Question about Lands Phones
I replaced my rechargeable batteries and am unable to call. Any incoming calls go into my vm. The phone doesn't ring and I am unable to retrieve the message. What is wrong
  • 36 Answers
Are batteries in the correct way? It's hard to help since we have no information to go on such as make, model, etc.
Posted on Nov 30, 2014
5 Suggested Answers
consultel1
  • 860 Answers
SOURCE: Incoming calls to office cause all phones to ring in classrooms
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
Hope that helps
Posted on Feb 19, 2009
SOURCE: our incoming calls are not ringing?
wen i receive incoming calls there is no ring or message alert
Posted on Dec 30, 2009
SOURCE: Incoming calls only ring once then hangs up. Can call out/not in
reset your mobile
Posted on Jan 29, 2010
SOURCE: landline phone does not ring out when there is an incoming call
incoming calls ringer on corded land line phone no longer works
Posted on Mar 11, 2010
I have a Uniden D3097. It is ringing only once on incoming calls. I have called from a different phone and it rings several times for the caller then goes to a generic VM not the VM I set up.
By any chance do you have call forwarding turned on? That would account for the single ring and the unfamiliar voicemail. Call forwarding is a service provided by your phone company or cable voice company which allows you to transfer incoming calls to another phone number, such as a cell phone. It's usually activated by pressing a key sequence (such as *72) and entering the number of the phone that you want to receive your calls. It's easy to turn it on and then forget to turn it off. You can turn it off with another key sequence, such as *73. Contact your phone company for the correct code.
Aug 12, 2014 | Uniden D3097 LOUD & CLEAR Cordless Phone -...
Toshiba DKT2010-sd calls no longer go to voicemail
go to the website http://www.telecom.toshiba.com/ go to the call forward settings in the book turn off Call forward All and turn on Call Forward NA (No Answer) by default it should go to the VM system. If it does not figure out what you dial in the keypad when you want VM to answer.
Nov 22, 2013 | Toshiba DKT-2010 Corded Phone
I have a problem with my Samsung iDCS 28D phone. All incoming calls used to be routed to me by default (unless caller specifically punched in a different extension). Calls are now being routed directly to...
try dialing 600 to clear call forwarding, then re-set your forwarding to busy/ no answer followed by the VM number.
I have uploaded a 'how to' video, more of these are at http://www.abbeytelecom.com
I hope this helps.
May 12, 2011 | Samsung DCS 12 Corded Phone
Cannot retrieve voicemail
When you press the message button, look at the display. Is it really going to the VM extension or is it going to another phone? Othre people could have left you a message by calling you and pressing the MESSAGE buttone either on purpose, or by accident.
You can clear ALL message lights from your phone by dialing *700 plus your extension and #. Of course you can access VM by dialing the VM extension, usually 165 or 500 from the intercom.
Apr 06, 2010 | Panasonic KX-T7630 Corded Phone
Nokia N72 mobile phone, am unable to hear dial tone when dialling and unable to hear incoming call answering a call and unable to from them when I make outgoing calls.
increase the volumes of ring tones ,unscrew the phone to check if the ringer is not faulty or damaged,repair or replace it ok
Jul 11, 2009 | Nokia Cell Phones
Turn off auto attendant for all incoming calls
Probably the easiest way to do this is to go into system programming #301 and turn off the ringing on the extension ports for VM/AA.
It still will go to VM if the cover extension is set to the ports, but the AA will not answer.
Carl
Apr 29, 2009 | Lands Phones
Haunted Phone!
well i can say I have had this issue before myself alot of the time it was due to interferance, lots of metal and steel in the way I had calls come in VM 4 days later make sure your always close to a window if there is lots of metal or tin around.
other then that I would contact your local dealer and tell them of the issue and see if there is something that can be fixed on the unit or if it is just a flaw of the phone itself and if possible upgrade or downgrade of the phone to one that will work correctly in your enviroment.
Nov 30, 2008 | LG CHOCOLATE VX8500 Cellular Phone
No respond to incoming calls
go to phone settings. check the profile and change it accordingly..regs
Jun 19, 2008 | Nokia 6260 Cellular Phone
Will Not go to voice mail
Jennifer209, if you press FEATURE + the button VM is pre-programmed on what does it display? It should show the extension number pilot to VM. If you call it directly, what happens? If you get no answer calling it directly, your VM may be down.
Kaait, is it getting into the VM that's the problem, or doing things inside the mailbox that is the problem?
Nov 21, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Lands Phones Logo
32 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
