Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Under neath the filter at the base of cleaner should there another filter underneath the colth one
Looked under filter and there is only a cloth one
  • 20 Answers
If you are referring to the filter at the base of the machine on the right hand side (standing in front of the machine with the clear cylinder directly in front of you), then, when you remove the filter housing you will see a filter with what looks like the spokes on a wheel. The cloth-type filter is permanently attached to this part. Behind that should be a round, thick, blue foam filter with a hole in the middle (like a doughnut).
I hope this answers your question.
Posted on Nov 30, 2014
The upholstery tool on my bissell lift off deep cleaner sprays bUT doesn't suction?
The lint filter on the water tank cover may be the reason for that. Try cleaning the Filters. Clean the Flow Indicator Filter: Unscrew the Flow Indicator Cap to remove it. Lift out the rotor and the filter is under it. Lift out the filter and clean. The Water Tank Filter looks like a screen on the underneath the front area of the cover. It's held in with tension and just pulls out. Clean it and replace it. Hope that Helped but if it didn't call the consumer care at 1-800-237-7691
Sep 14, 2015 | Bissell Vacuums
Is there a filter underneath the cloth one at base of stork
Hi Stephen, it's Jack at Dyson.
DC07 has two filters, a washable pre-motor filter, and a post-motor filter that doesn't need any maintenance. Both filters are engineered to last the lifetime of the machine in normal use, and shouldn't need replacing.
We wouldn't expect a filter to be missing from the machine unless it's previously been removed and not replaced. The washable pre-filter is shown in the video below - it has a yellow plastic outer section, and a blue sponge inner section:
If you're concerned that either of the filters is missing or damaged, you can order a replacement by calling us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Nov 30, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
Bissell instruction manuals
The instructions tell you to clean filters after each use. Check the User's Guide for specifics. Quick guide though. Water tank Cap: Under the cap is filter (looks like a screen) remove, clean, replace. Locate the Flow Indicator: turn it counter-clockwise to remove the cap. Lift out the rotor and the filter underneath, Clean and reinstall in reverse order. That should fix the problem. Consumer Care phone number is listed in the User's Guide.
Aug 20, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
How to open to clean
Hello! The dirt cup, filter and brushes need to be cleaned to ensure continued cleaning effectiveness. Below are steps for cleaning your Hoover Slider.
Turn switch to OFF position.
1. Press button and slide latch towards outside of cleaner. Rotate dirt cup toward back of cleaner.
2. While holding dirt cup, grasp filter frame and lift out filter. Empty dirt cup after every use. Dirt cup can be cleaned with a damp cloth. Allow to dry thoroughly.
3. Pull middle section of filter out of filter frame. To remove debris from filter, tap it on a hard surface or brush it with a soft brush.
4. Remove lint, strings, etc. from the brush roll located on the underneath side of the nozzle.
5. Replace the brush roll when the brushes do not touch the edge of a card as it is moved across the opening on the bottom of the nozzle.
Further disassembly of the cleaner is not recommended. Hope this helps!
F
Aug 13, 2014 | Hoover S2105 Slider Bagless Stick Vacuum
Loss of suction
do not connect to electricity at this point claim a little work area put a blanket down as you are going to strip it all down into little bits clean and then put it all back,
Take apart power cable unwrap, unclip middle glass cylinder section to empty rubbish out, there should be a filter at the base that you can see now unclip clean put back, empty rubbish out of cylinder clean base and top rubber section and filter section with fine brush, use a wet cloth to wipe clean all black rubber suction connectors put back, at the back there will be a hose connector at the base unplug clean put back and make sure no debris is in any of the connectors and underneath where the floor brush is before you start puting it all back , Hope this helps
Feb 17, 2014 | Eureka AirSpeed Bagless Zuum
Bissel power wash pro heat
Look under neath there is a **** hole. It may be plugged
Feb 09, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Dyson DC07 Original won't pick up at base
Lie machine on its side pull back handle as if vacuuming & switch on (KEEP YOUR FINGERS & ANY LOOSE CLOTHING CLEAR OF BRUSH ROLLER)
Brush should spin if it doesnt ensure clutch control knob on side of machine is in drive position if it isnt rotate knob by hand to drive brush should now spin.
If it doesnt & your machine has A clutch either clutch will need replacing or belts will need replacing.
Manuals are available to replace belts & remove the clutch from this site http://dysonmanuals.llc.nu/index.htm
Apr 28, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bissell vaccum problem
Could be plugged, check the hose and at the bottom by the brush roll, the inlet maybe clogged. Also check the filter under neath the dirt tank. There are filters above the dirt container, clean those out. If after that it is still loud, then maybe the motor fan or bearins are bad and will have to be replaced, part #2031214 sells for around $55.
Jan 16, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
54 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
