Question about Neff Ovens
How do I get a replacement clock unit for a Neff U1661N2GB/05 Double Oven
Neff Spares - no longer manufacture it and various other well known suppliers do not seem to stock it
4 Suggested Answers
SOURCE: i need to set clock on my neff u1322 double oven
Try depressing the two middle bottoms and turning the knob.
Posted on Mar 29, 2009
SOURCE: neff u1661n2gb/05. main oven not working and
I had a problem similar. The bottom oven stopped working and the left hand set of controls and clock died. I had three figure quotes for repair. I took the main control unit out from behind the switches, its a pain to do. I took pictures of where the wires went to save confusion later. I removed the main switch unit from the control unit by gently pushing back the inbuilt plastic clips. dont loose the small white connector piece on the end of the switch shaft. I gently pulled the switch knobs from the front then the knob extensions through the same holes. once the unit was out I turned it upside down I could see where two solder tracks on the circuit board had burnt out. I gently cleaned them up and bridged the gap with two short tinned pieces of single core wire I had stripped. I used a soldering gun as it gets really hot really fast and wouldnt damage the components underneath. the only fiddly bit when putting it back together was locating the bottom edge of the control unit in the little gulley, I had to bend the edge of the gulley down to make it easier. Once it was all back together it worked. Half an hour and I saved £300! Now I have to fix the hinges on the bottom oven door as it doesnt shut properly at the top. Any ideas anyone?
Posted on Nov 17, 2010
BADBOYJAY
  • 264 Answers
SOURCE: neff double oven trips rcd when either oven is turned on
your heater elerment has gone in the main oven i had the same problem if you need help takeing it out and see if its the problem get back to me ok
Posted on Nov 03, 2012
How do I tighten a loose handle on a Neff u1661n2gb/05 double oven
There are no screws holding the glass on. You need to pull off the inner glass. It just clips on so just pop a round knife at the top and it should just pop off. Tightening the screws should be easy but you probably need a torx screwdriver from memory
Mar 08, 2015 | Neff U1661 Double circotherm super...
Neff double oven trips rcd when either oven is turned on
Nov 03, 2012 | Neff U1421 Double circotherm Electric Oven
Neff u1661n2gb/05. main oven not working and shorts out electric when try to switch on. top oven works no problem
Nov 16, 2010 | Neff U1661 Double circotherm super...
Heat escaping, uneven baking, longer cooking times
Either the seals need to be replaced, or you may have weak oven door hinges, and the door is not closing properly.
Only solution would be to replace both hinges if this is the case.
Please rate my solution.
Thankyou.
Feb 01, 2010 | Neff U1421 Double circotherm Electric Oven
Please advise how to reset the time clock on a
Hold down 2 buttons - the first button on lhs "timer bell" the "hand" button and then use plus and minus with the other hand to set the time.
Jan 07, 2010 | Neff U1721 Double circotherm Electric Oven
Spare part number?
499003 available on line at neff spares remove back panel 6 screws lift up and out 3 screws holding element
Nov 23, 2009 | Neff U1721 Double circotherm Electric Oven
Lower oven not heating up everything else is working fine
hi, we have had the same problem. You can order the element from many places online, the cheapest is about £25 ranging up to £60 from neff themselves. Fitting it is ok the hardest part is getting the fan off to change the actual element. However, be warned, we are now on our 4th element and it just went again last night. Neff deny that this is a known fault that the elements keep going. However, at least 10 of our neighbours have had the same problem with their oven too!
Jan 18, 2009 | Neff U1721 Double circotherm Electric Oven
Neff B1442 Oven -- Defective timer and clock
Hi.
Is it flashing AUTO, If it is and you can'y reset it back to manual, then you have faulty timer.
Hope this helps
Nov 25, 2008 | Neff U1661 Double circotherm super...
Ovens Logo
75 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
