cam
  • Place the bonnet nut over the faucet valve, then tighten the nut with an adjustable wrench. Position the handle onto the end of the faucet, then insert a screw into the center of the handle, tighten it with a Phillips-head screwdriver and, finally, press the decorative plastic cap over the screw.
  • Turn on the valve that controls the main water supply by twisting the valve in a counterclockwise direction to complete the repair
  • Jan 28, 2011 | Delta & Single Handle Shower Faucet
    How do I remove handle? I REMOVE POP OFF COVER & PHILLIPS HEAD SCREW & HANDLE WON'T PULL OFF.
    The handel should pull off it must me caroded up try pulling and twisting it at the same time.
    Jan 21, 2011 | Price Pfister Genesis Luxury Kitchen...
    How to, removing front right door panel on 1996 concorde chrysler 4dr sedan
    Aug 16, 2010 | 1996 Chrysler Concorde
    The water leaks from the top of the valve when the handle is fully opened.
    You may have to put a new repair kit in faucet, but you might try tightening the adjusting nut under the handle. Loosen set screw in handle, and remove handle. There is a nut there with 4 notches in it. Delta gives you a combo allen wrench/spanner wrench for this. Try to tighten this nut. If you can't you can buy a new repair kit for this valve for about 10.00 that comes with wrench
    Jun 27, 2010 | Delta Model 470: Signature Kitchen...
    '01 F350 tailgate repair; handle no longer operates
    You must remove the handle from the gate, this is done by removing the plastic tail-gate guard. On in side of gate are some torx screws , remove screws and gate guard will come off. Then there are some more torx screws to remove steel acess pannel, the tail-gate handel will be held in place by 2 10 mm nuts . After removal of nuts the handle will come out, inspect handle for brakeage or rust. replace if nessesary.
    Oct 21, 2008 | 1997 Ford F350 Crew Cab
    Door Handle repair
    The fastner must be loose. Remove both set screws remove your handel. Then tighten the fastner. reinstall the handel and tighten your set screws. let me kniow if this helps
    Aug 18, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
    Home Logo
    44 people viewed this question
    Top Home Experts
    Donni Steen
    Tom Chichester
    Are you a Home Expert? Answer questions, earn points and help others
