Question about Kyocera Mita Office Equipment & Supplies
Have a kyocera 2560 tried to replace the touch screen and there is nothing to see at the display could you please reply with advise?
I have replaced the touch screen cause it did not work. Now I have got a dark screen. Any idea?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kyocera Mita Master
  • 884 Answers
Hi
Not being an engineer, I can't be specific about your problem, but you can get a full service manual for your machine relatively cheaply here:
Kyocera Mita KM2560 Service manual Parts Repair manual download
A description of the contents is given on this page and I also give it below:
"Service manual in English: maintenance, repair, troubleshooting, error codes, service mode, adjustment
Parts catalog: parts list, parts numbers, exploded diagrams
Service bulletin: Supplement manual, updates
Firmware"
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Nov 30, 2014
4 Suggested Answers
SOURCE: kyocera/mita KM1510 copier
Unfortunately it is the laser unit that has failed. And these unit's aren't a servicable item.
Posted on Jun 13, 2007
M2Tech1
  • 313 Answers
SOURCE: kyocera fs-1920 printer fault
if the machine is starting up and you just replaced the toner cartridge make sure it is seated properly also did you shake the cartridge slightly before fitting sometimes the cartridge can compact the toner and it doesnt agitate to the dev unit properly. check also if the dev unit has been reset properly and the lever set in place..
Posted on Jun 12, 2009
shawn38
  • 200 Answers
SOURCE: Hi, Have a Kyocera KM4050 copier/scanner/printer
First you have to get into the maintenance mode. It is important once in there you don't make any changes other than the one I tell you or you could damage the machine.
To get into maintenance mode do the following:
Press the STATUS KEY
With the numeric key pad key in 10871087 (if done correctly the display will change and say ENTER MAINTENANCE ITEM)
Enter 201 with the numeric key pad (follow the steps below):
1. Press the start key.
2. Select the [INITIALIZE].
3. Press the start key.
4. Press the center of the + keys. Be sure to press three + keys displayed in order. The touch panel is adjusted automatically.
5. Press the indicated three + keys, and then check the display.
6. Press the stop key. The screen for selecting a maintenance item No. is displayed.
Completion
Now to exit maintenance mode key in 001 with the numeric key pad
Press the Start Key ( you should be back to the status screen, press copy key to go back to the copy mode)
Remember do not go to any other maintenance mode or make any other changes.
Posted on Feb 19, 2011
TABLET FROZE. HOW DO I REBOOT?
Take BATTERY out , Should then re set & re Start when battery replaced
Jan 06, 2016 | Samsung Galaxy TabPRO SM-T520 16 GB Tablet...
Unfortunately om.sec.android.app.sansungapps has stopped
Mine has done the same on my android phone. I just ignore it, press ok, and carry on using it. Ive tried a factory reset but still no luck. Regards, Graham
Oct 19, 2014 | Samsung Galaxy TabPRO SM-T320 32 GB Tablet...
Kyocera km-2560 c6400 zero cross signal error
To reset this error hit 10871087 this will put the unit in Maint. Mode. Then press 906 then press start.Execute will appear on the screen press it. Either the machine will turn off by itself or it will say on the screen to turn the unit off then on using the power switch on the side of the unit. If the code comes back after all this either the fixing unit or the power supply are bad.
Hope this helps.
Jun 27, 2011 | Kyocera Copystar CS-2560 Black and White...
Error c6000 kyocera km-2560
THERES A PRINTER OR A PAPPER JAM GET AIR IN CAN BLOW OUT IF CARDLIDGE REPLACE WITH NEW.
Feb 15, 2011 | Kyocera Copystar CS-2560 Black and White...
Hi, Have a Kyocera KM4050 copier/scanner/printer with a touch screen. The touch screen is out of alignment (i.e. where you point does not align with what is sensed by the touch screen) and needs...
Completion
Feb 09, 2011 | Kyocera CS-2050 Black and White Copier
Hi We're using Kyocera Mita KM-2560. Unfortunately someone in our office was able to change login settings through device internal web interface. When I turn on the machine it asks username and password....
try Admin on both username and password ( A caps).
Also try 3000 on both or 6000 on both. try to select the system menu button and type the username and password there.
Jul 20, 2017 | Kyocera Office Equipment & Supplies
How to reset maintenance time kyocera copier cs-2560 ,
Enter "10871087" using
the numeric keys.
enter U251 Checking/clearing the maintenance count
reset it to 0
# to enter i think
Oct 09, 2010 | Kyocera Copystar CS-2560 Black and White...
182 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
