Question about Health & Beauty
<!-- from fixya rte -->Why does my scooter jump when using it - Health & Beauty
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
A power surge due to a shorted mosfet.
Posted on Nov 30, 2014
Scooter, when key is turned on the scotter jumps forward, the thottle is not in use, and the scooter is NOT IN GEAR, scarry
Your scooter may have lost its inhibit resistor 10k resistor that some scooters had on the center post of the throttle pot to stop this from happening. but the throttle has to be out of neutral position in order for it to move on startup. The throttle pots are normally 5k ohm pot, about 2.5k from the center to either outside posts. It would be wise to replace the speed control and the throttle together. Basically the controller thinks it is being told to go right at start up, that comes from the throttle.
Oct 06, 2015 | Health & Beauty
I recently bought a Honda Pantheon 125 reg 06. This a few time I have lost acceleration and this mor in the FI light came on then the bike stopped when I pulled to one side to inspect the scooter. I...
You may have a "spark jump" somewhere in your ignition system. Check wire from coil to spark plug and make sure it has a good connection. If the loss of power is still there, put the scooter in a dark place like garage, door shut and lights off. With a friend, you start the scooter and rev the scooter and your friend will look for spark jump from the exposed ignition system. If there is a jump, replace the offending wire.
Sep 26, 2017 | Motorcycles
Can you jump the batteries on the TSS300
If you mean jumping the batteries like you would a car; no this not possible with the AGM batteries. You should have 12v 32-35AH AGM batteries in the TSS 300.
Apr 26, 2014 | Electric Mobility 4 Wheel Heavy Duty...
NO DRIVE ON MY PRIDE REVO MOBILITY SCOOTER
You can try to do this with the cover off, just in case it is not seated properly and holding the lever from fully engaging. The actual swithc is a small microswitch down at the brake, and it can get dirt in it and that will stop it from working, or it may even fail, and need to be replaced. So I would:
1) try it woth the shroud off the motor using.
2) look for dirt around the switch.
3) take a paperclip and jump the scooter side of the switch to bypass the microswitch on the scooter, be careful not to short the jumper to the scooter frame.
Let me know how you make out.
Dan
Jun 11, 2012 | Pride Revo 4 Wheel Scooter
I have a Pride go-go ultra which is working fine, with new batteries except that on occasions when I insert the key I get a Bleeping signal and the scooter will not start, after repeatedly removing key it...
Alan, this could be that the switch is getting worn. If you can take the console off and get access to the switch try jumping across the switch and check that the scooter turns on and doesn't beep. If it works properly then the switch is worn and you can replace the switch with a plain old on/off toggle switch. If you want to buy a toggle switch and use it to jump the switch and see if the scooter works correctly. If it does then replace the old switch with the toggle switch. Hope this helps
Aug 19, 2010 | Pride Mobility Products Health & Beauty
Scooter cuts off while operating
Scooter hesitates when running or increase in speed could jump forward???
Jul 18, 2010 | Electric Mobility 3 Wheel Motorized...
Scooter wont start. will start with jump leads
neutral/safety switch might be bad. the safety switch that is controlled by pulling in the brake lever
May 11, 2010 | Motorcycles
the battery earth to the bikes chasy may be dirty check all battery leads are clean and tight plus any to the frame,,,
Mar 18, 2010 | 2008 Yamaha Yamaha G5
Health & Beauty Logo
50 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
