Question about Kitchen Ranges
One gas ring will not ignite as there is no spark,all others working ok
Do not know what to do ?
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number?
Posted on Nov 30, 2014
The igniter spark for all gas rings remains on permanently without pressing down the gas flow knobs. I can see nothing prompted this - I just came into the kitchen one morning to hear the igniter clicking...
This could be a problem with your spark module. its an electronic box either behind or under the cooktop. it sends the spark to the spark tip, which then ignites he gas. So in my opinion i would say it is your spark module.
Feb 02, 2011 | Smeg 23 in. SER34AX1 Gas Cooktop
2 of 5 burners do not start
The spark gap needs to have flow of gas across it for ignition to occur. The gas outlet holes at the point where the igniter sparks may be blocked, clean and inspect these for any blockages. Also check that the igniter spike is in the correct place. Careful evaluation of the position of the igniter in reference to the gas ring on the other rings may help you here. Good luck
Feb 02, 2008 | DCS CT-365 Gas Cooktop
KitchenAid gas stove main burner igniter does not work when the control knob is turned to the ignite position; however when any one of the other burners control knob is turned to the ignite position, the...
Hi Cecchung,
I think I know it.
Modern cookers have semi automatic ignition. Behind every knob there is a hidden switch and the switches are wired in "parallel". That means, when one button is put in "sparkstand", all plugs will spark. At least it should be.
In the youtube movie you can see how these switches are in a string.
So I suppose that the switch behind the button for the main burner does not work.
Fortunately, you still can lit that burne r with the other buttons.
Look at the movie, may be you can fix it yourself.
Kind regards, Dik
Maytag Gas Stove Burner Won Light Spark Ignition Switch
Feb 04, 2018 | KitchenAid KGST307 Gas Kitchen Range
Igniters works, gas may take up to 30 seconds to allow ignition
if you mean that there is gas comining out and it takes time before the gas ignites then check that the electrodes are not broken as this will allow the spark to go to earth and the gas will have to 'chase' the spark, not advised as the gas could build up and be a potential hazard. remove the top of the gas rings and make sure that they are clean, also clean the metal part with a brillow pad or wire wool to increase the chance of the spark reaching its designated point, ie. closer to to the gas thus ignition will(should) be almost instant. hope this helps.
Apr 07, 2010 | GE Profile JGP636 Gas Cooktop
Duvalli GHG604B gas hob ignition problem. Ignition has stopped working. Everything is clean and dry. Power and fuse is O.K. I suspect the spark generator unit, but how can I test?
If you know the power and fuse is ok, and none of the knobs will turn on spark, the only thing left is the spark module. The switches would never all go out at once.  Good luck
Jan 07, 2010 | Cooktops
Gas jets wont start they just make clicking sound
try oven if working gas valve system possible ok lift off covers to expose igniter looks like a little wire that arcs a spark to ignite gas clicking is igniter trying to spark ,clean area of debris if any, if no spark will need igniter adjuster /repaired or replaced and gas valve checked for proper function
Oct 19, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Sunl 150cc Won't start
sounds like the CDI module. I've had it go out on a couple scoots I've owned. Take it to a shop and have them check it
Oct 07, 2009 | Transport Schwinn Rechargeable Portable ...
Cannot ignite central gas ring on smeg 5-ring kitchen hob
I had a similar problem on a different gas range but your problem seems the same as mine was.
I examined the underside of the burner and saw a little 'flash' left from the casting process and I filed it off. This made the problem worse; it wouldn't light at all anymore.
I tried the opposite, blocking off the burner channel from the gas feed pipe to the spark gap; problem solved. It hasn't had a hiccough since.
I can only imagine that the flow of gas toward the spark gap was so strong, the gas was blowing itself out.
Not knowing exactly how the underside of your burner looks or how the gas is partially diverted to the spark gap but I drilled a small hole in the casting, inserted a length of copper wire (the gauge used in house wiring), then 'tuned' the flow by clipping part of the wire off and trying it. It might have taken all of 15 minutes to correct the annoying problem.
Nov 24, 2008 | Smeg 23 in. SE64 Gas Cooktop
My GE gas cooktop not working. Model#JGP336BEV1B8
Are the other 2 burners lighting with the spark? If so the other 2 are either shorting before the burners or the sparkers are faulty.
To service, the cooktop needs to be completely removed from the bench and disconnected from the gas as the access is from the bottom.
I could step you through it while watching, but to do it this way is not a good idea. It's probably worth ringing a serviceman.
Dec 26, 2007 | GE 30 in. JGP336 Gas Cooktop
Kitchen Ranges Logo
95 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
