Question about Toys
I can't find an electronics repairer who can repair or replace a motherboard from an electric bed operating system ?
I've removed the motors pod, which is quite straightforward, and found that the motherboard has four solenoids on it, one for each direction of the two motors. They spark inside (seen through their opaque plastic covers) and only work intermittently. They need changing or I need a new motherboard. Unfortunately they're soldered in. I can't find any company who list the motherboard as a spare part. Any advice would be appreciated. Thanks. BRS
ysastek
  • 28 Answers
SOURCE: MOTHERBOARD REPAIR
First off, is the motherboard actually the problem? If your motherboard has failed, the screen may come on and you may have some sort of raster (brightness) but thats as far as you get. Power supply failure is (in my experience) more common than mother board failures (usually) and may exhibit the same symtoms. Also a bad battery on the motherboard will cause funky things to happen on boot. (clock not right/failure to recgonize hard drives, etc). If you are certain a motherboard is a fault you should replace it ( unless you are VERY fluent in soldering/desoldering surface mounted components and component level repair and have a solid understaning of digital and D.C. circuits) More often than not, replacing the entier motherboard is cheaper and less of a hassle.
Posted on Sep 13, 2008
SOURCE: How much does it cost to remove and replace a power supply
my friend here in guyana to replace a power supply it is VERY expensive i don,t know about your country
Posted on Nov 09, 2008
SOURCE: Corning cooktop burner outage
The cooktop has to be examined for failure of the element or the switch. Some of the switches & some of the elements are still around. Have the elements checked for continunity. You will have to take it out of the counter and take the unit apart to do this.
Posted on Nov 21, 2008
SOURCE: How to replace Ice Door Solenoid
I got help from repairclinic.com , and didn't see any reference to a solenoid. I fixed my GE fridge, its model is #TFX27FJB,,,,Free!!!! The replacement part would have cost 46.60.
On inside of freezer door, behind ice dispenser, there is a panel about 7x9
(plastic) that you can gently pull the tabs free and remove the panel. You will see the mechanical stuff. There are 2 gear like (pulleys) that are in the center area,supposed to be connected by a part that is about 3-5 inches long , like a small wire cable with hook type ends, think it's called "lanyard cable" , mine was broken, so I patched it with some scrap wire,,,one end hooked to one pulley and the other to other pulley(gear). When my ice door quit closing after getting ice,this cable had broken, What I did was find a small wire, to fix the break,, using as much of the original cable as possible, make sure that total length is same as original. Hook one end to one pulley and wrap it around it, it has to be wrapped a certain way, I can't remember counter-clock wise or vise-verso, till it will take up all slack, and just reach and hook to the other. I think it is a spring that opens door, and then the gears turn to close it, that is why it has to be wrapped with no slack.
It cost nothing and it works great now,, the repairclinic.com will show you specs so you can see what you are doing.
I didn't want my food to thaw, so I had a large piece of Styrofoam that I cut to fit in door jam, to keep food safe.
Good Luck
Hope this helps.
Barbara H.
Posted on Mar 20, 2009
SOURCE: Coleman 5640 cooler
The cover on the inside just pulls off. Inside/Outside fans pull off. 2 screws to dismount motor. Unscrew leads to terminal. Most truckstops carry the motor, otherwise search for Colman 5640.
Posted on Jul 26, 2009
I spilled milk on my keyboard and now the computer is not working at all?
possible that it is no longer a working unit
take it to a computer repair shop and get a proper diagnosis and quote
first lesson in life----water and electronics do not mix
Oct 10, 2016 | Computers & Internet
Tip
How to Repair an Odometer in car?
The procedure is follows:--
1) First of all disconnect the negative cable from the battery of car.
2) With flat head screwdriver, pry the gasket around the edge of the face of speedometer gauge away from the dash and remove the gasket.
3) You will have to pull the entire speedometer gauge out of the dash;
NOTE:-- do not to disconnect the connecting electrical wires when you pull speedometer.With the gauge face down remove the screws from the back of the case with a screwdriver. After removing the screws , lift the gauge out of its casing and see its back.
4) Then grasp the post to reset the trip odometer. Do it very carefully;
5) Then remove the speedometer needle by turning the needle clockwise.
6) Then remove the two screws in the face of the gauge with screwdrivers.
7) Remove the motor casing for the odometer out from the dial after the screws are removed.you will need to pull the motor casing a bit to remove it out.
8) In the motor casing you will see the gear pod at the top of the motor casing. Slightly with bit force remove the gear pod. The gear pod is attached to the "lid" of the casing .
9) You will see the odometer planetary gear in the gear pod which you removed.Remove the planetary gear from the gear pod with the help of mini flat head screwdriver.
10) Insert new gear into position and reassemble the gauge by reversing the procedure.
This will help.thanks.
on Mar 15, 2010 | Buick Century Cars & Trucks
Turn signal relay 2008 jeep location
There is no relay , controlled by integrated power module . Electronics !
Feb 12, 2016 | 2008 Jeep Grand Cherokee Laredo
Winsheild wiper will not work
The wiper control module is probably at fault ,without test that is just a guess . The wiper/washer switch is a input to the wiper control module. Do you know anything about automotive electronics an electrical systems ?
  • The Wipers are Inoperative
  • Fuse.
  • Wiper motor.
  • Multi-function switch.
  • Circuitry.
  • Wiper control module.
  • GO to Pinpoint Test B .
Voltage drop testing the power an ground circuits for the wiper control module would be a good place to start . Do you know how to test electrical circuits with a volt meter ?
PINPOINT TEST B: THE WIPERS ARE INOPERATIVE CONDITIONS DETAILS/RESULTS/ACTIONS B1 CHECK FUSE JUNCTION PANEL FUSE 16 (30A)
Fuse 16 (30A)
  • Is the fuse OK?
Yes GO to B2 .
No REPLACE the fuse. TEST the system for normal operation. If the fuse fails again, CHECK for a short to ground. REPAIR as necessary. B2 CHECK FOR VOLTAGE TO THE WIPER CONTROL MODULE - CIRCUIT 65 (DG)
Wiper Control Module C294
Measure the voltage between wiper control module C294-2, circuit 65 (DG), and ground; and between wiper control module C294-11, circuit 65 (DG), and ground.
  • Is the voltage greater than 10 volts?
Yes GO to B3 .
No REPAIR circuit 65 (DG). TEST the system for normal operation. B3 CHECK CIRCUIT 57 (BK) FOR OPEN Measure the resistance between wiper control module C294-3, circuit 57 (BK), and ground; and between wiper control module C294-5, circuit 57 (BK), and ground.
  • Are the resistances less than 5 ohms?
Yes GO to B4 .
No REPAIR circuit 57 (BK). TEST the system for normal operation. B4 CHECK THE MULTI-FUNCTION SWITCH
Multi-Function Switch
Check the multi-function switch; refer to Section 211-05 .
  • Is the multi-function switch OK?
Yes GO to B5 .
No REPLACE the multi-function switch; REFER to Section 211-05 . TEST the system for normal operation. B5 CHECK CIRCUIT 993 (BR/W) FOR OPEN Measure the resistance between multi-function switch C269-4, circuit 993 (BR/W), and wiper control module C294-7, circuit 993 (BR/W).
  • Is the resistance less than 5 ohms?
Yes GO to B6 .
No REPAIR circuit 993 (BR/W). TEST the system for normal operation. B6 CHECK CIRCUIT 589 (O) FOR OPEN Measure the resistance between multi-function switch C269-1, circuit 589 (O), and wiper control module C294-1, circuit 589 (O).
Yes GO to B7 .
No REPAIR circuit 589 (O). TEST the system for normal operation. B7 CHECK THE WIPER CONTROL MODULE OUTPUT FOR VOLTAGE
Wiper Motor C152
Turn the multi-function switch to the HI position. Measure the voltage between wiper motor C152-4, circuit 57 (BK), and wiper motor C152-3, circuit 56 (DB/O).
Yes REPLACE the wiper motor; REFER to Motor-Windshield Wiper . TEST the system for normal operation.
No GO to B8 . B8 CHECK CIRCUIT 57 (BK) FOR OPEN Measure the resistance between wiper motor C152-4, circuit 57 (BK), and ground.
Yes REPLACE the wiper control module; REFER to Module-Windshield Wiper . TEST the system for normal operation.
Jun 29, 2017 | 2002 Lincoln Town Car
For how long will my adjustable bed last?
Adjustable beds are built to last for many years, and most of the problems can probably be repaired. Most of the adjustable beds have lifetime warranty (depend on the brand).
Aug 20, 2012 | Furniture
Can't get the motor off to replace it, how do I remove the motor?
You take rear wheels off, then remove the rear axle.
There are 2 black hinge pins that hold the dump bed on. You need to remove those to get access to the motors.
I got help with my grandkids peg perego gator model at
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
they repair these items and were really helpfull and patient...even with me:)
I hope this helps
Mar 13, 2010 | Peg Perego John Deere Gator HPX Ride on...
Need electric motor for dual control air pump
I have the same problem with a Simmons Airpedic bed system. Same model #xx/fcwt2/001. We found this number on the motor 800 247-0677. They want $250 for a king size. Have you come up with anything?
Sep 23, 2009 | Electric Air Pump
Address of amd processor cervice center in mumbai
LAPTOP SERVICE CENTER IN MUMBAI :- 9819767710/9867635653/26396203/69 593087/9324572507/32641103 (SUNDAY OPEN 10:00AM TO 10:00PM ) (DAILY 11:00 AM TO 11:00PM ) LOCATION:- HEAD OFFICE 587, ADARSH NAGAR OPP TARAPORE TOWER LOKHANDWALA ANDHERI WEST LAPTOP SALES & SERVICE CENTER IN MUMBAI REPAIR HOTLINE :- 9867635653 BRANCHES LOKHANDWALA ANDHERI SANTACRUZ VILEPARLE MAHIM BANDRA GOREGAON JOGESHWARI MALAD NEWMUMBAI POWAI HIRA NANDANI (HEAD OFFICE LOKHANDWALA MUMBAI ) SALES & SERVICE CENTRE FOR I PODS & ALL BRANDED LAPTOPS ,LG IBM APPLE SONY LENOVO COMPAQ TOSHIBA FUJITSU SHARP SAMSUNG GATEWAY PANASONIC ASUS DELL HP Our Laptop/Note Book Repair Services Includes Laptop LCD Screen Repair Rs. 2000/- Onward Laptop LCD Screen Replacement Rs. 4500/- Onward Laptop Back Light Repair Rs. 3750/- Onward Dim Light LCD Screen Repair Rs. 1500/- Onward Laptop / Notebook inverter repair & replacement Rs. 1800/- Onward Laptop / Notebook Lcd flex cable / Lcd ribbon cable replacement Rs. 2500/- Onward Floppy Drive /CD ROM / CD RW / DVD Replacement Rs. 1800/- Onward Operating System Repair / OS Installation Rs. 1000/- OS To be Provide Hard Disk/Data Recovery / Virus Removal Rs. 2000/- Onward Motherboard Repair Rs. 750/- Onward Motherboard Replacement Rs. 4000/- Onward AC Adaptor Jack Replacement & Repair (Reciprocal jack on motherboard) Rs. 2000/- Onward Adaptor Repair Rs. 750/- Onward Lap Top Tune Up Rs. 1000/- Onward Power On Pass Word Problem Rs. 2000/- Onward
Sep 11, 2009 | Computers & Internet
Tempur-pedic remote control does not work have put in fresh batteries - control lights up- but no bed movement Please advise Thank You Carol
If the solution posted by Susan R. (below) fails to work, locate the black power down box under the bed. Check the battery compartment and remove all batteries. If batteries are installed they will prevent a full reset of the box. Unplug the power cord, wait 45 seconds and plug the power cord back in to reset the electronic components. Replace batteries. Now that the error has been wiped from the box's memory, you can now synchronize your remote with the power down box using Susan's instructions below. - Mike V., Antioch, CA
"Locate the power down box for the bed and press the "learn button" for 1 second and release (Black box under the bed). On the hand control, simultaneously press and hold the position 1 and off buttons. The transmission indicator light will flash slowly and then flash rapidly. Continue to hold for 5 seconds and then release the buttons. It should now work! Enjoy. Susan R., Paducah, KY"
For further assistance, refer to the user manual that came with your TEMPUR® Advanced Ergo System™ or you can download it here.
http://www.tempurpedic.com/media/Ergo_System_Complete_Ref_Guide_FINAL_022008.pdf
For phone assistance please contact a Leggett and Platt representative at 800-888-3078. Leggett and Platt is the manufacturer of the adjustable bed and remote components for Tempurpedic.
Apr 11, 2008 | Computers & Internet
Toys Logo
368 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
